Author Topic: project with aluminum - question about bending  (Read 1655 times)
Offline greenjeans
  • 1972 CB750K2
« on: September 29, 2015, 06:42:35 AM »
I have a 1/4" piece of 5056 aluminum that I had a friend cut into a shape for me on a waterjet.
Basically, I'm trying to make a butterfly type steering wheel for a gravity/coffin racer.
All I need to do is put 2 45 degree bends in it.   I would need to heat with a torch ?    After bending,
would I need to reheat it ?
Re: project with aluminum - question about bending
« Reply #1 on: September 29, 2015, 07:22:43 AM »
Aluminum you can heat and bend and let sit and it will get hard again over few days.
Edit:  this particular Aluminum is non heat treatable:
http://aviationmetals.net/aluminum_sheet.php
You should be able to bend it cold.
« Reply #2 on: September 29, 2015, 07:42:18 AM »
I used before 2x4 clamped to the edge of the table as a poor man's break - the metal piece is between the 2x4 and table and the bend is made over the table's edge.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #3 on: September 29, 2015, 07:52:50 AM »
You should use a metal break to get the best (preside) results.
Just take it to a sheet metal fabricator. Even heating and ventilation fabricators can do that. They'll bend it in minutes. Likely won't cost you anything either.
Offline greenjeans
  • 1972 CB750K2
« Reply #4 on: September 29, 2015, 08:03:39 AM »
I have access to a torch and a brake.   Since that metal is "non-heat treatable"   I should just be able to put it in the brake and give it the bends ?      I was afraid it would crack or just break.
« Reply #5 on: September 29, 2015, 08:10:09 AM »
You got a scrap piece to try it first?
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #6 on: September 29, 2015, 08:28:33 AM »
No heat required. It won't crack or brake.
Have fun.
Offline Steve F
« Reply #7 on: September 29, 2015, 09:50:08 AM »
Some say it won't break, some say it will, but if it were me, given that your material is 1/4" thick, plan on a radius at the bend, twice the thickness to be safe.
Give me a break guys,
Use a BRAKE to bend material
too sharp a bend and it will BREAK
Offline Mantree
« Reply #8 on: September 29, 2015, 09:51:57 AM »
I use to bend electric boxes out of aluminum all day long it is a soft metal and will be fine in a break
Sent from my SM-G900V using Tapatalk
« Reply #9 on: September 29, 2015, 09:58:20 AM »
1+ Also, it will work harden when bending.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #10 on: September 29, 2015, 11:56:24 AM »
You guys are over thinking this.
It isn't rocket science.
« Reply #11 on: September 29, 2015, 01:33:18 PM »
Bend it with 2x4s in the vise.. And yes sharp radius can break it, if you are bending 6061 you have to use 2.5-3 times thickness as the radius... Not the same as bending the thin box material..
