Author Topic: Tapered Steering Bearings Thread  (Read 261359 times)
Offline dagersh
    • Photos
Re: tappered steering bearings for 71 cb750
« Reply #100 on: April 18, 2007, 04:43:57 PM »
Check out Z1 Enterprises, they have a great following in this forum.  Call them direct if you have questions.
Good Luck.
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB450/500 Custom
1972 CB500K1
1975 CB550F
1976 CB400F
1975 CB750 Future Restoration
1976 CB750K6
1976 CB750F
1976 GL1000
1968 Suzuki T500 Cobra
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline .RJ
  • homebase in your airspace
« Reply #101 on: April 18, 2007, 05:02:23 PM »
I just ordered a set from bikebandit, the listing only goes back to 1976 - the allballs website showed the same part numbers for both '71 and '76 for the steering bearing kit.
Offline hymodyne
« Reply #102 on: April 18, 2007, 06:27:40 PM »
if they're the same as the ones for the cb 500/550K, I've got a new set I'll sell you cheap. pro-flo finally sent my order, three weeks later, after I'd already given up due to an inability to contact or get a response from them. they're all balls and haven't been opened.
pm me if they will fit.
hym
kgreb
« Reply #103 on: April 19, 2007, 09:30:22 AM »
I bought mine from "PartsnMore" in Canada. I have the same bike and they went in fine. I haven't finished putting the bike together yet, so I can't say how they perform but the installation was easy.
kgreb
Offline Jinxracing
  • It's hot shit, not
  • '70 CB750 K1
    • The Hairy Nickel
« Reply #104 on: April 19, 2007, 12:17:38 PM »
I got mine from All Balls for my '70 CB750 K1. Worked great, good instructions, nice dust seal too.
–Captain Horatio Hornblower
www.thehairynickel.com
Offline original
« Reply #105 on: April 19, 2007, 12:27:16 PM »
hey, thanks for the input, i just ordered the all balls kit from the local harley dealer and they were priced to bad, $45 us.
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
Looking For Tapered Steering Bearings For CB77, Will CB350 or Others Work?
« Reply #106 on: April 24, 2007, 08:54:53 PM »
          Looking For tapered roller bearings for the steering of my CB77 305 Super Hawk. Anybody know if there is another model (like CB350) that will work? Or at least, where I can get some bearings? I don't remember seeing them listed on ebay, that I know of. Any input appreciated.
                                                 Thanks,  Bill :) ;)
Member # 1969
Offline hahnda
  • lskdfhs;dljksa;
I know the inner bearing diameter is the same as a CB350. Which means it would be easy to swap in a CB350 front end. I think the outer is the same also. Would have to measure to be sure. Can do tonite if I remember. If both inner and outer are the same I see no reason one couldn't use the CB350 sized bearings.
Kevin
CB750K4 in pieces
CB750K3 with F trim
CB750K7
CB500 Cafe Project
CB750 Cafe
Offline bill440cars
          Thanks Kevin,
                        That would be a big help. I'd sure like to update the old Super Hawk as much as possible without totally changing the bikes style, you know? ??? I want the best handling I can get without spending a fortune on it too. :-\  When you get a chance and happen to think of it, I'd appreciate the info. Thanks again. ;)
                                               Later on, Bill :) ;)
Member # 1969
TedT
I'm trying to remember the model of the ones I put on my stalled 305 Scrambler project.  I was using different triple trees, but I seem to remember something from a 70's Suzuki fitting just fine.
Offline bill440cars
           Hey Ted,
                 Appreciate the thoughts and all. If you do remember the details, I'd be appreciating any and all info on the subject. ;)
« Last Edit: April 27, 2007, 08:56:53 AM by bill440cars »
Member # 1969
TedT
I do remember that the thing I did was to measure both the inner and outer diameter, and I remember I went through All Balls Racing to get the tapered bearings.  I still don't remember what bike they wound up coming from-can I claim CRS Syndrome at 26?
Here's the site I went through though, if you can get the ID and OD they should have something for you:
http://www.allballsracing.com/dealer_tools.asp
Offline bill440cars
                Well, if Kevin's measurements of the 305 and 350 bearings match up, then I'm in business! ;)
                I did some checking at the ALL BALLS site, with that link that Ted left and it appears that the bearings that fit the CB350 also fit the 350F, 400F, CB/CL450 K1-K7, CB500T, CB500, CB550K/F, & CB650. So, even if I take a chance and get a set, it'll be used if it fits the Super Hawk or not. Now, I'd like to find out how much this will cost me too! Didn't see any way to determine that on that site. Did I overlook something?  P/N is 22-1011  Thanks for the info guys. ;)
Member # 1969
Offline hahnda
  • lskdfhs;dljksa;
I measured last night and you should be in business. Bearings match up to what you see below. Same part number that you listed earlier for All Balls.
Check out http://www.pro-flo.com to buy or even your local bike shop can get them through a Parts Unlimited catalog.
