Author Topic: how to port 500/550 four cylinder head?  (Read 8958 times)
Offline Trad
Re: how to port 500/550 four cylinder head?
« Reply #75 on: September 21, 2015, 08:06:42 PM »
Cal, go back and read the article you linked. Does it say other mods need to be made for porting to increase power? No, it does not. Speaking of numbers, that article stated that for every 1 CFM in increased flow, that cylinder would have an increase of .255 HP. Looking at the graph from the old Branch article shows an increase of about 9 CFM at a lift of .300", with the stock carb, which would add up to 9.18 HP.
I just re-read the article. You are correct my friend! Porting alone will yield noticeable gains! 9.18 HP is pretty impressive. It will obviously be further increased with additional performance mods. (hotter cam, higher compression pistons, oversized valves). After reading that again I'm fairly confident that a stock engine with a correctly ported head would yell noticeable gains on a SOHC4. I want someone to actually Dyno this.  :P
74 CB550 Build: NOS-GUTTED-OEMplus-HOLDTRUE
http://forums.sohc4.net/index.php/topic,130575.0.html
Offline calj737
  • I refuse...
« Reply #76 on: September 22, 2015, 03:50:25 AM »
What it clearly says, is that to achieve superior performance gains, porting in conjunction with camshaft modifications and valve sizes and exhaust tuning is required. This is the only point I've made repeatedly. I have not said that porting isn't important, nor that it's the basis of improvement, I have only said that as a single, standalone modification, it can not itself produce significant gains.
I didn't write the article, so I have no idea of the 0.255HP is a constant across all internal combustion engines, but in speaking with numerous engine builders over the past years, and as recently as yesterday specifically about this topic, porting modifications can only yield these gains if the rest of the system (exhaust for instance) can scavenge the added air flow. The volume of the cylinder is the volume, regardless of how quickly you fill it. Combust it, then you must expel it and scavenge it. Therefore, absent of an exhaust modification (which this article does address in terms of balance) you can not get the power out of the engine.
I'm unfamiliar with the "Branch graph" but I do know that the stock 500 cam (which is the motor the OP is running) has a lift of around .270. So I think we are measuring apples and oranges in terms of potential HP gains out of a single, given motor.
As I said when I linked that article, I found it very educational and it along with other research and dialogue with engine builders had formed my position that porting alone (especially on our primitive engines) is insufficient to produce significant HP gains. I did not cite that article is a verbatim of my opinion.
I feel like we've kicked this dead horse enough. I am in disagreement with someone's posted claims about the significant performance gains he derived on his 350 from simply porting. If you want to PM me and educate me, I am happy to benefit from your knowledge. But I have created too acrimonious a distraction in this thread for my participation or opinion to beneficial. Don't you think?
