Author Topic: Tapered Steering Bearings Thread  (Read 210197 times)
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
Re: ALL BALLZ tapered steering bearings for non experts.
« Reply #250 on: June 19, 2008, 08:08:27 AM »
Damn scary eh, it's also probably in the archives here somewhere too but I always believe that more information is better than less.
         Nice job on the bearing install instructions. I've seen some writeups on them before, but don't recall the info given. You seem to come across quite well with how it should be done and should prove very helpful. 8) ;)
                             Take care, Bill ;)
Member # 1969
Offline flyin_
« Reply #251 on: June 19, 2008, 09:27:53 AM »
Nice detailed write up.  I just did this job last winter.  Somthing else to consider is how much hot and cold effect this job.  If you put the races in the freezer and heat the stem (even with a hair dryer)  the job is much easier.
CB750K6
CB750K1/K4
2000 Honda Magna
1965 S65
Offline dagersh
    • Photos
« Reply #252 on: June 19, 2008, 09:35:52 AM »
Great Write Up Hush!
Worthy of an FAQ Sticky!
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB450/500 Custom
1972 CB500K1
1975 CB550F
1976 CB400F
1975 CB750 Future Restoration
1976 CB750K6
1976 CB750F
1976 GL1000
1968 Suzuki T500 Cobra
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline Hush
« Reply #253 on: June 19, 2008, 04:11:29 PM »
Damn I should have thought about putting the stem in the freezer and warming the race up, ah well something new every day eh. ;D
Offline bill440cars
« Reply #254 on: June 19, 2008, 09:50:02 PM »
           Oh well, at last you got the ideas in. And, if you do another, you could add that to the instructions at that time. ;)
Member # 1969
Offline Hush
« Reply #255 on: June 21, 2008, 12:35:32 AM »
Yup but how do I stop this getting burried?
Offline manjisann
« Reply #256 on: July 25, 2008, 03:50:30 PM »
Thanks a ton!!! Like you said, the instructions were practically nill. Instead of going to the manufacturers website, I decided to try here first just knowing someone would answer my questions  ;D This forum rules, and so do you!!
Thanks,
Brandon
1980 CB650 Custom
Offline JerryRice
Tapered steering bearings..why??
« Reply #257 on: August 12, 2008, 08:35:38 AM »
What's up people!
I am changing my top tripple tree. While I got everything apart.. I was thinking.
Should I change my steering bearing to the teppered kind?
Do I even need to bother? Whats the point?
Would you do it while you have everything apart..or it is not even needed. My steering feels fine.
Please let me know your opinion.
Thanks!
The Real JERRY RICE
My Dream Bike
www.CB350F.com
Offline Steve F
Re: Tapered steering bearings..why??
« Reply #258 on: August 12, 2008, 09:38:30 AM »
If your upper and lower ball races aren't dimpled (not likely) you should be fine with re-lubricating everything and reassembling.  Otherwise you could try to find original ball bearing races or replace them with far superior tapered bearings.  BTW, (at least on a 750) the ball diameters are different top-to bottom.
Offline mustangcar
« Reply #259 on: August 12, 2008, 09:44:31 AM »
are the ball diameters different on the k8? i didn't notice that when i repacked and cleaned them,steering is fine with the balls,Ijust took out the bike a few days ago after a complete frame resto tear down,the bike runs GREAT!!!!!!! ;D ;D ;D
Offline Hush
« Reply #260 on: August 12, 2008, 09:47:51 AM »
If your bike is 30 years old and the bearings have never been replaced and you have it all apart then might as well do it.
The way to test them is put bike on centre stand and see if there is a bias in either direction when the front wheel is off the ground, if the steering likes to self centre then they need replacement even if you think they feel fine.
Offline mystic_1
  • 1970 CB750K
« Reply #261 on: August 12, 2008, 09:58:42 AM »
Because they make me look cool.    ;D
Just kidding, tapered roller bearings are stronger than the loose ball bearings that came stock in the steering head, and they won't wear as fast, meaning adjustment is needed less frequently.  Even if your existing bearings seem ok, you will notice a difference in the feel if you upgrade the bearings.  For the small cost and effort involved, you should definitely go ahead and do it now since you have everything apart already.
mystic_1
- John Augustus Shedd
Offline JerryRice
« Reply #262 on: August 12, 2008, 09:59:09 AM »
Hush, My steering goes to the left.
I assumes self centering would mean its OK.
But you are saying the opposite.
You are saying it should go left or right vs stay centered?
The Real JERRY RICE
My Dream Bike
www.CB350F.com
Offline mystic_1
  • 1970 CB750K
« Reply #263 on: August 12, 2008, 10:09:31 AM »
Well, the manuals describe the test like this:
Prop up the front of the bike, so that the front wheel is off the ground, and center the bars.  Now, bump one side or the other of the bars.  The front end should fall all the way to the steering stop on that side smoothly.  Now repeat the test in the other direction.  You want smooth action with no binding in both directions.
