Author Topic: First Bike, First Build, 77 CB550K  (Read 6286 times)
Offline eoddom
Re: First Bike, First Build, 77 CB550K
« Reply #25 on: October 14, 2015, 07:06:10 PM »
I'm assuming that if there was a hoop welded on the end, it would hold it together.  But you see how I'm having trouble understanding how a hoop would fab up to the tail without completely re-engineering the back of the bike so it's all tube.  I'll definitely make sure that I have enough travel for the wheel, thanks for the heads up.  I guess I'll have to re-wire that spot going to the coils so it atleast uses solid copper-core wire instead of speaker wire.  And I'll look to see if that bracket is still there.  If not, I eventually plan on some rear-sets, so it'd have to be moved eventually.
Offline eoddom
« Reply #26 on: October 15, 2015, 08:02:50 PM »
Alright, thanks for that info.
On an un-related note, someone reached out to me on facebook when I was asking around for motorcycles for sale and offered me a cb450 basket case for free.  Gonna go pick it up this weekend and in turn, give it to my buddy so I have someone else to turn wrenches on a bike with.
Offline eoddom
« Reply #27 on: October 16, 2015, 06:54:12 AM »
Yeah I've done a tiny bit of research on the bike last night.  I gotta call the guy this afternoon, he's gonna give me a run down about the bike, what's there and what extra goodies he's throwing in with it.
Over 100hp per litre naturally aspirated is always cool though.  Only thing I've ever owned that could claim that was an E46 M3.
Offline eoddom
« Reply #28 on: October 16, 2015, 03:25:43 PM »
Not really an update, moreso a list of what I hope to accomplish tomorrow.
Install new rack of carbs.  These are PD46C's instead of the PD46A's i was running.  Main jets are 110's, slow jet is 45, pilot screws are out 1 1/2 turns.  Not sure what setting the needle is set at, will check this tomorrow and set at stock (3rd groove from top) if it's not already there, and move to 2nd groove from top if too lean.
Check and adjust valves, timing chain tension, gap points and check/adjust timing.
Install new plug caps and Uni pod filters (dont kill me for not having a stock airbox yet, working on it).
I'm sure the carbs will probably require tuning but I feel confident I have the time and patience to get them right, even if it means I end up with lots of extra jets.
Hopefully I'll be able to post up some pictures and a video of it running well tomorrow.
Offline eoddom
« Reply #29 on: October 18, 2015, 05:38:44 PM »
So success.  The bike started and ran pretty damn good.  Even managed, once warm, to start it with one kick of the kick starter.  Took it down my street and back just to make sure it's not dying out under load or backfiring.  I guess those 110 mains with the pod filters were a good combo.  Gonna have to adjust the IMS a bit to get the idle perfect so I don't have to mess with the big idle screw.
But now I've unearthed a few problems:
Apparently I have a charging problem.  Bike runs great until the battery gets low, then it runs like crap and eventually dies out and wont start.  Found this out at the end of my road on trip number two when it died at the stop sign and I had to push it home.  Also realized I'm EXTREMELY out of shape.  What's the most common issue with the charging system?  Reg/Rec?
Problem two, the drain screws in two of the bowls don't seem to seat well.  The overflow drains drip constantly but it's not due to the carbs overfilling.  Pulled both bowls, put a little fuel in them and they still leak.  Tried backing the screws out, cleaning them and reinstalling but still leak.  Tried using the screws from my other set of carbs and still no luck, so has to be a problem with the bowls themselves.  Any fix for this?  or am I going to have to scavenge to bowls off my other set of carbs?
Edit:
Here's a video of it running earlier.  Still need to adjust valves and timing chain but I think most of the noise is from that crappy leaky exhaust.  The pipes aren't even super tight in the head, I can move them easily from side to side.  New exhaust is high up on the list of stuff I need.
« Last Edit: October 18, 2015, 06:26:31 PM by eoddom »
Offline Gene
  • Chat enuf you too can be a
« Reply #30 on: October 19, 2015, 11:17:48 AM »
Also check for cracks in your overflow tubes.
*1973 CB750K3 (Bow)
Offline eoddom
« Reply #31 on: October 19, 2015, 03:09:59 PM »
It drains down to the lowest part of the bowl so I don't think it's the overflow tubes themselves.  Either way, I'll just scavenge and clean two bowls from this other set of carbs since no one seems to want to buy them.
Offline eoddom
« Reply #32 on: October 20, 2015, 06:09:30 PM »
Well I replaced the two bowls that were leaking, not leaking anymore.  I did happen to find the main jet for #1 in the bottom of the bowl though.
