Author Topic: Cover Your Eyes - This Could Hurt The Purist - Frame Bolt-in Pics  (Read 2617 times)
Offline RRRToolSolutions
  • I love old Japanese bikes!
Well, it's going slowly. The machinist friend's shop is down for a while so I had to hire it done elsewhere and get "worked in". I'll put all of this into a more organized fashion later once I'm done bolting it back in so I can show the "after" shots. Once the tank is on, I'm counting on it being absolutely invisible. The machinist and frame welder helping me with the fabrication say it's much stronger than the stock, light weight tubes were. This mod adds 2.8 pounds to the frame. The machined pieces are made from cold-rolled solid steel. The bolts are all grade 8 hardware and the ends are precision fits as the photos show. The fronts screw into the inserts so access is not blocked and can be removed once the "jam" nut is lossened. There are a total of 8 pieces of fabrication. The Eastwood epoxy Extreme Chassis Black is nice paint. It worked well over the scuffed up powdercoat. I did not try to remove the powder, only scuffed it with 240 grit and 3 heavy coats of epoxy. It won't rust and the gloss turned out nice. All pieces are welded in and now permanent. The removable section was powdercoated - leaving the machined edges bare so as not to interfere with the fit. We made one little goof - the tubes to the rear on the removable piece should have been left 1/4" longer. We cut the wrong side of the line.
Remember that saying - measure twice, cut once?  :-[
Anyway, I'm very happy it's done. I should have no more leaks and 'if" I decide to do more head work, change cams, or even remove the cases to install those Carillos - I can do so without the pain of clearing the frame.
Regards,
Gordon
« Last Edit: October 31, 2006, 07:40:27 PM by Ilbikes »
Kaws, Hondas, Yamahas, and Suzukis - especially Kaws
Re: Cover Your Eyes - This Could Hurt The Purist - Frame Bolt-in Pics
« Reply #1 on: October 31, 2006, 07:50:29 PM »
Looking good Gordon, can't wait to see it finished.
Sam.
Offline KB02
« Reply #2 on: November 01, 2006, 05:16:26 AM »
I agree. Looks great. Just like Honda Should have done. I have a small leak in the right front corner of head gasket. Just enough to see a tiny little bit of engine juice seepin' out. I really don't feel like pulling the whole engine just to fix it.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
« Reply #3 on: November 01, 2006, 05:26:15 AM »
I have the same leak...just started this year and after pulling the engine on other 2 bikes I dont really feel like doing the third.
Andy
« Reply #4 on: November 01, 2006, 06:22:04 PM »
Hey Gordon, sounds like you could make some money doing frame conversions ;D ;D ;D
Sam. ;)
Offline angeldeville
  • You meet the nicest people on a Honda!
« Reply #5 on: November 01, 2006, 06:28:57 PM »
Truly beautiful, nothing is more pure than actually improving these bikes!
76' cb750f custom
69' cb750 sandcast
69' CT90
Amen Saviour 750 Chopper frame
and enough parts to build about 6-7 more bikes
Offline sparty
  • I just play one on TV
    • Gallery
« Reply #6 on: November 01, 2006, 06:32:19 PM »
Well done.  My bike has a similar set-up, but it isn't as clean looking.
The pic below (a bad angle) shows how it looked before it was painted.
Sparty
« Last Edit: November 01, 2006, 06:37:12 PM by sparty »
1972 CB750 K2 Cafe' Style
« Reply #7 on: November 01, 2006, 07:14:06 PM »
Guys, I bolted her in this evening and will install the tank and seat tomorrow after checking the wiring hook-ups (installed a NOS ignition set and a NOS right handlebar switch while she was down) and priming the cam and valve train after the re-assembly and fixing that pesty leak. It went back real sweet. The small button bolts went at 25 foot pounds while the large front jam nuts went to 60 foot pounds - she ain't going anywhere. I'm 100% sure I'd do it again. Being able to work on the bike in-frame is the way it should be.
Regards, Gordon
Here are some updated photos -
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #8 on: November 01, 2006, 07:45:34 PM »
                    Now, I don't have a 750SOHC but, if I did (or ever do) that sure looks like the way to go.
            Great job! Well planned & executed! Ever think about putting it in the Tips & Tricks?
                                                  Later on, Bill
Member # 1969
Offline nteek754
  • 1973 K3/750/836/70 1970 750 chopper 1973 cafe
« Reply #9 on: November 02, 2006, 08:25:32 AM »
Hey all for you guys that do this to your bike Ive got a brandnew copper head gasket that I bought  for one of my 750 projects  but you have to install gasket run up to temp retorqe head and run up to temp and retourqe head  Kinda a pain in the backside having to pull the engine each time  if I dont sell it I may build a craddle from an old frame I allready cut up  20 bucks let me know thanks Craig in Maine  seven fifty four ever
seven fifty four ever its not the destination its the journey Ive been collecting these old dinasours for 33 years . they are quite an ICON
« Reply #10 on: November 02, 2006, 08:38:49 AM »
Very well done Gordon. ;)
