Author Topic: 400f tire sizes Q?  (Read 543 times)
Online Don R
400f tire sizes Q?
« on: October 06, 2015, 02:24:19 PM »
  My dealer got me 90/90/18 for the front and 110/80/18 for the rear they are irc and look really big dismounted. Those are the sizes that were on the bike before, My other 400F had inch and letter sizes so i'm not sure what they are. 3.00X18 and MJ or something.
 Anyway will these size IRC's work and look right once they are on it? ?
 I laced up new did rims and am ready to rock this 77 400f back to running again, she's been down a couple weeks already.
Offline Bodi
Re: 400f tire sizes Q?
« Reply #1 on: October 06, 2015, 03:54:00 PM »
Those are good sizes, about the best you'll find in a metric 18" tire (OK, that does look self-contradicting). The width 90/90/18 is in mm so a 90mm is very close to a 3.5" "inch" tire. The 110 is wider than stock at about 4.3" but the 110/80/18 height ratio means a lower profile and it will fit OK. Choice is reducing every year for 18" tires.
These will be "tubeless" tires so getting the bead over your tube rims will be more of a chore than with old tube tires, but they will go on. Use some lube - soapy water works well - and inflate them then check that the bead line is equally spaced from the rim all the way around. If not, try overinflating them to the "max" psi rating on the sidewall, if that doesn't do it you have to pop the bead off and try reseating it. The bike will pogo a bit if the bead sits offcentre..
Online Don R
« Reply #2 on: October 06, 2015, 08:57:56 PM »
 Thanks Bodi.
Offline MoMo
  • Ride like you're invisible
« Reply #3 on: October 06, 2015, 09:20:37 PM »
Don, for future reference...Larry
http://www.cb450stuff.com/tires/
Online Don R
« Reply #4 on: October 07, 2015, 02:56:27 PM »
 Thanks, got em on the rims and they look fine.
