Author Topic: Maduncle has FINALLY got himself a CB750K  (Read 35639 times)
Re: Maduncle has FINALLY got himself a CB750K
« Reply #75 on: December 01, 2015, 02:41:42 PM »
I wonder how that side stand will go with all the weight back in the bike, it looks like it's standing as a completed bike should now...?
Offline maduncle
  • Don't confuse me with a
« Reply #76 on: December 02, 2015, 02:09:32 AM »
Should have seen the lean on it with the 2" shorter stock CB750 side stand.
I am hoping this is better, not sure if engine weight would add to the lean or settle it down a little and decrease the lean. Anyway - I can always go back to the stock one if I have to.
CB750K2 (only slightly modified)
« Reply #77 on: December 02, 2015, 02:38:22 AM »
It's leaning over further because of the extra long Koni shocks, by installing them, you've raised the frame an inch or so. The longer sidestand will do the job, or else put some shorter shockers on it. Cheers, Terry. ;D
Offline maduncle
« Reply #78 on: December 02, 2015, 02:48:29 AM »
Thanks Terry - I figured it was the rear shocks causing the extra lean, love these shocks so they are staying on.
(PS - message sent).
« Reply #79 on: December 02, 2015, 03:17:49 AM »
No worries, I'm in Sydney this weekend Cliff, but I'll have a look for that clutch part when I get back to Melbourne on the following weekend. Cheers, Terry.
Offline maduncle
« Reply #80 on: December 02, 2015, 03:33:45 AM »
Thanks!
« Reply #81 on: December 02, 2015, 03:42:53 AM »
I like the DOHC stand, less chance of sinking in softer ground..
Offline Restoration Fan
  • My wife will never call me
« Reply #82 on: December 02, 2015, 04:02:37 AM »
Yep, I ran BT45's on just about every bike over the last 20 years and they're brilliant, but I've recently fallen in love again with Pirelli tyres Scunny, I've got Sport Demons on my BMW K100RS and Yamaha FJ1200, and Scorpions on my Honda XR500R, and they've just changed the way those bikes handle. TT100's are only good for "necklacing" public servants........ ;D
I'm running Sport Demons on my 750 and I have been really pleased with them as well.
Offline maduncle
« Reply #83 on: December 12, 2015, 07:12:25 PM »
Whilst I wait for my boring and honing I am also designing.
Can somebody please tell me if there is any difference between a CB750K and CB750F1 front hub?
Or otherwise - how can I bolt a disc to each side of a CB750K hub and keep the speedo drive?
« Reply #84 on: December 12, 2015, 08:00:21 PM »
Twin disc and speedo drive is easy Cliff, I'll post a link... ;)
http://forums.sohc4.net/index.php?topic=53532.0
Offline maduncle
« Reply #85 on: December 13, 2015, 01:14:13 AM »
Thanks!
The disc will be Ducati Monster discs though - and Brembo calipers.
« Reply #86 on: December 13, 2015, 01:57:25 AM »
Thanks!
Hmmm, you will just have to get creative mate... ;D ;)  I'm trying to work out a similar problem using different wheels..  ;)
Offline Godffery
  • Godffery's Garage
« Reply #87 on: December 13, 2015, 09:04:54 AM »
Offline maduncle
« Reply #88 on: February 02, 2016, 05:46:13 PM »
Long time between posts I know - but I only work on this bike when money permits and that ain't often.
But I did pick this tank up the other day.
I just bought it for the cool old 70's airbrushed art, but now I look under the tank I think it might be an early one.
Can someone tell me what model CB750 this tank is off by these photos?
« Reply #89 on: February 02, 2016, 05:57:49 PM »
rh side dual outlet petcock makes it k4 or earlier... those are not the wrinkles of wrinkle tank fame.  "Wrinkle tank" has em farther forward on the tunnel so that you will see the wrinkles looking into the tank with the cap open.  So all I can tell ya is late K0-k4
« Reply #90 on: February 02, 2016, 07:15:06 PM »
Yep, what Sean said Cliff, we didn't get K3 or K4 CB750's officially imported to Oz so it'll be late K0 to K2. Cheers, Terry. ;D
Offline maduncle
« Reply #91 on: February 03, 2016, 02:00:20 AM »
Thanks Sam and Terry - I am uninitiated the ways of the ripple so when I saw them I thought "ooohhhhhh".
Still, it will come in handy one day, particularly if I am feeling a little hoarse.
« Reply #92 on: February 04, 2016, 03:02:07 PM »
 :) LOL, I see what you did there!
Offline maduncle
« Reply #93 on: February 06, 2016, 11:37:07 PM »
FINALLY!
After waiting fifteen weeks, six hours and twelve minutes - I got my barrels with new bored out sleeves back from the engineer.
This means I can now take all of the engine parts up to the engine builder and get the thing put together for my bike.
I am a bit over the whole "sitting on a rolling frame and making vroom vroom noises" bit. So I think I may actually have a bike on the road in around 8 weeks.
Offline maduncle
« Reply #94 on: March 09, 2016, 02:52:16 AM »
Okay - so five weeks in and the engine is almost ready. I needed to get one or two small parts (such as more bearing retainer clips) before the bottom end could restitched together, but now is getting there.
Just out of curiosity - what other carbs can go on a CB750 (well 836) without buying CR's? Is there a bank of Mikuni's that fit, or a set off another model bike that improves performance?
« Reply #95 on: March 09, 2016, 03:51:20 AM »
I'm using the same Carbs Terry had on his gold 750, 34mmCV's off a cbx750, they aren't an exact match but can be made to fit with a little persuasion, you'll still have to jet them to suit......
« Reply #96 on: March 09, 2016, 06:00:38 AM »
Mikuni RS34s fit but that's a lot of carb - meaning it's well suited for a higher performance motor.
« Reply #97 on: March 09, 2016, 02:33:14 PM »
there are adapter boots out there for Mikuni vm26, vm28, and vm29 smoothbore all from Kawasaki Z1/Z1000.  Generally speaking, the stock carbs are not a restriction until you have done quite a bit of cylinder head work, regardless of displacement.
« Reply #98 on: March 09, 2016, 04:12:22 PM »
I've got a very nice set of new CR31's here Cliff, going cheap...... ;D
Offline maduncle
« Reply #99 on: March 10, 2016, 07:39:14 PM »
hahahahahaha -
Next year mate.
