Author Topic: Removing swingarm busing and steering neck races ?  (Read 4994 times)
Offline rddcw
« on: September 01, 2015, 10:02:25 AM »
About to purchase a Brass drift to help aide the removal of my swing arm bushings and steering neck races on my 74' CB 750 K4. What size and length of drift are you guys using ? The manufacture offers these drifts in different size diameters and lengths.
Re: Removing swingarm busing and steering neck races ?
« Reply #1 on: September 01, 2015, 11:01:42 AM »
I used a 3/8 socket extension with a good edge
Online 70CB750
« Reply #2 on: September 01, 2015, 11:02:56 AM »
The neck is easier, I used Harbor Freight brass, 1/2".
For the swingarm, I used a steel bar, it takes bit more effort.  Some people make smart washer for getting bushing out - diameter of the bushing, grinded on sides to fit through the bushing.  You slide it inside the swingarm, turned it flat and use  a punch on top of the washer to get bushing out.
« Reply #3 on: September 01, 2015, 11:35:48 AM »
I saw thru one side of the old bushing. Then it falls out.
Offline Henning
« Reply #4 on: September 01, 2015, 12:08:28 PM »
For the neck races any sort of drift will do. Just be careful not to skew it; I did that once and it was a mutha***** to beat back up so I could knock it out straight.
For the swingarm bushings I prefer the "D" washer method with a threaded rod, do a search. That way you can get them out in a controlled fashion. Sometimes they are more or less welded to the swingarm by rust and there's only a thin lip to beat on with a drift, and it can quickly get rounded out. Hack-sawing I would say is a last resort; you will leave marks inside the swingarm.
71 or thereabouts 750 K1 - this one should have been put down
Offline rddcw
« Reply #5 on: September 01, 2015, 12:57:16 PM »
Henning,  Would you be able to describe the "D" washer method ?  If I do purchase a Brass drift, anyone know how Long the drift or extension should be ?
Offline Henning
« Reply #6 on: September 01, 2015, 01:36:01 PM »
Find a sturdy washer with the same OD as the inside of the swingarm. Hacksaw off opposing edges sufficiently to slide it through the bushing. Flip it on its side at the back edge of the bushing and use a threaded rod to free the bushing. It may be overkill for your swingarm, but as I said people have had serious problems getting the bushings out. Pic:
Online 70CB750
« Reply #7 on: September 01, 2015, 01:41:21 PM »
^^ yep, see my post above, couldnt find a picture :)
Offline Henning
« Reply #8 on: September 01, 2015, 01:55:08 PM »
Yes, saw that :)
It will work unless he has the top hat style bushings, struck me after my post. Not sure what a K4 has.
« Reply #9 on: September 01, 2015, 04:38:09 PM »
Yes, saw that :)
Early K4 has the standard bushings, but the last of the K4 has the top-hat type.
Offline Davez134
« Reply #10 on: September 01, 2015, 06:00:57 PM »
I did this as well, with simple hacksaw blade. Came out sooo easy!
Offline rddcw
« Reply #11 on: September 01, 2015, 07:05:38 PM »
Are those pivot bushing in the swing arm plastic and do you stop before cutting all the way thru the bushing with the hacksaw blade ? I'm assuming that once you cut thru some of the bushing it makes pushing the bushing out easier ?
Online 70CB750
« Reply #12 on: September 02, 2015, 04:33:43 AM »
Late arms had plastic bushings in them.  I painted the F swingarm and baked it in the owen and those bushings just fell out on their own.
Offline Davez134
« Reply #13 on: September 02, 2015, 06:49:38 AM »
you cut all the way through the bushing giving it room to, I guess retract/get smaller in circumference. Comes out easily.
Offline rddcw
« Reply #14 on: September 02, 2015, 03:17:42 PM »
Prokop,  You said Late Arms. My Bike has a build date of 11/74.
« Reply #15 on: September 02, 2015, 04:39:03 PM »
Around that time, the bushings were changing from the straight type to the top-hat type. They were phenolic material then, too. When you powdercoat arms and the arm gets baked, the phenolic bushing does not expand, so it falls out while the arm is hot! honda's replacement bushings for these arms are not great, and the aftermarket bronze ones often do not fit, neither the hole nor the collar, correctly. The final fit must be .0008" to 0.0012" collar clearance or the arm will be loose (again).
« Reply #16 on: September 02, 2015, 06:57:57 PM »
HM - Have you tried the bushing from the Kensua Kid on ebay [Germany]?
Offline theslayedsaint
« Reply #17 on: September 02, 2015, 07:36:30 PM »
I just send the arm to get powder coated and when it comes back its gone! problem solved   ;)
1974 CB750 custom build cafe racer
-849cc big bore
-Webcam 63a
-APE rods
-4-1 stainless exhaust
-GSXR front end
Online 70CB750
« Reply #18 on: September 03, 2015, 04:05:28 AM »
Thats a good guy to buy from for us cheapasses who don't send swingarms to Hondaman :)
http://stores.ebay.com/kenosha-kid-motorcycle-parts?_rdc=1
« Reply #19 on: September 13, 2015, 10:08:36 PM »
Kenosha Kid?
Yep, I have had to saw and grind out 2 sets of his bushings. Their owners (victims?) were told they would fit their arms, but the bushings were too big OD and seized during the installations, partway in their holes. They measured almost .003" larger than the swingarm holes, which made them impossible to install. After they got all mashed in the attempt(s), the arms ended up at my house. :(
And a sonofa....to remove!
Online 70CB750
« Reply #20 on: September 14, 2015, 04:13:25 AM »
Kenosha Kid?
I installed pair in my swingarm, no problems at all.   Just saying  :)
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #21 on: September 14, 2015, 08:16:04 AM »
Kenosha Kid?
Me too.
--Evan
1975 CB750K "Rhonda"
Offline alacrity
  • Ride, Optimize, Repeat
« Reply #22 on: September 14, 2015, 02:52:45 PM »
Same as a couple others suggested.  With perhaps a bit more detail. - I posted this a few years ago
http://forums.sohc4.net/index.php/topic,104216.msg1165478.html#msg1165478
I recently restored and sold a 77 cb750f, and am nearly finished with a (former basket case) cb750k5.  This is a place to share, learn and enjoy.  I am grateful to and for 99+% of this site's membership.
« Reply #23 on: September 14, 2015, 03:57:28 PM »
Kenosha Kid?
Which bike (and arm) was it?
Online 70CB750
« Reply #24 on: September 14, 2015, 04:18:47 PM »
It was an F arm, not sure what year. It had phenolic bushings - they fell out when I baked the paint - so I got these from Germany and pressed them in. Using it now in the K3F hybrid I just finished.
