Author Topic: Valve Production Run Finished  (Read 1168 times)
Offline Big Jay
    • CBRzone
« on: September 05, 2015, 01:02:05 PM »
New production run of Honda sohc 750 valves just completed.
These valves are real stainless steel and have hard chrome stems. APE is the only one that makes this valve, and it is available direct from APE, thru all APE distributors and all leading cylinder head shops.
APE developed these valves as an addition to our ever expanding real race valve line, when we became involved with the restoration of the R.C. Engineering iconic top fuel motorcycles, once ridden by the legendary Russ Collins. We found when doing the cylinder heads, that there were no valves available that you would want to run in a supercharged nitro Honda.
Now all Honda sohc 750 owners can benefit from this by the availability of a true high performance valve for every Honfa sohc 750.
They are available in std size, as well as 1.5mm oversize intake and 1 mm oversize exhaust.  These valves racer at $24.95 each. Why settle for anything less in your engine.    http://cbrzone.com/sohc.html
Re: Valve Production Run Finished
« Reply #1 on: September 05, 2015, 02:13:37 PM »
Should that post be reported for too much bike parts porn in one post?
 ;D :P 8)
Good job Big Jay! Thank you for the continued support and all the great work that comes out of APE.
David
« Reply #2 on: September 05, 2015, 06:06:56 PM »
Agreed!! Thanks to you and APE for all of the sweet parts for our machines, the helpful advice from staff and sponsorship of the forum!
Offline johno
« Reply #3 on: September 06, 2015, 01:21:24 AM »
Yeh I bought a set about a month ago for my new 1,000cc class salt bike
I'm a bit of a stainless junky anyway and thought at least the valves wont rust after getting a gutsfull of salt after a run on the salt. ;D
GRASSHOPPER SOHC HONDAS ARE THE MEANING OF LIFE.
