Author Topic: 1979 cb650 brake rebuild kit  (Read 627 times)
Offline BollarNPS
« on: October 05, 2015, 10:22:23 AM »
Does anyone know where these can be bought? I can't seem to find one anywhere.
Offline JimJamerino
  • Yay! I'm a
  • Not rich enough to be "eccentric."
    • My CB650C build thread
Re: 1979 cb650 brake rebuild kit
« Reply #1 on: October 05, 2015, 01:47:47 PM »
Are you talking about the front brake master cylinder, or caliper, or the back brake?
Either way, the only kits that I know of is a master cylinder rebuild kit and a master cylinder reservoir kit. Everything else is piecemeal.
I got a lot of my parts throughwww.newmotorcycleparts.net and www.partsnmore.com.
I got a new caliper piston and an OEM piston seal from ebay. Be careful of the part numbers for the seal; I ordered the wrong one the first time.
My disassembled master cylinder: http://forums.sohc4.net/index.php/topic,74212.msg1044953.html#msg1044953
Part numbers on my caliper seal: http://forums.sohc4.net/index.php/topic,74212.msg1244829.html#msg1244829
~ Jim
formerly "emperorspartacus"
There are old bikers.  There are dumb bikers.  There are no old, dumb bikers.
My CB650C rebuild http://forums.sohc4.net/index.php?topic=74212.0
Offline BollarNPS
« Reply #2 on: October 05, 2015, 08:53:44 PM »
I'm talking about the caliper rebuild. I noticed the mc rebuilds are a dime a dozen. I haven't taken apart the caliper yet so for now I just want piston seals. You've purchased these through the websites mentioned above?
Offline fizzlebottom
« Reply #3 on: October 05, 2015, 09:36:22 PM »
There is no caliper rebuild kit. You just replace the rubber bits. If the piston(s) have any pitting, you replace those as well.
While you're at it, replace the hose with stainless steel. Especially if your rubber hose is more than 6 years old. Otherwise you're risking the rubber bulging and providing seriously inferior braking.
1982 CB650SC Nighthawk
Offline BollarNPS
« Reply #4 on: October 06, 2015, 10:18:47 AM »
That's what I'm looking for is the pistol seals. Maybe I'm just searching the wrong term.
Offline JimJamerino
  • Yay! I'm a
« Reply #5 on: October 06, 2015, 10:50:34 AM »
On mine there really wasn't much to the caliper. Piston, seal, caliper, a couple bolts, and the pads. With the part numbers a new seal shouldn't be too hard to find. If not on the sites I mentioned, maybe through your local dealership, other sites, or ebay?
~ Jim
Offline przjohn
« Reply #6 on: October 06, 2015, 12:57:17 PM »
They sure look a lot like the 750 calipers. I would think there have to be kits out there for those bikes. Maybe see if they are the same part #
« Reply #7 on: October 06, 2015, 02:56:07 PM »
http://www.partzilla.com/parts/search/Honda/Motorcycle/1979/CB650+A/FRONT+BRAKE+CALIPER/parts.html
Go there. You want to order the following from that list:
8
BOOT
PN 45109-425-003
12
BOOT, CALIPER SHAFT
Use from Frame SN 2016872
PN 45133-425-003
12
BOOT, CALIPER SHAFT
Use up to Frame SN 2016871
PN 45133-413-003
16
SEAL, PISTON
PN 45215-533-043
Pay attention to #12, the Caliper Shaft Boot. You need to make sure it is the correct one for your frame's SN.
Offline BollarNPS
« Reply #8 on: October 06, 2015, 03:01:36 PM »
thank you for that link and information that is very useful!!!! my question now is what is the difference between the #16s
« Reply #9 on: October 06, 2015, 09:58:43 PM »
Probably an instance of Honda assigning a new part number because of an update to the part design or that it was used in other bikes as well. Get either one and it's with fine I'd imagine.
Offline JimJamerino
  • Yay! I'm a
« Reply #10 on: October 07, 2015, 09:04:35 AM »
The first one, 45215-533-004, is the one that fit my bike. When building mine, I found out the European models, despite being the same year and trim, used a different size piston.
~ Jim
Offline BollarNPS
« Reply #11 on: October 07, 2015, 10:10:04 AM »
Well I hope I got the right one then. I got the 043 but idk if mine is European mode
