Author Topic: Tapered Steering Bearings Thread  (Read 208304 times)
Offline Chris Liston
« on: May 28, 2005, 04:50:54 AM »
Where can I order them?  Dealer?  and also bronze swingarm bushings? 76 CB550F
1976 CB550F Cafe in progress
Offline Gordon
  • 750K1, 550K2
Re: Where to get Tapered Steering Bearing CB550?
« Reply #1 on: May 28, 2005, 08:08:41 AM »
Please look over the FAQ.  Literally dozens of parts suppliers listed in there.
kmenzel
« Reply #2 on: May 28, 2005, 09:49:55 AM »
I just got some from www.partsnmore.com for $40.  I think that was as cheap as I could find.  My bike is a cb750, but i think they have other bike sets as well.
frstmate
tapered steering head bearings
« Reply #3 on: August 29, 2005, 07:18:18 PM »
this seems to get old asking the same ?. If anyone out there has a k6 or similar apart or who is getting ready to install the tapered bearings if they could post the numbers that are on the bearings them selvesshould be 4 or 5 digit number.. any help would be appriciated since i have a specialty bearing shop close by but need those numbers... These forums are a  great place for info. keep up the good work guys
thanks Rich
Re: tapered steering head bearings
« Reply #4 on: August 29, 2005, 07:27:12 PM »
Rich,
I have a set spare.
I ordered a set and they sent two sets.
I am at work at pesent and won't be back till Friday night.
If you dont find out by then look in Friday if you can.
Sam.
frstmate
« Reply #5 on: August 29, 2005, 07:38:10 PM »
Thanks Sam will check fiday or saturday..
thanks again
Rich
the_genrl
« Reply #6 on: August 29, 2005, 11:11:54 PM »
you may want to check ebay and try a custom fit.  I know ive seen universal tapered headset bearings on ebay, available in english sizes ( 7/8" 1" 1 1/8" maybe).  i think they were intended for choppers and the harley like, but i can see one of them working if you want to make some collars or something.
might be something to look into...they only ran like $10-$20
Online bryanj
« Reply #7 on: August 30, 2005, 03:07:23 AM »
Numbers wont help as they are not standard bearings
Offline hahnda
  • lskdfhs;dljksa;
« Reply #8 on: August 30, 2005, 06:57:29 AM »
These are the size you need.
Upper: 26 x 48.5 x 15.2
Lower: 30 x 50 x 14.4
They are an odd size so not sure even your specialty bearing shop will have them.
These places do.
http://www.pro-flo.com/proflo_all_balls_steering_stem_bearings_honda.htm
https://www.partsnmore.com/cat_index.php?model=cb750_sohc&category=chassis
http://www.denniskirk.com
And probably many more.
Kevin
Kevin
CB750K4 in pieces
CB750K3 with F trim
CB750K7
CB500 Cafe Project
CB750 Cafe
« Reply #9 on: September 03, 2005, 02:06:25 PM »
Hi Rich,
Not saying what Kevin has said is wrong but the size is not the same as what I have.
The bearings have on them H264815 and H305014.
We got sent two sets instead of two bearings, the other set has been in our CR750 for three years now and are fine.
Good luck with your bike ,
Sam.
« Reply #10 on: September 03, 2005, 03:32:30 PM »
Dave , the numbers I gave Rich will fit all CBs from 200 thru to 1000cc which includes all the SOHC4s.
Sam.
frstmate
« Reply #11 on: September 03, 2005, 08:19:55 PM »
Thanks guys will let you know what i come up with.
Rich
« Reply #12 on: September 03, 2005, 09:05:32 PM »
DIFFERENT NUMBERS FROM DIFFERENT MAKERS.
GOOD BEARING SERVICE SHOULD BE ABLE TO SUPLY BY CROSS REFFERENCING.
SORRY FOR CAPS, ONLY GOT ONE HAND, HAVING A NOSE BLEED.
