Thanks Terry, that's really helpful. As I've posted elsewhere, I'm trying to put together a 550 hybrid running 750 sleeves and 64-65 mm pistons, it turns out to be a little more difficult than just putting in 836 pistons since the 750's had offset valves, and none of the SOHC's had much in the way of valve clearance. So the domes of the 650 pistons actually come above the cylinders? I would guess the the shoulders are slightly below, but even still that would mean almost zero squish...can anyone else confirm this?
