Author Topic: kawasaki sprocket carriers  (Read 834 times)
Offline KRONUS0100
  • MAD MATT THE MANIAC
« on: September 30, 2015, 02:11:32 PM »
does anyone know if the sprocket carrier for an 83 gpz550 is the same one as used on the 82 kz750 ?  thanks
MATT
Re: kawasaki sprocket carriers
« Reply #1 on: October 01, 2015, 01:33:34 AM »
Hmmm, I think the 550 was slightly smaller, the wheels certainly were, I could be wrong though, I'm chasing a sprocket carrier off a Z1000 P, wouldn't have one by any chance... ;)
Offline KRONUS0100
« Reply #2 on: October 01, 2015, 06:19:37 AM »
nope not off hand i dont.  the gpz rear wheel i just aquired is an 18x2.15....same as the 78 comstar that was on my 750f.  i currently running the 16x3 off the 82 kz750....sprocket carrier looks like it might fit the 18, but i havent pulled the rear wheel to check the fit.  brake rotor will swap over if i drill some holes for 5 bolt pattern.   found a couple of websites that carry the same part number for the drive hub assembly, and one that sez they are different numbers.  i got all winter till spring to figure it out.
MATT
« Reply #3 on: October 01, 2015, 08:21:43 PM »
Matt, do you need an '82 550 carrier? I've got one in the shed. It seems to also fit on a 2.5 wheel of an unknown model Kawi.
Offline KRONUS0100
« Reply #4 on: October 02, 2015, 05:51:53 AM »
I MIGHT.  im going to go ahead and pull my 16 inch rear out of the bike this afternoon and see if the carrier i have will fit the 83 gpz550 wheel.  pretty sure 82-83 gpz shared the same wheel.......the one that looks like the normal kawa mags.  84 up i think switched to the funny looking tri spoke mags.
MATT
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #5 on: October 02, 2015, 11:10:56 AM »
Go to motogrid.com. Look at the parts diagram and cross-reference the part#.
Offline KRONUS0100
« Reply #6 on: October 02, 2015, 06:19:53 PM »
they are not the same.  the gpz550 is a bit smaller diamater hub
MATT
« Reply #7 on: October 02, 2015, 06:53:43 PM »
I suspected so..... ;)