Online bryanj
« Reply #13 on: September 04, 2005, 09:11:26 AM »
I think you will find those FAG bearings from dresda have the outer races ground to a smaller OD than original
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #14 on: November 10, 2005, 02:44:23 PM »
when i replaced my steering bearings on my cb550 F4, i was surprised at the apparent air gap between the top of the headstock, and under the spanner wrenched nut that hold the stem in place. i couldn't quite tell once it was tightened down, but it appears as if dust could get under that nut and into the bearings. didn't have a dust seal upon disassembly, nor does honda show one up there in microfiche, but it seems vulnerable as is. maybe tightening that nut down against the bearing seals it somehow, but if it rides on the inner race, how is that possible?
does it normally sit like this? seems like it would have to in order for that nut to not drag on the frame, but i couldn't help wondering if something was amiss...
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Online bryanj
Re: on the subject of tapered steering bearings...
« Reply #15 on: November 11, 2005, 04:10:56 AM »
The adjuster nut usually has a fixed on dust cover that dont come seperate
Offline paulages
  • 1976 cb735
« Reply #16 on: November 13, 2005, 05:08:42 PM »
i didn't lose anything in disassembly...was i missing something to begin with?
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Online bryanj
« Reply #17 on: November 14, 2005, 02:51:07 AM »
Quite possible the dust cover is just like  a dished washer that as i remember it  is crimped onto the peg nut so it can come loose and fall of, or be damaged and ripped off cos it rubs. If you can find a parts book to look at you will see the shape, or do what i did for a chop and flaten out a beer can and cut a big washer out of the ally, OK you can use a coke can too if you are teetotal
Offline cappy
Tapered Roller Bearings for Steering Stem
« Reply #18 on: December 04, 2005, 04:05:49 PM »
Hey all,
I just tore my CB550 front end off.  Are the ball bearings good enough for racing or do others update to tapered roller bearings??  Does anyone know what the sizes are?  I was going to mic the stems and bores tonight.  I know PRO-FLO has a good list of various sizes.
Thanks in advance,
Greg.
GTR1400 KAWASAKI CONCOURS 08'
T500 TITAN 75'
YZ250 82'
CB550 77' BUILDING
Offline jaknight
  • ....Round Town Ride......
Re: Tapered Roller Bearings for Steering Stem
« Reply #19 on: December 04, 2005, 04:26:37 PM »
HI GREG,
   Tapered bearings are the only way to go.  If you put your bike on the center stand, have someone sit on the very rear of the seat to lift the front wheel off the ground.  Then take hold of the handlebars and gently move them left to right.  Notice the bump like "stop" in the center and the rough feel as the front wheel moves through its turning arc.  There is a much smoother feel with the tapered bearings and no "bump" in the center position.
   They are worth every penny and bit of work that it takes to install them.  ~ ~ ~ jaknight
"THE PEN IS MIGHTIER THAN THE SWORD........
..........EXCEPT IN A SWORD FIGHT"
"There is nothing new under the sun.........But there are many old things we do not know"
BIBLE ---> Basic Instructions Before Leaving Earth
cd811
« Reply #20 on: December 05, 2005, 09:42:17 PM »
just looked it up...
www.denniskirk.com has them for $40.99
update your bike...NOW ;) ;D
Pcross
« Reply #21 on: December 06, 2005, 01:51:25 PM »
Try David Silver Spares for Tapered rollers for your replacement head bearings, as they more than likely stock them for your model of bike.
Offline chippyfive50
  • NO PEE ON TEPEE
    • thesweetimpala
« Reply #22 on: December 07, 2005, 07:20:08 PM »
Hey Cappy,
     shop for the lowest price @ one of the places in this link:    http://forums.sohc4.net/index.php?topic=743.0   it is in th FAQ's....ASS.   BITBURGERS ALL RIGHT!, WELP SEE YA  LATER! ;D
« Last Edit: March 16, 2011, 04:41:57 AM by Glenn Stauffer »
SOHC Member#4000
71' 500K0 #1021237--E1108327
78' 550
72' 750K2(sold to "Craig")
74' 750K4 #2306334--E2303422
73' CL175
http://gallery.sohc4.net/main.php?g2_itemId=14013
kmenzel
« Reply #23 on: December 07, 2005, 07:57:57 PM »
check partsnmore.com also
eldar
« Reply #24 on: December 07, 2005, 09:12:13 PM »
I thought about replacing my bearings but i do not have any grind or slop or any bump spot in mine. I think they are fine but  ithink I will change them anyways. Metal has come a ways from the 70's and tapers seem to be a hot ticket in most everyones opinion. Kinda like putting in cb900 coils.
