Author Topic: 1976 CB750F - first bike, first build - mild cafe  (Read 38578 times)
Re: 1976 CB750F - first bike, first build - mild cafe
« Reply #175 on: May 24, 2016, 09:48:09 AM »
After vacuum sync is done, mixture screws are set independently, based on plug color.  Not by idle sound.
Looking good.
Pics of how  you mounted your LED stop/tail light?
Offline riffman12
« Reply #176 on: May 25, 2016, 12:51:27 PM »
sort of hard to see, but this is how the LED strip sits. It was taped on for the test run, but will be properly mounted once the seat is painted.
My friend behind me said it was quite dim in daylight, but I'm hoping that just because of the low voltage / charging problem.
« Reply #177 on: May 25, 2016, 04:50:31 PM »
Make sure it is visible enough in sunshine, because that's what you'll be riding in most of the time.  You don't want to get rear-ended in LA (or any other) traffic.
Your painter should be able to body fill and blend the seat to the light.
Offline Thousandson
  • Ride, Fix, Repeat
« Reply #178 on: May 27, 2016, 11:46:38 AM »
Looks great. One thing I found out on my 750SS 78', when I did clubman bars. It put me really far forward, great attack position, feels like I am part of the bike. But I had to roll the bars pretty far forward just so they didn't hit the tank. It looks like you did the same thing, I just can't ride for long long distances. I traded out to drag bars, it was a compromise.
Current ride: 78' Cb750F
« Reply #179 on: May 27, 2016, 12:42:27 PM »
A nice alternative are the Tommaselli Condor Clubmans which are adjustable.  You can adjust the bars to a zero or even positive angle because the attachment point remains static.  They are pricier than a standard clubmans.  The adjustment points are indexed and have a LARGE allen bolt so they do not move even when applying lots of force.
« Reply #180 on: May 27, 2016, 01:20:49 PM »
yup...standard clubmans dont really work with these bikes.  They came about for 1960s twins and singles raced in sportsman classes
Offline riffman12
« Reply #181 on: July 10, 2016, 07:05:45 PM »
so after almost exactly a year, this project is finally finished. Rode it all day today, high speed runs, twisties, around town. So much fun to ride!
Huge thank you to all of you who helped me through the way. Couldn't have done it without all of you. Here's some pics:
I'm sure it's not completely done. More things will come up, but for now it's just where I want it.  :D
« Reply #182 on: July 10, 2016, 08:47:52 PM »
It came out great.  Glad you got the seat/taillight sorted.
Offline Yozzer74
    • Yozzer
« Reply #183 on: July 15, 2016, 10:06:09 AM »
Bike looks great how was the fitment of the exhaust pipe
Offline riffman12
« Reply #184 on: July 25, 2016, 10:39:25 AM »
Thanks guys!
I'm still having a bit of wobble in the outside rim of the front comstar. I've had it up to 85mph and there is still no shake or anything through the bars, so I'm hoping the wheel is just a bit out of round (and balanced properly). Brake rotors are still dead straight so there is no movement at the hub. Is this normal for comstars?
Thank you! the exhaust can be a bit of a pain to get all 4 headers lined up with the head. Just takes a bit of muscle. Once it's in it fits the bike really well.
Here's a recent shot of the bike:
« Last Edit: July 25, 2016, 11:46:08 AM by riffman12 »
« Reply #185 on: July 25, 2016, 12:36:18 PM »
My comstar does exactly that...visual wobble at speeds of about 30 to 50, above 50 you can't see it, no affect on handling or how the bike rides
« Reply #186 on: July 25, 2016, 06:44:57 PM »
Trippy!
« Reply #187 on: July 25, 2016, 06:56:25 PM »
every spoked wheel I have ever had did similar except some could be felt and did affect handling
« Reply #188 on: July 25, 2016, 11:15:52 PM »
Sean, was that before or after dropping acid...?   ;D :P
« Reply #189 on: July 26, 2016, 03:10:01 PM »
all of the above
« Reply #190 on: July 26, 2016, 03:32:15 PM »
all of the above
I was wondering because, my carpet had those very same symptoms.... 8)
« Reply #191 on: July 26, 2016, 04:53:36 PM »
Thanks guys!
Do you get any speed wobble at higher highway speeds?
Offline riffman12
« Reply #192 on: July 27, 2016, 08:44:22 AM »
nope I've been up to about 85mph and it feels really solid
only annoying thing is a vibration through the footpegs that makes my feet go numb after a while. But that feels more like it's from the engine as I don't really get it through the bars.
« Reply #193 on: July 27, 2016, 10:23:44 AM »
If you haven't experienced numbness in your hands riding with clubmans, you haven't been on a long enough ride!  ;)
