Author Topic: Good? Bad ? Need help  (Read 755 times)
Offline josherr
« on: August 30, 2015, 01:31:57 PM »
Newbie here
Today when I was taking off my exhaust pipes I looked inside the cylinder head all I saw black dust
Is this normal or is something not right
Anything helps
Thanks
Offline goldarrow
  • one day, i'll be an
Re: Good? Bad ? Need help
« Reply #1 on: August 30, 2015, 01:33:25 PM »
If your bike has 0 miles, and with that much carbon deposit, then I'd worry.
CB550 K0
Offline calj737
  • I refuse...
« Reply #2 on: August 30, 2015, 02:28:26 PM »
It's not good. It's a sign of too much fuel and too weak of a spark to burn the fuel present. Short of pulling the head and having it cleaned professionally, best you can do is get he bike tuned properly, and run some high quality gas and a fuel additive to help de-coke the motor.
Offline goldarrow
« Reply #3 on: August 30, 2015, 02:50:36 PM »
Only to have it come right back.  Unless your looking for something to do, pull the head is actually fun and enjoyable experience.  Be ready to "might as well do it while you're there"
CB550 K0
« Reply #4 on: August 30, 2015, 07:10:16 PM »
perfectly normal
« Reply #5 on: August 30, 2015, 07:20:19 PM »
And run the #$%* outta it to blow that stuff out.
Offline RevDoc
« Reply #6 on: August 31, 2015, 05:45:13 AM »
From the Hondaman post "Things that cause a ratty idle":
#4: carbon buildup on the intake valve guide and stem. When the assembly warms up and the guide opens up, the thing runs OK. Try running BG44K (1 ounce per tank of fuel) for a while, or pull the head to check it out. (Bold is mine.)
BG products are available online. Did a nice job on one of my bikes.
 Then do as Jerry Rxman suggested!
Dana
'78 CB550K--Angie
'82 CB750 Custom--Eva
As soon as you straddle a bike expect every other driver on the road to suddenly start competeing for the title "Dumbestsonofa#$%*inallNorthAmerica!!"
