Author Topic: 1975 CB550K Restoration  (Read 35191 times)
Offline HondaAddict
    • Videos on my CB550K restoration and other projects
Re: 1975 CB550K Restoration
« Reply #75 on: December 27, 2017, 09:34:24 PM »
Usually the shocks are gone and you could tell how bad they were with springs removed.  The Hagons and Ikons are excellent replacements, better to spend that much to get a good shock, you won't regret the expense.  Consider it a safety item like tires and a good helmet.
there are sintered caliper pads available from EBC, worth choosing.
With a lathe you can fab several things.  Look up FunJimmy's Cafe Interceptor build, nice resto mod front end.
You could do that hub work and earn a few $ doing it for others.
RaceTech gold valve emulators for your forks if you stay with original forks are recommended.
likely your fork springs are toast and need replaced.  Most were needing replacement with 12-15k miles max.
You can skim the center of your fron hub's raised cooling ribs as the front does not need that and a cut and polished hub center is very nice.  Waxing the back of the fork ears helps keep rust at bay and wax on chrome will make it easier to wash and clean and maintain the shine.
Great info - thanks! Sintered pads are now on my list.
My fork spring lengths are within service manual specs and the shocks are passable. I'm hanging on to as much original equipment as I can for now, simply because I don't see this bike getting many miles and my project budget is stretched these days. There are quite a few handling upgrades I'd like to make if it becomes a regular rider.
I bookmarked FunJimmy's build thread for reading over morning coffee tomorrow. Much education and inspiration to be gained there. Like Jimmy, many folks here set the bar damned high! :)
1976 Honda CB400F
1975 Honda CB550K (sold in 2020)  Project thread | Videos
2008 Honda GL1800AL
2016 Honda CB500F
2018 Honda CB300F
1984 Honda V65 Sabre (sold in 2020) Project thread on V4Musclebike.com | Video
1986 Honda Z50R
Offline HondaAddict
« Reply #76 on: December 31, 2017, 01:58:24 PM »
So, I realized today that my engine has a bad case of the infamous wear problem in the #1 intake rocker shaft bore. On the upside, I hadn't started sanding this piece. :)
I guess I'm on the market for a 77/78 CB550 cylinder head cover. So far I haven't seen any on ebay, etc. Does anyone here know where I can buy one? I'll post an ad in the classifieds as well.
« Last Edit: January 07, 2018, 02:04:00 PM by HondaAddict »
1976 Honda CB400F
2008 Honda GL1800AL
2016 Honda CB500F
2018 Honda CB300F
1986 Honda Z50R
Offline HondaAddict
« Reply #77 on: January 06, 2018, 08:46:39 PM »
Rear wheel hub B/A.
« Last Edit: January 06, 2018, 08:50:06 PM by HondaAddict »
1976 Honda CB400F
2008 Honda GL1800AL
2016 Honda CB500F
2018 Honda CB300F
1986 Honda Z50R
Offline HondaAddict
« Reply #78 on: January 07, 2018, 06:42:03 AM »
You didn't remove the bearing and replace it? It looks beautiful though-
Thanks.
Bearings are on my list. I didn't have the replacements and I needed to make some form of visible progress for motivation. This rocker arm shaft issue has been a bit discouraging. :)
1976 Honda CB400F
2008 Honda GL1800AL
2016 Honda CB500F
2018 Honda CB300F
1986 Honda Z50R
Offline HondaAddict
« Reply #79 on: March 03, 2018, 08:41:51 AM »
I found a replacement valve cover. It cleaned up fairly well.
1976 Honda CB400F
2008 Honda GL1800AL
2016 Honda CB500F
2018 Honda CB300F
1986 Honda Z50R
Offline HondaAddict
« Reply #80 on: March 03, 2018, 08:44:49 AM »
Clutch cover cleaned up. With all the covers finished, the next step for the engine is to get it ready for paint.
