Author Topic: So what keeps killin my bike?  (Read 7078 times)
Offline CBGBs
    • Ride or Rot vintage motorcycle event in FTW
« on: October 29, 2006, 06:33:54 PM »
Long story, short.
My twin blew a piston. Popped a hole right in the center of the right piston. I was ridding two-up on a 90 plus degree day on a long highway. This is tough for a 350 I know, but she should be good for it. I gradually lost power until I was giving it full throttle to maintain 50mph and then it stopped. Blown piston.
So I checked it out and decided to leave it to the pro's. Bored with .030 over slugs, ported intake and exhaust, slight mill of the head and back in the bike it goes. This time with upgraded carbs (cb500t), electronic ignition and fresh filters.
The bike did well until one day about fewer than 1000 miles later on a nice 80+ degree day when it happened again only it was more subtle. I lost the left piston this time.
What do you think happened?
'66 CB77 Superhawk  '73 CB350G Cafe  '75 CB400F '65 S90  '78 CB750 SS
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
Re: So what keeps killin my bike?
« Reply #1 on: October 29, 2006, 07:57:34 PM »
Stock airbox? Stock exhaust? Sounds like it was running a bit lean. That + ambient air temperature??
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
Offline mrbreeze
  • Not your average
« Reply #2 on: October 29, 2006, 08:13:04 PM »
Yup...more likely than not runnin lean.
MEMBER # 257
Offline Green550F
  • Nothing is as cool as that which you made.
« Reply #3 on: October 29, 2006, 10:04:51 PM »
had a snowmobile ddi it to me. if you think it sucks, try walking home when it's 20 degrees out!
the sled had broken a ring, leaned out a cyl, melted a hole through the piston, fused the wrist pin to the piston too. actually had to cut the piston in half to replace it!
93 Kawasaki Voyager XII
70 Honda CL350 Cafe
Offline kghost
« Reply #4 on: October 29, 2006, 10:15:46 PM »
I think it sounds like detonatation.
Maybe your working that poor 350 a little too much.  ;D
Stranger in a strange land
Offline mrbreeze
  • Not your average
« Reply #5 on: October 29, 2006, 10:28:57 PM »
A few years back,I walked 2 miles home in Wyoming.....winter,11pm.....when I got home it was straight up 0 degrees....can you say Frosty the F%$n Snowman?????
MEMBER # 257
Offline CBGBs
« Reply #6 on: October 30, 2006, 02:59:34 AM »
The first incident was with stock airbox, the second was with foam filters. Both incidents with stock exhaust.
I kept the carbs clean, adjusted the jetting, checked my diaphrams :P, and used filters on the fuel lines. Valves were adjusted. Why would it do this to me twice. :(
« Last Edit: October 30, 2006, 03:05:08 AM by CBGBs »
Offline crazypj
  • I'm brill, me
« Reply #7 on: October 30, 2006, 08:01:42 AM »
It switched sides so it may well be that the ignition timing is out on the side that died?
It wont need to be far out if your putting motor under a reasonable amount of stress, particularly if carburation is either spot on or slighty lean.
Go up a size on main jet to be on safe side.
PJ
Offline kghost
« Reply #8 on: October 30, 2006, 10:19:47 AM »
Knocking (also called pinking or pinging)—technically detonation—in internal combustion engines occurs when fuel/air mixture in the cylinder has been ignited by the spark plug and the smooth burning is interrupted by the unburned mixture in the combustion chamber exploding before the flame front can reach it. Combusting stops suddenly, because of the explosion, before the optimum moment of the four-stroke cycle. The resulting shockwave reverberates in the combustion chamber and pressures increase catastrophically, creating a characteristic metallic "pinging" sound.
The fuel/air mixture is normally ignited slightly before the point of maximum compression to allow a small time for the flame-front of the burning fuel to expand throughout the mixture so that maximum pressure occurs at the optimum point. The flame-front moves at roughly 33.5 m/second (110 feet/second) during normal combustion. It is only when the remaining unburned mixture is heated and pressurized by the advancing flame front for a certain length of time that the detonation occurs. It is caused by an instantaneous ignition of the remaining fuel/air mixture in the form of an explosion. The cylinder pressure rises dramatically beyond design limits. If allowed to persist detonation will damage or destroy engine parts.
Detonation can be prevented by:
The use of a fuel with higher octane rating
The addition of octane-increasing "lead," isooctane, or other fuel additives.
Increasing the amount of fuel injected/inducted (resulting in lower Air to Fuel Ratio)
Reduction of cylinder pressure by increasing the engine revolutions (lower gear), decreasing the manifold pressure (throttle opening) or reducing the load on the engine, or any combination.
Reduction of charge (in-cylinder) temperatures (such as through cooling, water injection or compression ratio reduction).
Retardation of spark plug ignition.
Improved combustion chamber design that concentrates mixture near the spark plug and generates high turbulence to promote fast even burning.
Use of a spark plug of colder heat range in cases where the spark plug insulator has become a source of pre-ignition leading to detonation
As you can see above......
