Just a few days ago I removed mine. A 1" hole saw, preferably mounted in a drill press, (but not necessary), perfectly removes entire bushing without damaging inside diameter of hub. I used a hand held drill for the first one. Works fine if you're careful. Not even an impact hammer, after soaking in Kroil 3 days, would remove mine. Where did you finc the bushings? I paid a fortune for mine, from some guy in England, after an exhaustive search
