Author Topic: how to port 500/550 four cylinder head?  (Read 8952 times)
Offline kranta
  • honda cb 250RS 1981 CAFE & honda cb 500 four 1978.
« on: September 16, 2015, 11:41:20 AM »
so, i was thinking to do mild porting to my cb 500 four and i havent done it before so, how i get muchest power from porting? and should i take every irregularities out and which kinda spots i should take? and how i know that in every intake holes have same kinda porting? and what tools i should use? should i use sand paper or tremel ?
sorry about bad english!
Offline Powderman
Re: how to port 500/550 four cylinder head?
« Reply #1 on: September 16, 2015, 11:48:20 AM »
Porting is not something that can be accomplished by the average DIYer. You can seriously destroy your head if not done correctly. There's an art and a science to porting for gains.
« Reply #2 on: September 16, 2015, 12:03:26 PM »
Yep.
Offline jeffg
« Reply #3 on: September 16, 2015, 01:19:23 PM »
I have done porting, sure it is true you can damage things, but you can also do a good job yourself.
their are basically 3 stages:
1 Polish
2 case match, casting flaws.
3 reliving areas that are unneeded to create more flow.
case match:
 is, in my opinion easy. All your going to do is cut, grind casting flaws, and case mis match. With a careful eye it is, this is easy to spot.
polish is pretty easy as well, you can buy a bit kit from summit racing for polish.
I had a 1/8 pneumatic grinder from harbor freight worked great. I had carbide bits for the die grinder from northern tools.
It is a very noticeable power difference to complete case match, casting flaws, & polish.
I always did it on my dirt bikes, and once on a v8 408 stocker motor I built.
If I do a cb750 - 836, someday which I expect I will I will definitely do a stage 3 port polish.
Cutting can go bad because if you go to far you will go through a jacket!
keep In mind when going to 1 extreme, usually requires additional tasks, lumpy cam, pods,...
« Last Edit: September 16, 2015, 01:23:38 PM by jeffg »
Offline Powderman
« Reply #4 on: September 16, 2015, 03:43:52 PM »
1 Polish
case match:
The art of porting is knowing what "areas are unneeded to create more flow." Most of us have no clue what those areas are or how much to take away. Take away too much and you create less flow, slower flow, etc. none of which will improve performance.
Offline calj737
  • I refuse...
« Reply #5 on: September 16, 2015, 05:35:43 PM »
The best way for you to do it, is to take the head to a professional and let him do it. You can polish the ports, but reshaping or grinding them is best left to pros. If you do modify the shape, volume or size of a port and it is not exactly equal to the others, you will never get a balanced vacuum reading across all cylinders.
Can you do it? Unlikely. Should you do it? Nope. But feel free to pursue which ever path you choose.
« Reply #6 on: September 16, 2015, 06:30:14 PM »
It's not just about maximizing flow, but as much about getting the right flow pattern according to what Mike has told me. Some things are probably better left to pros.
« Reply #7 on: September 16, 2015, 08:17:11 PM »
I really have not inspected 500/550's ports, so I don't know what they really need, but if they are anything like a K1 or later CB750, all you have to do is take a peek down the ports, think about airflow, and you will see why these ports are garbage from the factory.  CB750 ports are often so bad, that as long as you are careful, don't expect huge power gains, even a clumsy child with a piece of 80 grit(that would be me) can't eff 'em up any worse.  Get Hondaman's book, go slow, just clean up the major problems(there are plenty), and don't surface finish the intakes too smooth.  Obviously, pros like Mike R. are gonna get better results, but he is also gonna make you pay for his experience, as well he should...
An easy thing to do to help visualize basic airflow/fluid dynamics...get a clear hose for your shop vac and a big pile of sawdust...
« Reply #8 on: September 16, 2015, 08:26:48 PM »
HondaMan has some guidance on the forums about it and there is one thread where a fellow did HondaMan's recommended mods.  I don't have the links handy. Search might yield results.
HondaMan also takes on work rebuilding motors and mild/moderate head work.
MRiech does it for a living and knows how to yield excellent results.
If you give it to someone,  then they need to have experience with the Honda CB heads.
Offline camelman
  • Man... Myth... Legend
« Reply #9 on: September 16, 2015, 09:14:48 PM »
I ported the head on my 350f and it made an unbelievable difference. I went from downshifting going up a particular hill at 60MPH just to maintain speed with only me on the bike to staying in top gear and accelerating up that same hill with a passenger. I had never ported a head before, but spent a few weeks reading all of the articles I could find online. I ended up using a Dremel tool with sanding drums as well as some flapper wheels. Take your time, think it through, and CLEAN it up when you are done.
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Offline calj737
  • I refuse...
« Reply #10 on: September 17, 2015, 03:55:01 AM »
...even a clumsy child with a piece of 80 grit(that would be me) can't eff 'em up any worse.
Here's proof of your clumsy child notion... Scroll down a bit to the pictures of his ports.
http://forums.sohc4.net/index.php/topic,150258.50.html
« Reply #11 on: September 17, 2015, 04:24:29 AM »
Cal, or anyone else for that matter, do you have any pics of an unmodified 500/550 port?...because if they are as bad as a 750 port, the pictures from the linked thread are probably better than stock.