The leading causes of detonation are : incorrect timing (too advanced), Lean mixture (carburation), Over loading, and incorrect Spark plug (too cold a heat range).
When detonation occurs temps and pressures in the cylinder rise dramatically. This causes hot spots to develope on the piston. The aluminum piston does not require much heating beyond its normal operating range before the metallurgy of the piston is affected.
When this happens the piston loses its "temper" and will melt. Aluminum pistons are manufactured from alloyed and heat treated materials and once you over heat them this is lost.
Riding two up at highway speed (60-70mph) up and down hills on a 350 sounds to me like a sure way to overwork the engine leading to detonation.
Offline CBGBs
« Reply #9 on: October 31, 2006, 03:08:33 AM »
Yes, my engine does ping. It always has and no matter what I have done to affect this it has always been present. I have tried higher octane, larger jets, larger carbs I have tried adjusting the timing to varying degrees. I use stock plugs. The engine was likely knocking both times it blew. The bike would often ping "off the line" when riding.
I am frustrated with this problem. :(
Offline mrbreeze
  • Not your average
« Reply #10 on: October 31, 2006, 07:06:59 PM »
If you don't find whats wrong and fix it soon....you're gonna be more than frustrated!!!! Can you say cooked aluminum?
MEMBER # 257
Offline CBGBs
« Reply #11 on: November 01, 2006, 02:43:31 AM »
I've said "cooked aluminum " twice already. Twice in 6000 miles. :-[
Brunow
« Reply #12 on: November 01, 2006, 08:48:59 AM »
Can you check it? Drive up a hill in a heavy gear (4th?)
If you hear your cilinder "ping tingeling ing ing ing..." turn your bike off.
You may have mutch work to do  :-\
nice post kghost!
Offline dusterdude
« Reply #13 on: November 01, 2006, 10:23:19 AM »
you might try 1 step colder plug too.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline kghost
« Reply #14 on: November 01, 2006, 01:15:21 PM »
Ummm....wouldn't recommend that as that can be one of the factors causing detonation.....
Offline dusterdude
« Reply #15 on: November 01, 2006, 01:49:16 PM »
really?
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
« Reply #16 on: November 01, 2006, 05:04:00 PM »
I hate to say it but maybe you need a bigger bike if you are going to run at high speeds for long strecthes . Engines that are running really hot will PING. . They are kinda around town bikes. I know it is a downer but maybe a 500 or 750 be better suited.
« Reply #17 on: November 01, 2006, 08:58:31 PM »
Who's a silly Timothy ;D ;D ;D ;D....you already did recommend it in your super detailed post ::) ::) ::)
Now say sorry to Dusty ;D ;D ;D ;D ;D ;D ;D ;D
Sam.  ;)
Offline kghost
« Reply #18 on: November 01, 2006, 09:04:17 PM »
Sam.  ;)
 ;D yes ... I did....but I think he skipped that part....... ;D
« Reply #19 on: November 02, 2006, 06:05:45 PM »
Offline CBGBs
« Reply #20 on: November 02, 2006, 06:46:06 PM »
Hey , hey!!!!! back on track! This is serious! My bike is in serious surgery right now and I'm not sure that I have a cure. I know the bike is small, but it is a champ when its runnin good and I love the bike.
My goal is to hit a ton on it. I really think I can. :o
« Reply #21 on: November 02, 2006, 07:05:49 PM »
Harder/colder plugs, not sure what caused it the first time but remember, youv'e had the head milled raising the compession.
Higher comprssion = heat, you need plugs that can withstand the heat.
Go up two sizes, if it makes it to hard to start, come down one.
Sam.
Offline CBGBs
« Reply #22 on: November 04, 2006, 05:03:25 AM »
My plan so far is to rebuild the petcock and make sure it is flowing well. I've also considered using a single spout aftermarket piece from sirius consolidated SCI just because I've noticed some random flow problems(?). I will make sure the carb boots are not overly tight on the head causing a leak when the engine is very hot.
Ill try colder plugs but I have little faith any of these will really solve it.  This will be a winter project. I've been too buisy lately to do anything but purchase a Mac 2 into 1 exhaust that should be here any day.
The bike actually pinged less after the head was milled and I was using the CB500T carbs. but instead of pinging at cruising speed, it would usually ping a little off the line.
This bike must hit 100mph. ;D
phylo101
« Reply #23 on: December 12, 2006, 07:12:26 PM »
the G's were known for "pinking"; that and the cam lubrication issue were two of their worse points. BUT they were also known for very imprecise timing and the alloy points plate warping, especially if they were overheating anyway! Very easy for the timing to go out. And as 90mph is right up at the very edge of the twin's performance envelope the pin was out of the grenade and it was smoking anyway......
Offline crazypj
  • I'm brill, me
« Reply #24 on: December 13, 2006, 07:21:19 AM »
yes you can, but you'll have to be wrapped around the tank or find a long downhill (or both ;D)
They are also very susceptible to fuel level changes. (as little as 1 gallon used makes a difference at full throttle)
 When it drops they run lean so make sure you keep it topped right up or change to Mikuni carbs which don't seem to have the same problem as stock Kei-Hin
PJ
