The clutch cable needs to be re-routed properly for safety sake. The speedo cable (from the right side of front wheel) needs to be restrained so it doesn't rub the tire. It looks like there's some "custom" wiring done under the seat. Some good clear pictures of that would be helpful.
It looks like the clubman bars are mounted, but not bolted down? Also, your brake reservoir needs to sit "upright" so as not to suck air in the system. Okay, enough about the seat... We've all bought bikes with ugly seats before-
Can you explain better why the electric start doesn't work? No button? Not wired? Did the PO (previous owner) remove the starter motor for some reason? Kick start is fun too, but electric start is better in traffic if you dump the clutch at a light
I differ from others; keep the pods and tune your bike. Yes, it will take more doing, but you can get it to run well with some trial and error and good input from folks like Flybox.
All those "phillips" screws are not Phillips, they're JIS. And they're different. Buy a set of JIS bits for your tool set and then you will be able to remove them easily without stripping the dog poop out of them. This is the number 1 tool for a new bike owner I'd recommend.
