SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
1975 CB400F Crankcase cracks below oil filter
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: 1975 CB400F Crankcase cracks below oil filter (Read 1659 times)
Cablecarusa
Full Member
on:
September 09, 2015, 07:10:09 PM »
I was cleaning up the engine (out of bike) and found three small cracks on the crankcase just below the oil filter housing. The motor has about 9k and looks to be very clean (sat in garage since 81). I don't want to take the motor apart if I don't have to. Suggestions??
Logged
Powderman
Master
Re: 1975 CB400F Crankcase cracks below oil filter
Reply #1 on:
September 09, 2015, 07:14:22 PM »
Are they actual cracks or those crack looking spider webbing in the casting?
Logged
Cablecarusa
Full Member
Reply #2 on:
September 09, 2015, 07:16:43 PM »
They are actual cracks with a length of 1/4 to 1/2 inch. Wierd because I didn't see any oil leaking from them
Logged
Don R
My Sandcast is a
Really Old Timer ...
Saver of unloved motorcycles.
Reply #3 on:
September 09, 2015, 07:21:19 PM »
Probably a cold spot in the casting, if there's no leak I'd go forward.
Logged
MoMo
Ride like you're invisible
Reply #4 on:
September 09, 2015, 07:22:22 PM »
can you post a couple good close up photos ?
Logged
Cablecarusa
Full Member
Reply #5 on:
September 09, 2015, 07:25:07 PM »
Thanks all for the response, I'll post a couple pics in a few.
Logged
Cablecarusa
Full Member
Reply #6 on:
September 09, 2015, 07:39:40 PM »
Here's one
Logged
Cablecarusa
Full Member
Reply #7 on:
September 09, 2015, 07:42:37 PM »
And no.2
Logged
MoMo
Reply #8 on:
September 09, 2015, 07:47:46 PM »
Thanks, I've never seen anything like that but it does seem to be superficial. Could have happened from someone beating on the oil filter retaining bolt. I'd clean the area, use something like JB Weld, button it up and keep an eye on it....Larry
Logged
Cablecarusa
Full Member
Reply #9 on:
September 09, 2015, 07:55:00 PM »
Many Thanks! I'll get some JB tonight
Logged
Don R
My Sandcast is a
Reply #10 on:
September 09, 2015, 10:55:24 PM »
I JB'd some cracks in a set of chevy 292 turbo heads. The same heads Earnhardt hated. They lasted until race season was over. You're ahead if they aren't leaking, could have been collision damage to a previous filter and bolt.
Logged
Flyin900
Expert
Reply #11 on:
September 10, 2015, 06:06:52 PM »
I would suggest using the JB High Temp metal epoxy on that fix not just straight JB Weld. it comes in a grey stick that you knead a small amount as required together and then apply to the cleaned area.
I have used it numerous times on bike engines and it is rated to 450F continuous and can be sanded/painted if necessary.
I rebuilt missing/broken fins on a CB 350F head over a wire scaffold covered with this material and was able to sand and paint them like it never happened.
Never had any issues with heat or bonding or the repair holding the high temp paint.
Last Edit: September 10, 2015, 06:09:08 PM by Flyin900
Logged
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
