SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Screw/bolt kit for K7
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Screw/bolt kit for K7 (Read 705 times)
shotty750
Full Member
on:
October 06, 2015, 09:19:47 AM »
Has anyone come across anything like this on Ebay or somewhere? Screws on my alternator cover were badly stripped. Thanks!
Logged
'77 CB750K
flybox1
My wife thinks I'm a
Really Old Timer ...
Re: Screw/bolt kit for K7
Reply #1 on:
October 06, 2015, 09:34:31 AM »
http://www.bullitcustomcycles.com/products/stainless-bolt-kits-hardware/honda-cb750-sohc-1969-1978-bolt-kit
Last Edit: October 06, 2015, 09:37:20 AM by flybox1
Logged
'78 750K (F3 engine) PD42b's, Modified airbox w/K&N filter, 40/110 jets, 1 needle shim, IMS@ 1 turn out. Kerker + Cone 18" QuietCore
beemerbum
Expert
Reply #2 on:
October 06, 2015, 10:07:17 AM »
Right or wrong? My local CB 750 guru doesn't like allen bolts for side covers. His reasons are: (1) Not authentic (2) Too easily over-tightened by amateurs. On the other hand, original screws and bolts are hard to come by. Does anyone know of a source for Phillips side cover screws? It is probably wise to invest in a set of JIS screw drivers if you want an original look. They are also good to have to take apart 40 year old Japanese bikes.
Last Edit: October 06, 2015, 10:10:31 AM by beemerbum
Logged
flybox1
Reply #3 on:
October 06, 2015, 10:17:44 AM »
source: bolt depot (phillips, not JIS)
for a trailer queen show bike, yeah, ok.
but these kits have it all and are sorted by cover/use.
Logged
PeWe
Bike almost back to the 70's 2015
Reply #4 on:
October 06, 2015, 10:31:11 AM »
The authentic look.
http://www.yamiya750.com/index.php?main_page=index&cPath=158_283
Logged
CB750 K6-76 970cc (Earlier 1005cc JMR Billet block on the shelf waiting for a comeback)
CB750 K2 -1975 build thread
shotty750
Full Member
Reply #5 on:
October 06, 2015, 10:32:31 AM »
Thanks for the link Flybox1....yeah, I was wondering too if anyone sold the Phillips head screws in a kit but these should work fine too.
The newbies should invest in a torque wrench if they're getting these!
Logged
'77 CB750K
PeWe
Reply #6 on:
October 06, 2015, 10:55:55 AM »
There are std srewdrivers for allen heads. Difficult to over torque. I have complete set for M4-M8. Make the assembly easier.
http://img.directindustry.com/images_di/photo-g/ball-end-allen-wrench-screwdriver-type-88203-6477155.jpg
Logged
Mantree
Hot Shot
Reply #7 on:
October 06, 2015, 12:27:02 PM »
I personally like allen keys but I have digital torque wrench for when I do head gaskets or the such but just doing side covers I just know when to stop with the Allen keys
Sent from my SM-G900V using Tapatalk
Logged
evanphi
Apparently I'm an
Old Timer
Rhonda the Basket Case
Reply #8 on:
October 07, 2015, 08:07:03 AM »
I have a 1/4" drive, inch/lbs torque wrench for the allen bolts. Easy to use. Never over-tightened!
Logged
--Evan
1975 CB750K "Rhonda"
calj737
I refuse...
Reply #9 on:
October 07, 2015, 01:13:46 PM »
Side cover bolts are 6mm and use less than 8# of torque. Unless you are sealing a rubber o-ring, "snug" is amply tight
Logged
'74 550 Build
http://forums.sohc4.net/index.php?topic=126401.0
'73 500 Build
http://forums.sohc4.net/index.php?topic=132935.0
754
Reply #10 on:
October 07, 2015, 06:09:00 PM »
Learn to use your middle two fingers on an Allen wrench for 6mm..
If that's hard. Cut it down to three inches length..
Logged
Kelowna B.C. Canada
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
