Author Topic: MOVED: $500 REWARD FOR WIN TICKET ON SOHC 750 HONDA  (Read 13774 times)
Offline gschuld
Re: MOVED: $500 REWARD FOR WIN TICKET ON SOHC 750 HONDA
« Reply #100 on: February 12, 2016, 11:25:36 AM »
Heck, I have seen 7x18 ET Drag slicks on 3.5x18 wheels.  Not exactly ideal...
Lots of people seem to run the 5.5x18 on a 3.5 rim.  Frankie ran the sake slick on a 4.5x18 wheel and thought it was perfect.
Curious, how are your 60ft times?
George
Offline gschuld
« Reply #101 on: February 12, 2016, 11:26:54 AM »
George
Edit:  I thought you ran a 4.5x18 wheel with the slick Frankie?
Offline POPS 911
« Reply #102 on: February 12, 2016, 04:45:30 PM »
This swing arm has a pivot 16mm slide in bushings 1 1/2" long that you can remove = you can make two bronze inserts to your axel size 1 1/2' long. This swing arm was not made for a SOHC 750 as builder worked on many KZ and Suzuki in his shop. May be I can find a bronze boat propeller shaft at my friends scrap yard and saw off 6-10" . I will mount a flat topped 6 1/2" wide street tire that I have on a stock rear F-rim with stock disc brakes and gear all f-model and put on my 750A, make spacers and pivot inserts for 750A size bolt , always wanted to hold a left front brake on a rear wheel brake for the line lock on the two step. Stock arm F is 10 7/16" spread.
Offline POPS 911
« Reply #103 on: February 14, 2016, 06:20:21 AM »
FRANK in the 10's : Chrome moly at UPS will be in your hands soon, leaving Columbus, Monday got a tracking number. Have a few ZUKI square swing arms that you could cut up for that single shock build ..... I will measure sizes and E mail you pictures ....... more free stuff !!! V-TWIN Honda running perfect, left hand button kill foot shift , lowered, shift light, Rev limiter, small fairing, gear change ????