Offline calj737
  • I refuse...
« Reply #12 on: September 17, 2015, 04:33:24 AM »
the ports on that linked thread are destroyed by a knucklehead with a dremel. They are not even close to equal in shape or volume, off center to the intakes, and way over-worked! That head is now worthy only as a piece of alloy scrap. A new head has been substituted and a professional will do some tuning and polishing on the ports.
Are stock ports on these motors poor and very restrictive? Sure. But that doesn't mean anyone with a Dremel and an outlet should take to them. Polish them up, sounds fine. But grind on them and reshape them? I wouldn't go near it. And seat of the pants dyno results are anecdotal horse hockey in my book.
« Reply #13 on: September 17, 2015, 03:16:47 PM »
well alright then! so this must prove that the only way to improve performance is to spend thousands of dollars and don't bother trying to learn anything because someone else collecting those dollars already knows far more than you...and I agree the butt dyno definitely does not work, especially when your butt is not seated on the seat, going down the road
Offline calj737
  • I refuse...
« Reply #14 on: September 17, 2015, 04:10:27 PM »
Thousands of dollars? I spent a fraction of that for Mike Rieck to do a Stage III job on my head. If I recall, that work was about $300 for porting. Far less than the danger of screwing up a critical component, don't you think?
You're not only mistaken about the cost, but you're insinuation that someone can become "self taught" to improve the fluid dynamics of cast piece with hand tools and no instruments, no flow bench, no dyno is absurd. Experience in porting is the result of proper education, proper tools, and lots of success. You think you or the OP can achieve that by the glow of a shop light with a stool and a Dremel? You must be exceptional. I tip my hat to you.
« Reply #15 on: September 17, 2015, 04:45:33 PM »
Yeah , your right.  I promise to give up learning new skills and will just throw money at all of life's challenges from now on.
« Reply #16 on: September 17, 2015, 05:26:12 PM »
Sean, what Cal is trying to say is that without the knowledge, the trial and error method is born to fail many times, thats why experst do the investigative work using flow benches, unless you are just cleaning up the ports, poor castings and the like, not many people I know have an "accurate eye " or know how to measure accurately a port and combustion chamber, Jeffg said "polish" the ports, thats completely wrong for the inlet side of the head, you should only ever polish the exhaust ports, the inlet ports need a rougher surface to correctly atomize the fuel. correct porting is quite a complexed thing to do and a very easy thing to completely screw up, cleaning up the ports isn't porting as such,  and is far easier to do.... ;)
« Reply #17 on: September 17, 2015, 05:57:31 PM »
There are some skills I'd like to develop. This is one that I'm out of my depth on tools-wise and knowledge-wise.
« Reply #18 on: September 17, 2015, 06:03:20 PM »
this is all I am really saying....with the added caveats that cb750 ports got a LOT of stuff that obviously needs cleaning up(still hoping someone would post some pictures of stock 550 ports.  perhaps they are not as bad as the middle year cb750 ports and thus easier to "ruin"), and I am positive that M. Rieck was not born with a die grinder in hand turning out 90 hp sohc4 mills.
I never said anything about polishing the intake ports and agree it is generally a bad idea
I also never said anything about diving in head first with a die grinder and the biggest carbide burr that fits to create a huge pile of aluminum swarf without doing any research...and if someone would actually look into a cb750 port and note the factory port match "swipe" that was done, at the factory, along with fairly massive amounts of casting flash, and think about it for  a few seconds, they might realize that, with a few specialized tools and quite a bit of care and time, this should be able to be improved substantially
and if a stage 3 port job from Mike R. is really only $300...well...that is just crazy
« Reply #19 on: September 17, 2015, 06:04:19 PM »
I have a friend that ports performance car engine heads, he spends a lot of time making templates {changing external port shape on inlet and exhaust}  and fluid measuring, I watched him port my Old SLR holden V8 heads, he took about a cup of metal out of each head, they were a work of art and made a huge difference to the cars performance, {ask the gearbox}  ... :o ;D
« Reply #20 on: September 17, 2015, 06:07:33 PM »
Cool, and I agree with what you are saying about cleaning up the casting rubbish, still, someone will screw it up, its inevitable... ;D :o, I threw the polished bit in as there is still a lot of misinformation and opinion on what works best.  ;) I think the $300 is just for port work, nothing else, No valves, seals, guides etc.... ;)
« Reply #21 on: September 17, 2015, 07:39:08 PM »
Hey C-man, didn't you put together a make-shift flow bench so you could compare relative flow before and after? I also seem to recall a major core-shift issue with one port?
Offline flatlander
« Reply #22 on: September 17, 2015, 11:22:12 PM »
i have pics here but they are not great. they don't show enough to really understand what's going on but may be better than nothing.
and after mike had a go at them:
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #23 on: September 18, 2015, 01:05:51 AM »
those look nice.
not that you'll ever see that work at work on the road.
covered by manifolds and all :D
Offline flatlander
« Reply #24 on: September 18, 2015, 01:45:41 AM »
transparent head and manifolds and exhaust headers would be a good idea to show off the work. until then these things stay the internal secret of the engine ;)
