Author Topic: PD Carb linkage pass through gaskets  (Read 666 times)
Offline Zax
« on: September 03, 2015, 08:51:09 PM »
Hi,
 I am in the middle of a carb rebuild on my 78F. I have various gaskets in the pass through holes the throttle linkage runs to connect the 4 carbs. There are felt style rubber and none. Can some one tell me what is suuposed to be in there and where I can get replacements? I have searched the usual part sites and gone through a ton of schematics with no luck.
Thanks,
Zach
1978 CB750F
Offline Desert-SOHC
  • It's old
Re: PD Carb linkage pass through gaskets
« Reply #1 on: September 03, 2015, 10:41:06 PM »
Its supposed to be a little felt ring but I've been told that they are no longer available. I left the ones that were there and did nothing for the ones that weren't, they seem to be there to keep gunk out...they don't seal anything.
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
Offline harisuluv
« Reply #2 on: September 03, 2015, 11:29:35 PM »
Yes--they are just basically to help keep the gunk out.  Not important for sealing at all.
Remember, the vacuum sync procedure involves taking OFF the caps and adjusting them like that, so don't worry about it being a good seal.
Offline Mantree
« Reply #3 on: September 04, 2015, 12:39:43 AM »
When i rebuilt my cb650 carbs there were no gaskets there
Sent from my ME302KL using Tapatalk
