Author Topic: "winter" project  (Read 1062 times)
Offline bamajoe
"winter" project
« on: October 04, 2015, 01:57:33 PM »
So I acquired a 1970 cb750. The engine is not stamped with a VIN. The frame VIN is CB750-1048055. According to what I could find online, the "sandcast" motors where not put in frames that "new". But according to the same website the "sandcast" motors had 10 screws in the clutch cover and the die cast motors had 11. So my question is what is up with no VIN on the motor, and is mine a "sandcast"?
« Last Edit: October 09, 2015, 07:52:47 PM by bamajoe »
Offline bamajoe
Re: Vin questions...
« Reply #1 on: October 04, 2015, 01:59:44 PM »
Sorry forgot pics
No vin
Clutch cover
« Reply #2 on: October 04, 2015, 02:28:22 PM »
Many early cases suffered damage from drive chain breaks, many replacement cases never got the VIN restamped, that is most likely what happened to yours.
Sorry, no sandcast there.
Offline bamajoe
« Reply #3 on: October 04, 2015, 02:42:17 PM »
I'm fine with it not being sandcast. Just was kinda confused..
« Reply #4 on: October 04, 2015, 04:00:05 PM »
Drive train and internal chain failures tore up cases, and the dealers would replace them with non-stamped cases.
Offline tango911
« Reply #5 on: October 04, 2015, 04:03:38 PM »
i think its 10 and 9    die and sandcast on the clutch cover bolts.
CURRENT STABLE:
1969 Honda Dream 305 (black)
1974 Mach III kawi 500 smoker
K2 (project)
K2 Original fixer up
K0 original fixer up
2006 CRF250R
Offline bamajoe
« Reply #6 on: October 04, 2015, 04:06:21 PM »
I was going of this..
Offline tango911
« Reply #7 on: October 04, 2015, 04:13:41 PM »
maybe im remembering wrong.  thought the sandcast had 9
CURRENT STABLE:
K2 (project)
2006 CRF250R
Offline kmb69
« Reply #8 on: October 04, 2015, 05:01:51 PM »
This Sandcast 750 intro contains several errors. I have requested that it be corrected or removed but it is still there.
Steve, you are correct. The Sandcasts have 9 holes in the clutch cover. I am going to call you tomorrow about 658.
Offline bamajoe
« Reply #9 on: October 04, 2015, 07:39:42 PM »
thanks for the info!
Offline bamajoe
Re: "winter" project
« Reply #10 on: October 09, 2015, 08:09:51 PM »
alright i renamed the thread as I'll be asking more questions here and posting about this project.  ;)
  well I rigged a soda blaster and went at my carbs this evening with pretty nice results I thought! But... in the process of removing the float pins in my carbs I managed to do the very thing I was dreading. i broke one of the float posts >:( >:( .. so I turned to ebay  ::) and found a "reposter"... anybody ever use something like this?