Also, if the steering feels "notchy" or tends to want to "snap" into place in the centermost position, the bearings need to be replaced.
mystic_1
Offline rhinoracer
« Reply #264 on: August 12, 2008, 11:23:36 AM »
 :o :o :o I needlessly banged my head on the wall ('cause I just replaced mine with 1/4" bb's top and bottom) before verifying your quote. The Honda parts direct diagram shows 1/4" balls top and bottom, whew, I'm fine! Although the race and cup radius does seem made for larger ball bearings.
Baja native.
rhos1355
« Reply #265 on: August 13, 2008, 02:53:26 AM »
Boy, I really, really hope your information is wrong there, Steve. Because it didn't say so on the parts manual or the maintainance manual. (ok, ok, I didn't really look)
Offline Steve F
« Reply #266 on: August 13, 2008, 04:52:40 AM »
My book states that there 19 balls on the lower, and 18 upper.  I distinctly remember after measuring them there are two sizes.
There are different part numbers for upper and lower bearing parts, according to the parts fische:
RACE, STEERING LOWER BALL-50302-268-000
RACE, STEERING LOWER-50302-268-010
RACE, STEERING LOWER BALL-50302-268-305
RACE, STEERING TOP BALL 50301-268-000
RACE, STEERING TOP BAL-50301-268-010
RACE, STEERING UPPER BALL-50301-268-305
RACE, STEERING LOWER CONE-53212-250-000
RACE, STEERING LOWER CONE-53212-250-010
RACE, STEERING-53212-250-305
RACE, STEERING TOP CONE-53211-268-000
RACE, STEERING TOP CONE-53211-268-010
RACE, STEERING UPPPER CONE-53211-268-305
I'm not sure why there are 3 different numbers for the 4 basic items, perhaps upgrades or changes, or perhaps as a "set" (-305) ?
« Last Edit: August 13, 2008, 05:19:48 AM by Steve F »
Offline 333
  • Time for change
« Reply #267 on: August 13, 2008, 05:48:37 AM »
Here's the real reason why rollers are better.  Each ball bearing has a single point of contact on the race.  Over time a dent in the race will occur at the place where the bike is going (steered(SP?))straight.  A roller bearing spreads out that contact patch the entire length of each roller.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
rhos1355
« Reply #268 on: August 13, 2008, 06:09:38 AM »
I've just checked my parts book and it states the folowing
96211-08000  Ball, steel, RB8 (1/4")       37 pieces for K0,K1 and K2
Phew, I was crapping bricks there.
Offline nippon
    • Classic Cycle City
« Reply #269 on: August 13, 2008, 06:15:22 AM »
Because I hate searching the balls on the floor after disassembling. ;)
Go for the tappered ones, they are stronger and better than an almost 40 year old
technology.
nippon
Offline Steve F
« Reply #270 on: August 13, 2008, 06:37:26 AM »
That 1/4" description leaves me skeptical.... these bikes are metric after all.  It almost sounds like a compromise.  But anyway, if you can, replace the balls with tapered rollers.  I like 'em.
Offline voxonda
« Reply #271 on: August 13, 2008, 07:14:12 AM »
It may sound funny, but there are no metric balls!
Cheers.
Offline 333
  • Time for change
« Reply #272 on: August 13, 2008, 10:00:06 AM »
Just like rims and tires.  No metric rims, and tires diameter always in inches.
BTW, roller bearings have been around for 40+ years.  They have always been a common upgrade for bikes.  Balls are just cheaper.
Offline voxonda
« Reply #273 on: August 13, 2008, 10:13:59 AM »
The main reason tapered bearings are used is that these bearings can accept heavier loads, due to the fact that a roll has more contact-area (line) then a ball (point), and accept loads from 2 sides. sorry can't explain better. Goes beyond my english. You also have to have 2 tapered bearings opposit to each other to accept loads from both sides.But there is a downside.................... make sure you adjust them right, or they won't survive either.
Hope it's a bit clearer now, or is it?
cheers, Rob
Offline Kouros
    • DOUBLESTRIPES.COM
Tapered Steering Bearing...Need more help please
« Reply #274 on: September 11, 2008, 10:17:45 PM »
I have 74 CB750K4.
What other years match the 74, as I'm having problems finding the 1974? I've found 2 on ebay a 75 and a 79. Should I got with the 75?
Are these a good choice as front Wheel bearings?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=002&sspagename=STRK%3AMEWA%3APIC&viewitem=&item=120303380145&rd=1
Are these a good choice for Tapered Steering?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=016&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=260285321523&rd=1
Thanks in Advance.
Kouros
« Last Edit: October 15, 2008, 02:58:18 PM by Kouros »
1974 CB750 K4 (Re-build in-progress)
