Author Topic: CB350F original jets or not  (Read 781 times)
Offline dbbrian350F
  • dbbrian350F
« on: September 13, 2015, 10:31:28 PM »
My main jets are a little beat up around the edges, so I don't think I am the first one into the carbs.
I cannot find any markings on them.  Is it supposed to be around the top rim, or in the middle section?  The top rim is rough - probably someones pliers, and the middle of the jet (the widest area) appears to be a rough casting, not smooth brass.  I trierd a little polish.
The slow jets have what appears to be a white paint stamp of the Kiehin K star and 35, which would be stock size.  But I was looking at Jetrus.com and they show a stamped embossed like symbol.  https://jetsrus.com/FAQs/FAQ_genuine_jets.html
Not sure if I am overlooking it on the main, or because they are aftermarkets jets.
Jetsrus.com appear to have the stock jets if I need them.  Do people recommend them as a Good source or are there genuine Keihin jets availanble somewhere?
Brian
« Last Edit: September 13, 2015, 10:41:19 PM by dbbrian350F »
Bound and determined to restore my...
1974 CB350F1
Lucky new custodian of...
1978 XS1100E
Re: CB350F original jets or not
« Reply #1 on: September 14, 2015, 07:01:56 AM »
as long as the ID of the jet is intact, you're ok to run it.
The mains also need a good oring around them to create a good seal.
At least get a new (viton) oring here.
Jetsrus is the go-to for many of us here.
I've had great customer service and their jets are top notch.
Offline Bodi
« Reply #2 on: September 14, 2015, 07:37:57 AM »
I have only seen OEM jets with the K and number punched into the metal: this does not prove that yours are not genuine.
The main jets I have look like this, so using pliers could mangle the lettering I suppose.
And yes, 98 was way too big for the 466'd 400F. It's running 90s now.
« Last Edit: September 14, 2015, 07:40:10 AM by Bodi »
Offline dbbrian350F
  • dbbrian350F
« Reply #3 on: September 14, 2015, 09:55:23 AM »
Thanks guys.  I'm lokking into the viton o-rings.
The picture is great, at least now I know where to look, among the mangled edge of the jet.  ::)
1974 CB350F1
1978 XS1100E
Offline dbbrian350F
  • dbbrian350F
« Reply #4 on: September 14, 2015, 05:55:47 PM »
Got the magnifying glass out (still in denial about my age, eyes not what they used to be  ::) )
I see a 75 on one, and parts of the number on the others, so looks like they are the right size at least!
Brian
1974 CB350F1
1978 XS1100E
