Author Topic: Buchanan Spokes on '77 CB550F Rear Wheel - Widening Spoke holes?  (Read 715 times)
Offline dagersh
    • Photos
Hi Guys,
Did a search, and not really finding the answer.
I have powdercoated my hubs.  The front wheel with the Buchanan Spokes literally fell together.  However, I am having a problem with the rear wheel.
In order to even attempt to get the inner spokes seated I would really have to wrestle it in.  I spoke with Buchanans and they suggested cleaning out the PC, which I did.  It helped a bit, but still not enough.  I can only get them 95% there, getting hung up at the bend of the spoke.
Interestingly, the outer spokes slide right in as they should, and also slide right in if I put them in the inner position as well (they go in both ways easily).
So, here is the question:
I used a 15/64 bit to carefully clean out the PC from the spoke holes.  Can I go up to 1/4 (the next size up) to widen the spoke hole?
I think if I do, I can lace the inners easily.  However, I do not want to compromise the rim.
As always, your input and advice is greatly appreciated.
Thanks,
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB450/500 Custom
1972 CB500K1
1975 CB550F
1976 CB400F
1975 CB750 Future Restoration
1976 CB750K6
1976 CB750F
1976 GL1000
1968 Suzuki T500 Cobra
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline 540nova
Re: Buchanan Spokes on '77 CB550F Rear Wheel - Widening Spoke holes?
« Reply #1 on: October 12, 2015, 12:05:37 AM »
I would never put a drillbit through my hub holes like that. Use some oil on them and twist them and spin them as you wiggle them in.
Offline jonda500
« Reply #2 on: October 12, 2015, 05:28:44 AM »
Sounds like the inner spokes are the wrong ones - there are different spokes used in these wheels that are the same length but different length in the short bit after the bend - maybe you could make the wider part of the hubs holes deeper(so the heads are more counter-sunk) to suit the spokes you have?
John
A starter clutch thread:
Offline dagersh
    • Photos
« Reply #3 on: October 12, 2015, 07:49:53 AM »
Good answers guys.  Did it very carefully, and ended up taking off the PC.  The spokes still need to be forced in, but they do go and fit well.
Jonda500, I thought the same thing myself, in conversations with Buchanan's, its the Outer spokes that have as many as three different sizes.  I had sent them pics and measurements at purchase.
Now, when I laced up the wheel, I think I got my spacing off, and I was not able to get my last side of outers to lace.  I will give it another go today.
Thanks!
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
