Author Topic: Mikuni 29 mm smoothbore fitments on cb750  (Read 3529 times)
Swoop
« on: September 28, 2015, 12:06:50 PM »
Hi,
I know at one time there were special boots made for this fitment....are they still available?.....or is there a workaround?
Thanks
Steve
Offline dragracer
  • CB750F Dragbike
Re: Mikuni 29 mm smoothbore fitments on cb750
« Reply #1 on: September 28, 2015, 12:45:22 PM »
Z1 Enterprises sold them but last I checked they were out of stock with no delivery date. Said to call for more information. I haven't called myself.
« Reply #2 on: September 28, 2015, 12:54:52 PM »
I just bot a set from Z1, $149.95. Took about 3 weeks delivery. Mine were old and cracked. Wanted a fresh set. HE doesn't keep them on hand, will special order if the money's up front.
As a user, I think VM29 is a little fat for 736cc displacement. Maybe consider VM26.   Any way I've got mine on a 889cc engine, had them n a previos 839cc engine, liked them very much. JEff (Z!1) is helping me tune this aplication btter than the first application.
Swoop
« Reply #3 on: September 28, 2015, 01:30:01 PM »
Thanks for the replies....so they are not unobtainium.
Going on an 836.
Cheers
Steve
« Reply #4 on: September 28, 2015, 01:55:26 PM »
Going on an 836.
Cheers
Steve
Not to me they weren't, just a phone call, credit card and 3 weeks away.  I think DynoMan carries them too. I did not call them as I like Z1.
Should work great on an 836cc.
Offline dragracer
  • CB750F Dragbike
« Reply #5 on: September 28, 2015, 04:56:32 PM »
Thanks for the feedback on the Z1 availability. I'm going to call next week to put my order in. McRider, I assume the boot configuration allowed for a direct fit for the carburetor  racked for a kz and Gs and not standard 750 spacing??
« Reply #6 on: September 28, 2015, 05:26:17 PM »
Ooh Thats a good question. Mine are racked for the CB750, and I think that's different than the KZ and GS. Jeff will know.
« Reply #7 on: September 28, 2015, 06:34:24 PM »
You can get the rubbers Frank, My VM29 smoothies have the stock Kawasaki spacing but the manifolds I have allow them to be fitted to a 750 Honda, I had old CR31mm with ticklers spaced for the Kawasaki/GS1000 and they fitted the 750 with the correct manifolds, I'm sure someone still sells them... ;)
Offline dragracer
  • CB750F Dragbike
« Reply #8 on: September 28, 2015, 06:57:33 PM »
I've got several sets of Mikuni flatslides racked for kz's and a set of Cr33's. I sure would like to use them on a SOHC.
« Reply #9 on: September 28, 2015, 08:14:27 PM »
I've actually got 2 sets of the manifolds that mate up the Kawasaki/GS carbs to the Honda, I am keeping them just in case i need odd manifolds for non stock carbs... I wonder if the manifolds would fit the bigger 33's and Mikuni flat slides, you may have to buy some to find out.... ;)
http://www.ebay.com/itm/Honda-CB750-Carburetor-Manifolds-Mikuni-VM29-Smoothbore-Carb-Boots-/151801078527
http://andrewsmotorsports.mybigcommerce.com/honda-cb750k1-k5-cb750-76-cb750f76-cb750-sohc-vm29-manifold-kit-005-026/
Offline dragracer
  • CB750F Dragbike
« Reply #10 on: September 30, 2015, 04:53:13 PM »
As long as the spacing is correct, I can use a drum roll sander on my drill to open the boots up to the proper diameter for the bigger carbs. That's what I had to do with the stock f model boots on the bike now.
Offline 1080
« Reply #11 on: September 30, 2015, 05:39:28 PM »
I used Fuel transfer hose back in the 90's.
Offline hotdog
« Reply #12 on: September 30, 2015, 06:12:26 PM »
Great photo..!
Instagram - LUMPY CAM MOTORCYCLES
FB - LUMPY CAM Motorcycles
Offline johno
« Reply #13 on: September 30, 2015, 08:42:35 PM »
They were man days  ;) when ya done what ya think ;D
ps great pic
GRASSHOPPER SOHC HONDAS ARE THE MEANING OF LIFE.
Offline Ricky_Racer
« Reply #14 on: October 01, 2015, 09:00:15 AM »
I believe the importer on these manifolds is Sudco. Check with them at Sudco.com. Phone: 310-637-8330, or email: Sudco@Sudco.com
RR