1976 Honda CB400F
2008 Honda GL1800AL
2016 Honda CB500F
2018 Honda CB300F
1986 Honda Z50R
Offline HondaAddict
« Reply #81 on: April 07, 2018, 12:30:51 PM »
Rear wheel re-assembled (waiting for new sprocket). Attached are a few B/A shots.
1976 Honda CB400F
2008 Honda GL1800AL
2016 Honda CB500F
2018 Honda CB300F
1986 Honda Z50R
Offline HondaAddict
« Reply #82 on: April 21, 2018, 06:54:59 PM »
Carbs completed.
« Last Edit: April 30, 2018, 02:34:36 PM by HondaAddict »
1976 Honda CB400F
2008 Honda GL1800AL
2016 Honda CB500F
2018 Honda CB300F
1986 Honda Z50R
« Reply #83 on: April 21, 2018, 11:56:53 PM »
beautiful work man
Offline HondaAddict
« Reply #84 on: April 22, 2018, 07:43:40 AM »
1976 Honda CB400F
2008 Honda GL1800AL
2016 Honda CB500F
2018 Honda CB300F
1986 Honda Z50R
Offline HondaAddict
« Reply #85 on: April 25, 2018, 06:57:13 PM »
Engine painting finished.
Before
Cleaned up, after about a week of my spare time.
Masked. I sacrificed my old valve cover & gasket as a masking shortcut.
Underside painted.
And the rest.
A day later.
« Last Edit: April 30, 2018, 02:31:41 PM by HondaAddict »
1976 Honda CB400F
2008 Honda GL1800AL
2016 Honda CB500F
2018 Honda CB300F
1986 Honda Z50R
Offline HondaAddict
« Reply #86 on: April 29, 2018, 10:09:21 AM »
Swing arm and stands finished.
« Last Edit: April 30, 2018, 02:36:37 PM by HondaAddict »
1976 Honda CB400F
2008 Honda GL1800AL
2016 Honda CB500F
2018 Honda CB300F
1986 Honda Z50R
Offline HondaAddict
« Reply #87 on: April 29, 2018, 10:11:34 AM »
And... painted the rest of the frame. Clear coat to follow.
« Last Edit: April 30, 2018, 02:19:59 PM by HondaAddict »
1976 Honda CB400F
2008 Honda GL1800AL
2016 Honda CB500F
2018 Honda CB300F
1986 Honda Z50R
Offline HondaAddict
« Reply #88 on: May 01, 2018, 07:36:51 PM »
Gauges finished. I opted for the chrome aftermarket covers. I wasn't sure I'd like them, but they're growing on me.
« Last Edit: May 01, 2018, 07:39:00 PM by HondaAddict »
1976 Honda CB400F
2008 Honda GL1800AL
2016 Honda CB500F
2018 Honda CB300F
1986 Honda Z50R
Offline HondaAddict
« Reply #89 on: May 04, 2018, 06:56:49 PM »
Seat before/during/after. I didn't anticipate how much work it would take.
« Last Edit: May 04, 2018, 08:18:10 PM by HondaAddict »
1976 Honda CB400F
2008 Honda GL1800AL
2016 Honda CB500F
2018 Honda CB300F
1986 Honda Z50R
Offline HondaAddict
« Reply #90 on: May 10, 2018, 07:16:41 PM »
And... back in with the engine.
I tacked on the covers to see how it all looks. My new stainless bolts should arrive any day and I have to make a gasket before buttoning it up.
« Last Edit: May 10, 2018, 07:18:25 PM by HondaAddict »
1976 Honda CB400F
2008 Honda GL1800AL
2016 Honda CB500F
2018 Honda CB300F
1986 Honda Z50R
« Reply #91 on: May 10, 2018, 11:21:10 PM »
Looking good!
« Reply #92 on: May 11, 2018, 09:04:46 AM »
I can't tell precisely from the picture, but, it looks as though you may have the fork gators on wrong. The "seams" should be oriented to the rear of the bike, and the weep holes on the bottom pleat, not the top. That allows moisture to drain out.
