Author Topic: Weird topend noise cb750 with pics..  (Read 2172 times)
« on: September 05, 2015, 01:21:43 PM »
I put 200 miles on this on this on Wed, 60-70 mph thru steep mountain passes.
At the end of the day it had gotten a lot louder..
 I decided. To cut the frame and pull the tappet cover..
Does this look bad ?   ? ?
« Last Edit: September 05, 2015, 01:26:47 PM by 754 »
Offline Trad
Re: Weird topend noise cb750 with pics..
« Reply #1 on: September 05, 2015, 01:25:34 PM »
Those lobes are pooched, it looks like the bearing surface is all scored too. Oil starved looking results.
74 CB550 Build: NOS-GUTTED-OEMplus-HOLDTRUE
http://forums.sohc4.net/index.php/topic,130575.0.html
Offline goldarrow
  • one day, i'll be an
« Reply #2 on: September 05, 2015, 01:26:32 PM »
Yes, look bad.  Lack of oil up top?
CB550 K0
Offline BPellerine
« Reply #3 on: September 05, 2015, 06:34:57 PM »
does this look bad,a little humour there frank??bill
1978 CB 750K ard and webers
another anfob
Offline Garage_guy_chris
« Reply #4 on: September 05, 2015, 06:43:22 PM »
meh nothing wrong with that. Throw it back in change the oil to 85w140 gear oil. adjust the tappets to 1/4" clearance and enjoy!
Offline enwri
  • So that noise is normal?
« Reply #5 on: September 05, 2015, 07:08:53 PM »
VTEC?
77 CB 750 k.. 29 years and counting.
91 TDM 850 (No.34) so comfy and soft
8? XJ 550 meh...
76 XL 350 Super Sport stump puller..
80 XR 200 idiot proof
75 MX 250 b dangerous
Offline jonda500
« Reply #6 on: September 05, 2015, 10:16:22 PM »
I'd love to see the rockers that went with that camshaft- that's the worst one I have ever seen! John
A starter clutch thread:
Offline mrbreeze
  • Not your average
« Reply #7 on: September 05, 2015, 11:17:45 PM »
If ya keep running it like that it will wind up looking like Garage Guy Chris's piston!!
MEMBER # 257
« Reply #8 on: September 06, 2015, 03:16:30 AM »
Metal burrs all over the engine or at the top only?
Maybe time to pull engine and repair it all, find the reason for oil problem that might have caused more damage. Crank, rod bearings...?
« Reply #9 on: September 06, 2015, 07:53:30 AM »
Changed cam, rockers, towers..runs like a swiss clock..
Offline Old Scrambler
« Reply #10 on: September 06, 2015, 09:19:02 AM »
But will the Swiss clock be running after a few hundred miles?
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #11 on: September 06, 2015, 10:38:05 AM »
It better, got around 500 miles to ride back..
« Reply #12 on: September 06, 2015, 11:33:58 AM »
Tick-tack-tick-tack-tick-tick-crack!
Offline Henning
« Reply #13 on: September 06, 2015, 01:23:32 PM »
So, you just happened to have a spare cam, rockers etc. in the toolkit under your seat?
71 or thereabouts 750 K1 - this one should have been put down
« Reply #14 on: September 06, 2015, 04:38:54 PM »
Had to drive 390 miles round trip in a cage...to my stash..
 Cut frame  tore down,  and fixed it Friday..
 Did not remove carbs, moved coils.around, without unclipping the wiring..
Most of the debris settled under the cam tower, the pocket on outboard side, and the depression by the front oil drain..... A bit of stuff in filter housing but. Far less than expected. ..good thing
 Got 200 miles on it..running great.... Finally on the road..
« Reply #15 on: September 06, 2015, 05:29:31 PM »
Did you check that there is a good amount of oil getting up there?
« Reply #16 on: September 06, 2015, 08:04:56 PM »
Yes, oiled everything but the top collar on the valve..
 Rode a couple miles pulled the tappet covers on 4.. The collars were oily..
 We pulled the destructor jet and cleaned it and part of the passage.. The jet looked clogged and I got some stuff out of the oilhole.
« Reply #17 on: September 07, 2015, 03:08:31 AM »
Silicone used at a previous repair? Or too much case sealer that fall off? More to come and block the passage?
« Reply #18 on: September 07, 2015, 02:29:32 PM »
I like to hope its finished that.. It better get me home..
 Yeah I new by the silicone hanging off case mating surface, that this could've a possibility.. Blank,  no number cases on it..
« Reply #19 on: September 08, 2015, 07:43:28 PM »
The Swiss watch has about 575-600 me les on it and got me home....good good..
Offline mystic_1
  • 1970 CB750K
« Reply #20 on: September 08, 2015, 08:43:00 PM »
Glad to hear you managed to RTB safely.
mystic_1
- John Augustus Shedd
« Reply #21 on: September 14, 2015, 10:02:17 PM »
Got 1000 miles on it now... Don't know whether to call it...
 The Blue Bastarde.....or the Swiss Clock.....lol
