Author Topic: no marking on top piston ring, CB550  (Read 866 times)
Offline BigBird
  • learning and doing
« on: October 09, 2015, 07:36:25 AM »
I´m re-installing a single top piston-ring (scraper) and wonder if the orientation matters as the top rings don´t have any marking as the other lower rings.
Any opinion appreciated, thanks!
Offline fizzlebottom
Re: no marking on top piston ring, CB550
« Reply #1 on: October 09, 2015, 07:49:13 AM »
If yours are like mine (CB650), there's one with a chrome edge and one without. The one with the chrome edge is rounded and orientation doesn't matter. The one without has a specifically shaped edge and orientation does matter. The marking for this one goes on top. It may be hard as #$%* to see, so wipe it off and use a magnifying glass if you have to.
1982 CB650SC Nighthawk
Offline BigBird
« Reply #2 on: October 09, 2015, 08:00:04 AM »
Thanks, yes, the 2nd ring has clear orientation marks on all four.
Offline BigBird
« Reply #3 on: October 09, 2015, 08:17:23 AM »
the top ring has a slight lip on the outer edge.
i read from diagrams that the lip should be facing upwards like this:
Even though the other cylinder rings on 3 & 4, which i never touched, is facing with lip down. I'm assuming itts best to trust what worked previously, as i didnt burn a large amount of oil
« Last Edit: October 11, 2015, 02:32:49 AM by BigBird »