Upper: 26 x 48.5 x 15.2
Lower: 30 x 50 x 14.4
Honda   C250N (79)
Honda   CB250 (Early Models)
Honda   CB250RS (80-84)
Honda   CBX250RS
Honda   CM250T Rebel (82-84)
Honda   GB250F/F2
Honda   MVX250 (83-84)
Honda   VT250F (83-86), VTR250 (88)
Honda   CB350F/F1 (73-74), CB350G (73), CB350/ K2-K4 (69-72)
Honda   SL350 /K2/K3 (69-73)
Honda   CB360 (74-76), CB360GT (76), CB360T (74-77)
Honda   CJ360T (76-77), CL360 (74-75)
Honda   CB400A (74-75), CB400F (75-77), CB400TI/TII (78-79), CB400T (80-81)
Honda   CBX400F
Honda   CM400A/C/E/T (79-81)
Honda   GB400
Honda   CB450/K1-K7 (65-74), CB450T (82), CB450SC (82-86)
Honda   CL450 /K2-K6 (68-74)
Honda   CM450A/C/E (82-83)
Honda   CB500/K1/K2 (71-73), CB500T (75-76)
Honda   CX500 C/D (78-81)
Honda   FT500 Ascot (82-83)
Honda   GB500F/F2
Honda   GL500/I (81-82)
Honda   VT500 Ascot (83-84), VT500ED, VT500C/FT (83-84)
Honda   CB550K/K1 (74-78), CB550F (75-77), CB550SC (83)
Honda   CBX550F (82-83)
Honda   CB650 (79-82), CB650C (80-81), CB650SC (82-85), CBX650ED/SCD
Honda   CX650C (83), CX650ED
Honda   GL650/I (83)
Honda   VT700C (84-85)
Honda   CB750K (69-78), CB750A (76-78), CB750F (75-78)
Honda   VFR750C (83)
Honda   VT750C (83)
Honda   GL1000 (75-76)
Honda   GL1000L (76)
Kevin
CB750K4 in pieces
CB750K3 with F trim
CB750K7
CB500 Cafe Project
CB750 Cafe
Offline bill440cars
                   Thanks for that Kevin. ;) Sure appreciate having you to provide info like that, when I need it too. I don't mean to say that I don't appreciate others that provide info either. As time goes on, I (like others I'm sure) am learning about which members are more apt to know particular bits of needed info. If you think about it, there is a massive amount of info available here on this site and I feel privileged to have access to it. ;)
Member # 1969
Offline Green550F
  • Nothing is as cool as that which you made.
Cost on those will be right around th $40 mark.
93 Kawasaki Voyager XII
70 Honda CL350 Cafe
LRSDTIM
HELP! Removing tapered bearing race
« Reply #116 on: June 08, 2007, 11:27:54 AM »
A month ago I installed tapered bearings on my 350F and I appear to have botched the job somewhat. The bottom bearing rusted and froze up nearly causing me to eat the back of a taxi cab. I installed the bearings on the stem correctly at least from looking at other threads here I did. First the thick washer from the all balls kit and then the seal and then the bearing. I'm not sure what caused the rust but I'd like to get the bottom race out of the head so I can clean the heck out of it and install a new set of bearings. The old races stuck out slightly and I was able to get them out with a hammer and punch. These are so flush and so tight I haven't been able to get any sort of purchase on them. The top bearing and race appear to be fine by the way. Here are some pictures of what the bottom bearings looked like when I removed them and the bottom race that I would like to remove. Any ideas?
Offline Jinxracing
  • '70 CB750 K1
    • The Hairy Nickel
Re: HELP! Removing tapered bearing race
« Reply #117 on: June 08, 2007, 11:34:22 AM »
Those photos make it look as though you installed the bearings without packing them with grease first. If that's what happened I'm sure you'd get some fast rusting.
LRSDTIM
« Reply #118 on: June 08, 2007, 11:39:00 AM »
You are correct and I won't make that mistake again. Do you think it's necesarry to remove the lower race? Would wire brushing the rust out and packing grease in be sufficient?
Offline Jinxracing
  • '70 CB750 K1
    • The Hairy Nickel
« Reply #119 on: June 08, 2007, 11:45:28 AM »
Those are precision-ground surfaces for a reason; any sort of defect in the surface can show up in how they feel when you turn the bars. If it were my bike I'd just chalk it up to a learning experience and definitely replace the bearings.
If you can't get purchase on the races from the back side, you're going to have to get creative. I'm trying to think of a way to pull them out from the "front side" and so far I'm not coming up with any (reasonable) solutions.  Drilling is probably out due to the hardness of the race material. Hopefully a member with more experience will chime in on this one.
LRSDTIM
« Reply #120 on: June 08, 2007, 11:53:39 AM »
Definitely a learning experience and fortunately not a terribly expensive one. Replacing the bearings is my only option and yeah I didn't really think brushing out the rust was a fantastic idea but you never know. I hadn't considered drilling into the race, I may have the tools to accomplish this.
Offline clarkjh
  • Expert? If only.
  • Surely and Samson are now Co-habitating
« Reply #121 on: June 08, 2007, 12:01:27 PM »
know anybody with some "Dry Ice" freeze the sucker and hit it with a chisel.  Should break it.
James
SOHC/4 #3328
SOHC/4 Gallery: http://www.sohc4.us/gallery/v/members/personal/clarkjh/
1974 CB550, 40000 Miles
1980 GL1100, 102789 KM - Back on the road after a complete engine rebuild.
*** Why, oh why, is it always head gaskets with me?***
Offline dusterdude
« Reply #122 on: June 08, 2007, 12:09:21 PM »
clean it and go on with it,these steering necks turn on what a 90 degree axis at the most and have no rpm turning them.so as far as load goes,it aint no big deal.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
LRSDTIM
« Reply #123 on: June 08, 2007, 12:31:14 PM »
James
With my luck, the whole frame would shatter into a million pieces.
Offline Roach Carver
« Reply #124 on: June 08, 2007, 01:44:17 PM »
clean the race and replace the bearing. The race is going to be a nightmare to get out and as long as its not pitted it should be fine
