I also spent a little time trying to understand and find true TDC on this bike since the flywheel is installed off by one bolt. I know the proper fix is to install the flywheel correctly, butI need to prove to myself that it will run like it should first.
THEN I'll worry about fixing the flywheel.
After a lengthy discussion on the Facebook Airhead Beemers page, I got a really simple explanation from Tom Cutter of Rubber Chicken Racing. Actually, I got lots of good information during that discussion, but his was simple, straight forward and in language I could understand.
Basically, it boiled down to this:
"You can also just count 9 (nine) teeth from your known TDC point. Not the random mark you found, but the actual, verified TDC point. 9 teeth will give you a Full Advance point, at about 29-30 degrees BTDC. Mark it with a different color Wite-Out or nail polish. Start the engine, raise to 3100 RPM or so, adjust the beancan so that your new Mark shows up centered at the line in the left side of the timing hole. If the engine still runs bad, something else is bad. It could still be weak spark, clogged carb passages or a valve/ compression issue."
I found true TDC several times yesterday, mostly as a sanity check to make sure I was doing it right. Then, when my retired mechanic buddy came over I had him check my work. He agreed that we were at TRUE TDC. I also checked the valve clearances while there and they were spot on.
I also found this picture on the Internet. (This is NOT my flywheel and appears to be a severely lightened one at that.) This pic helped because A ), those are the types of markings on my flyhweel, and B ), it helped me see the actual 9 tooth count between markings.
After finding true TDC, I marked a tooth on the flyhweel with a yellow paint pen and the counted down nine teeth. I counted at least three times, going in both directions. It turns out that the white paint mark that I WAS seeing, the one that someone before me added, was only seven teeth from TDC.
If that's the case, and if I understand this correctly, my timing is in fact advanced too much. And with dual plug heads it should be retarded by 3 degrees or so, correct? The old, previous white paint mark is getting to the center of the timing window by 2,000 - 2,500 RPM. The REAL full advance mark is still two teeth down and should be in the window at 3,100 rpm.
This, too, could be affecting the mid-range, no?