Could be the pictures, but you do want to verify that installation...
You must have a great monitor, Cal. I can't see that on my stinking iPhone!
Offline HondaAddict
« Reply #93 on: May 11, 2018, 02:35:35 PM »
Thanks for pointing this out. I haven't yet stretched the gators onto their seats, so I'll be able to turn the seams to the back. However I'm unsure about the gators being upside down. You mention the weep holes need to be at the bottom of the pleats. That makes perfect sense to me and mine are in the upper part of the pleats, so I was initially convinced you're right.
Then I googled a few photos and it seems like the longer cuff (as shown below in a gorgeous photo from the SOHC/4 Gallery) is always at the bottom, as I've installed mine.
Is it possible that the weep holes are not for moisture but for air to exit/enter when they're compressed/stretched? If so, it would make sense for them to be in the upper part of the pleats to hide them and allow less moisture in.
If I need to flip them, now's the ideal time, so any advice you or others can offer would be much appreciated.
« Last Edit: May 11, 2018, 02:42:05 PM by HondaAddict »
1976 Honda CB400F
2008 Honda GL1800AL
2016 Honda CB500F
2018 Honda CB300F
1986 Honda Z50R
Offline HondaAddict
« Reply #94 on: May 11, 2018, 05:28:54 PM »
With respect to the photo, I defer to the penultimate authority for 550 restorations, SohRon. He made this point specifically in his thread that the hole needs to be at the bottom of the fork, on the underside to let moisture (from condensation) week out and to help prevent corrosion.
I have no particular data which is correct, but if you spent the time that he did to get everything factory perfect, I’d respect his opinion on the matter. It is possible the pictured bike is incorrectly restored too. But it sure is beautiful!
Thanks. I'll have a look at SohRon's thread. I appreciate your advice. You clearly have a sharp eye!
1976 Honda CB400F
2008 Honda GL1800AL
2016 Honda CB500F
2018 Honda CB300F
1986 Honda Z50R
Offline Little_Phil
« Reply #95 on: May 12, 2018, 02:35:53 AM »
You can’t flip the gators as the form is different at each end. Just fitted genuine Honda gators to a 500. One was vintage stored for 20 years (and still in Honda packaging), on was new from DSS. Both have holes underside of every other convolution. The holes are near one seam. Also have some aftermarket gators and all are underside of convolutions, but not necessarily on/near a seam.
Having said that I do think that they are mainly is to expel/ inhale air.
Lovely bike, great restoration. I'm going to back and read the whole thread now. I have four 500/550s.
Offline HondaAddict
« Reply #96 on: May 12, 2018, 05:57:47 AM »
Thanks!
I grabbed this photo and cross-section drawing of the fork from the service manual. These also show the longer cuffs on the bottom.
« Last Edit: May 12, 2018, 05:59:53 AM by HondaAddict »
1976 Honda CB400F
2008 Honda GL1800AL
2016 Honda CB500F
2018 Honda CB300F
1986 Honda Z50R
Offline HondaAddict
« Reply #97 on: May 12, 2018, 08:39:53 PM »
I made good progress today. Clutch, rear end, wiring harness, turn signals, engine hardware, etc. Getting close...
« Last Edit: May 12, 2018, 08:44:46 PM by HondaAddict »
1976 Honda CB400F
2008 Honda GL1800AL
2016 Honda CB500F
2018 Honda CB300F
1986 Honda Z50R
« Reply #98 on: May 13, 2018, 09:14:49 PM »
Those are some great photos!
Offline HondaAddict
« Reply #99 on: May 16, 2018, 06:38:42 PM »
Thanks! My wife takes many of them (and all of the decent ones).
1976 Honda CB400F
2008 Honda GL1800AL
2016 Honda CB500F
2018 Honda CB300F
1986 Honda Z50R
