Author Topic: cb 650 cam to 550/500 what modifications have to do?  (Read 1775 times)
Offline kranta
  • honda cb 250RS 1981 CAFE & honda cb 500 four 1978.
« on: September 11, 2015, 01:47:13 AM »
so what modications ihave to do if i put 650 cam to 550 or what parts i have to change?
Offline Scott S
Re: cb 650 cam to 550/500 what modifications have to do?
« Reply #1 on: September 11, 2015, 03:47:58 AM »
 You have to  put the 550 cam chain sprocket/gear on the 650 cam. You will also most likely have to clearance the head a little bit to clear the cam lobes. Where and how much varies from bike to bike. It can be done with a  Dremel tool.
 And, of course, cam chain and valve adjustment.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline DaveBarbier
« Reply #2 on: September 11, 2015, 04:16:48 AM »
I may be mistaken, but I think you'll also need the tach drive gear and a tach gauge with a 650 ratio.
Offline Restoration Fan
  • My wife will never call me
« Reply #3 on: September 11, 2015, 04:23:21 AM »
If you're going with the mechanical tach, maybe so.  But I believe that cal and a few others run a magnetic tachometer that reads from pickups on the front sprocket.
Offline Bailgang
  • Scott
  • Indiana
« Reply #4 on: September 11, 2015, 04:32:49 AM »
+1
750 tachs have the same ratio as the 650 tach which is what I used on my 550 when I swapped a 650 cam in it.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
Offline Bailgang
  • Scott
  • Indiana
« Reply #5 on: September 11, 2015, 04:38:59 AM »
Do you mean electronic speedo maybe? I can't see how mag pick ups on the front sprocket will work for a tach especially if bike is in neutral.
Scott
71 cb350 twin
77 cb750 F2
« Reply #6 on: September 11, 2015, 04:42:39 AM »
You're right.  Brain fart.  My bad.
Offline Bailgang
  • Scott
  • Indiana
« Reply #7 on: September 11, 2015, 04:44:47 AM »
It's all cool, I'm still on my first cup of coffee. :)
Scott
71 cb350 twin
77 cb750 F2
Offline kranta
« Reply #8 on: September 11, 2015, 05:09:13 AM »
ok, thanks! ;D
Offline goldarrow
  • one day, i'll be an
« Reply #9 on: September 11, 2015, 05:37:02 PM »
Be sure to test fit the 650 cam on to the head, spin it by hand and make sure cam lobes don't hit the head
CB550 K0
Offline Kenzo
« Reply #10 on: September 11, 2015, 05:53:35 PM »
How often are there clearance issues with the 650 cam in a 550? Most of the post imply simple easy drop in power improvements.
Where is the best place to source these cams?
TIA
Kenny
H-Town, Tejas
>1976 CB550F SuperSport (Work In Progress)
MotoGP Werks Exhaust, Uni Pods
>2006 KTM EXC 453 (EXC 400 w/ Short Stroke Big Bore Kit)
« Reply #11 on: September 11, 2015, 08:15:26 PM »
Used cams turn up here occasionally but they are often bought on eBay.  They can go for $100 or even higher sometimes. Good price is generally around 70-75 for a good cam and tach gear.
Offline DaveBarbier
« Reply #12 on: September 12, 2015, 04:28:53 AM »
If you could find one for that cheap then that would be great. I've seen them range from $120-$200 with just the cam and sprocket. Funny how much the price drops for the '83s and later. Saw $30 for both cams (DOHC) on eBay. But of course you need '79-'82.
« Reply #13 on: September 12, 2015, 10:02:13 AM »
You also need to be careful about buying a cam on eBay.  Low resolution pictures or not showing every lobe on the cam can hide a roached/pitted or overly-worn cam.  You can also get a hardweld cam for about $360 ish (Dynoman).