Offline eoddom
« Reply #33 on: October 22, 2015, 05:32:26 PM »
So I checked timing and it's pretty far advanced.  Problem is, 2 of the 3 timing screws are completely stripped out from the PO.  Anyone know what length/size/pitch these screws are?  gonna get some easy outs and some bolts to replace the screws with and get my timing set properly.
Offline eoddom
« Reply #34 on: October 23, 2015, 04:42:18 AM »
Yeah I've read about the JIS screws.  Wish the PO had aswell, haha.  the screws are completely rounded out in the middle from the previous owner.  So far, these are the only screws I've come across in this bad of shape.  Every other screw I've that I needed to take out, I've been able to remove.
Offline eoddom
« Reply #35 on: November 04, 2015, 12:16:26 PM »
So I got the bike running a little better today.  The timing was a bit advanced, so brought it back a little and now it doesnt fall on its face when it's under load.  Is it normal for these things to be pretty blah under 3k in any gear but 1st?  I'm sure the timing could be fine tuned from here.
Also think I need to bring my air jets back half a turn, wont seem to idle lower than 1200rpm no matter how much I back out the big thumb screw for the entire carb assembly.
Also, from a cold start it seems like to having no choke at all.  Fires right up without touching choke.  With the choke on it wants to idle at like 2krpm but also seems to feel better in general.  Running rich maybe?
« Reply #36 on: November 04, 2015, 03:26:16 PM »
Yes, could be rich, do a plug chop. Have you sync'd your carbs yet?
1200 rpm is a good idle, I like it a little high.
Life begins at 5K!
Offline eoddom
« Reply #37 on: November 04, 2015, 04:56:23 PM »
I'll do a plug chop tomorrow and order a new set.
The carbs havent been vacuum synced yet, that's on the list next.
Also, curious, how do you guys generally support your frame to remove the front fork and rear swing arm?  I'm at the point in this project where I feel comfortable that the bike is running half way decent/will run better with fine tuning and I want to go ahead and strip her down to the frame, get it cleaned up and start replacing bearings/bushings, cleaning up the harness, etc.
« Reply #38 on: November 04, 2015, 06:35:40 PM »
I bolted a large pice of angle iron to the ceiling joists in my garage. I attached a large ratchet strap to it and lift the entire front or rear end up off the ground.  Works great.
Offline eoddom
« Reply #39 on: November 04, 2015, 07:33:31 PM »
I rent so that probably wont be an option, haha.  I guess I could get my 2 ton engine hoist back over here and some chain and get the bike off the ground.
« Reply #40 on: November 04, 2015, 08:37:19 PM »
It's just 3 large lag screws, no damage would be done that a little sparkling can't fix (if you have sheetrock)
Engine hoist should work great
Offline eoddom
« Reply #41 on: November 07, 2015, 05:13:21 AM »
I'm gonna go grab my engine hoist today and see how it works out.
I plan on starting the tear down today now that the bike is running pretty alright.  My biggest goal here was to hear the bike run and to take it for a ride around the neighborhood.  That will be the driving force that gets me through having this thing in pieces and keeping the motivation to put it back together.  First thing I'm going to do is buy ziplock bags, a marker and break out the camera...hopefully that will help me remember what goes where on the other side of this.
Also noticed my neighbor doing some cutting and welding on his Jeep Comanche yesterday, so gonna go make friends with him so I can hopefully get some little stuff welded over the winter, haha.
Offline eoddom
« Reply #42 on: November 08, 2015, 08:44:46 AM »
So spent a few hours stripping down what I could with the bike on the ground.  Once I dove into the wiring, I realized its extremely simple and not as much of a rats nest as I had expected.  Definitely gonna have to replace the fuse block.  If I make it out to my dads today, I'll have the front fork and rear swing arm dropped tonight.  Then it's just figuring out how to get the engine out.  Will probably just lay it on its side and lift the frame off of it like others have done in the past.
On a side note, I got laid off this past monday.  This is the first time I've been unemployed in years and I'm kind of looking forward to a break.  I haven't taken vacation in 7 years so we're going to use this time to travel a bit, prepare for daughter number 2 and relax.  I've got standing offers at the 1st of the year so I'm just gonna ride it out and have some fun.
So here's ol nekked bike, just hanging out.
Offline eoddom
« Reply #43 on: November 09, 2015, 05:07:35 AM »
And some more progress.  Engine hoist worked great for getting the bike up.
It really is amazing how simple these bikes are at the end of the day.
