Author Topic: Cylinder removal in frame  (Read 1582 times)
Offline mdl91881
« on: October 04, 2015, 05:50:05 PM »
Does anyone know if you are able to install the cylinder with the bottom end in the frame?  I pulled my motor to do a rebuild and was thinking it would be a lot easier to re install the motor bottom end and then the top end.  I know I read that the heads can be removed/installed with the engine still in the frame, but haven't seen anything about the cylinders.
Offline Old Scrambler
Re: Cylinder removal in frame
« Reply #1 on: October 06, 2015, 09:43:34 AM »
I have not done this.  I think the answer is ...........Yes...........BUT.............If you leave the motor-mount bolts out and have 2 or more helpers............It will be a real challenge to get the rings compressed...........and much more likely to damage the paint and sealing-surfaces. Installing the cylinder on a bench or engine-stand allows you to keep everything more sanitary and assures the rings are not broken.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
« Reply #2 on: October 06, 2015, 09:46:39 AM »
What engine are we speaking of here?
I have a motorcycle problem.
« Reply #3 on: October 06, 2015, 11:24:01 AM »
YEs, the post is in CB750A which can do a top end job with the bottom in frame, I think. OCICBW
Standard Ks and Fs cannot.
Which is it?
Offline mdl91881
« Reply #4 on: October 07, 2015, 04:29:19 AM »
the bike is a 1977 cb750a
