Author Topic: CB550 - Dropped the pan and don't like what I see  (Read 3039 times)
Offline imgnr
Re: CB550 - Dropped the pan and don't like what I see
« Reply #25 on: September 22, 2015, 09:48:19 PM »
Thanks for confirming.  The bolts did fit.  Regarding yours being 1/8 off wonder if you could've moved / tacked on a nut to move the hole...
I think I'll try Toolguy's method of pulling out the tensioner and manually bending it.  I wonder if anyone else tried this method and it worked for them.
By manually bending the tensioner, will it affect the way it functions?
I'm like the cat lady but with motorcycles.
Offline eigenvector
« Reply #26 on: September 23, 2015, 08:10:44 AM »
I would be amazed if you could bend it, it's not flimsy by any means.
Be mindful of where you bend it, at the retainer portion not where the slipper is (the slipper is what presses against the chain).  Otherwise I doubt it will affect how it works.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
« Reply #27 on: September 23, 2015, 12:42:03 PM »
It prevents sloshing of the oil, it's also called a baffle. Since the pickup is located to the rear, the baffle keeps oil in that section of the pan to provide the greatest depth of oil for the motor to pick up.
The oil dam also helps there be oil allowed to be picked up when you are leaned over pretty good for a turn to one side. It ccould be a fix to an issue with the larger oil pan in the 650.
Offline imgnr
« Reply #28 on: September 23, 2015, 01:13:04 PM »
Thank you all for your comments. Since its not that much more work pulling the head and I haven't put the cam chain back on yet, I'm going to pull it and the cylinders just so see what else the PO did wrong. Per recommendations from another poster, I think I'll take the cylinders to be honed as well since the PO said he changed the rings right before he sold me the bike. I've since put in a few hundred miles of short rides because the bike was so unreliable.  I also have the gasket so might as well.
Glad I checked the tensioner based on recommendations from this wonderful site.
Offline Trad
« Reply #29 on: September 23, 2015, 02:09:42 PM »
Good on you. You'll get it running right and there will be no guessing after you're done.
74 CB550 Build: NOS-GUTTED-OEMplus-HOLDTRUE
http://forums.sohc4.net/index.php/topic,130575.0.html
