Author Topic: my henry abe pistons and cyls compression Q  (Read 5089 times)
Offline BPellerine
« on: October 12, 2015, 04:19:19 pm »
a pic of my ha pistons and the package they came in,appear to be diff than the other types of ha pistons
the cylinders are early with nice thick fins and no casting flash!
« Last Edit: October 19, 2015, 08:04:13 pm by BPellerine »
1978 CB 750K ard and webers
another anfob
Offline Bill/BentON Racing
    • BentON Racing
Re: my henry abe pistons and cyls
« Reply #1 on: October 12, 2015, 05:04:33 pm »
I've  got 3 of those!! That's what was in Purple Rain! !  ;D, Bill  Nice looking cylinder.
BentON Racing Website
BentON Racing Facebook
Offline BPellerine
« Reply #2 on: October 12, 2015, 05:18:59 pm »
hmm I did not know that was what was in purple rain,I am gathering henry abe stuff so I have spares,this going in my engine.bill
another anfob
Offline NalleyRacing
  • 1972 Cb750K dragbike Instagram: Drag_racer736
« Reply #3 on: October 12, 2015, 09:44:48 pm »
I have 3 used henry abe pistons from a build right now along with a NOS set of sleeves with the taper at the bottom.
Funny thing is the old ones are flat top turbo style pistons like you have there and we found in purple rain.. but my new Henry Abe set have slightly more compression
« Last Edit: October 12, 2015, 09:49:51 pm by TreyAllen »
« Reply #4 on: October 13, 2015, 04:52:55 am »
Look same as mine...  http://forums.sohc4.net/index.php/topic,150456.msg1717063.html#msg1717063
Bill, diameter of your pistons?
Mine are like 67.45mm around the sleeves, 66.9mm at top.
My cylinder to them is old, before the additional 8 thick o-rings to seal better. Will it leak more without these?
Offline BPellerine
« Reply #5 on: October 13, 2015, 10:45:03 am »
pewe they are all 67 mm pistons for the ha kit,so maybe a little diff in tolerance ,the cyls are bored for each piston.I don't think that they will leak any more than later cyls,cycle x say you don't have to use the seals with their mls gasket,and what did people do before the 8 seals?billp
another anfob
Offline BPellerine
« Reply #6 on: October 13, 2015, 10:54:26 am »
these have a slight dome that you cant see,how about a pic of the diff pistons so they are in one place,slipper type,pewes type,and these.I thought there were only 2 types.bill
another anfob
« Reply #7 on: October 13, 2015, 11:33:01 am »
My take is if the cylinders were made for the seals then use them.
As you say, there are 2 different HA 900 pistons. Maybe more?? I've only seen/noticed 2 types. You have the heavier ones.
    • BentON Racing
« Reply #8 on: October 13, 2015, 03:38:19 pm »
Well, not so so fast young man, you thinking with the little head anyhoo!  ;D I personally don't use them like Kenny / CycleX, I could be wrong, let MikeR. chime in, but I believe he's no fan either, Bill
« Reply #9 on: October 13, 2015, 04:37:10 pm »
 ;) you damn straight bro!
I figure it's extra insurance as my rationale. The 1000 I just put together had the cylinders done by Big Jay @ APE. Later model cylinders. He plugged up those holes for the seals so he doesn't believe in them either. Said they are unnecessary so I CAN'T use them on this engine.
Offline BPellerine
« Reply #10 on: October 13, 2015, 05:34:07 pm »
I am not saying to use/not use the seals,and I know why they are there but lots of early bikes do not have them and with prep they should be as good as any,if you get a gasket set now for 69/78 the head gasket is made for the seals but the gasket is used on early as well,anyway I have heard it said that these were the walmart big bore,but I aint racing so no diff.hahabillp
another anfob
« Reply #11 on: October 13, 2015, 06:00:11 pm »
Here is what your next set looks like, they are on the Way..
 I figured you may like the box, so I built another to wrap around it.
Offline BPellerine
« Reply #12 on: October 13, 2015, 06:05:31 pm »
thanks a lot frank,nice to have spares when you run obsolete stuff,and this proves that there are 3 diff kinds,those are like pewes,and flat.bill
another anfob
« Reply #13 on: October 14, 2015, 01:00:23 am »
It look like 2 versions of the older heavier ones. I have the older heavier but 67.5mm instead of 67.... measured with 2 different old Mitutoyo calipers with same result.
- Bill, can you measure your pistons, around skirts and top?
    • BentON Racing
« Reply #14 on: October 14, 2015, 05:05:37 am »
My H Abe 900cc pistons, one might need some extra polishing!  ;D, Bill
Offline BPellerine
« Reply #15 on: October 14, 2015, 10:09:46 am »
if you look closely at mine the valve cutouts are less half moon in shape,but the same dome.billp
another anfob
« Reply #16 on: October 14, 2015, 10:37:50 am »
My HA pistons are very flat.
Offline BPellerine
« Reply #17 on: October 14, 2015, 01:33:56 pm »
pewe I will measure mine for you,I will be getting a nos set like yours,I will be able to compare.wonder why the valve cutouts are like that?billp
another anfob
Offline BPellerine
Re: my henry abe pistons and cyls compession Q
« Reply #18 on: October 19, 2015, 08:02:51 pm »
I was wondering if anyone could tell me the effect on compression using these flat,67mm pistons with a stock combustion chamber would have,the slight dome is right at deck height.I know there are other factors that figure into this,but I have not milled the head or cyls at this point,just bigger bore into small chambers.thanks bill
another anfob
Offline BPellerine
Re: my henry abe pistons and cyls compression Q
« Reply #19 on: October 20, 2015, 10:55:04 am »
pic
another anfob
« Reply #20 on: October 20, 2015, 12:09:59 pm »
Bill, here is the picture of my Henry Abe piston top. Looks like it was designed to be used without head chamber work maybe, which you had asked about in the PM?
Offline turboguzzi
« Reply #21 on: October 20, 2015, 12:53:39 pm »
can you put a side view of that 67mm piston? looks like the ticket for something i have in mind..... tnxs!
« Reply #22 on: October 20, 2015, 02:14:54 pm »
Unable to locate a clean picture at the moment
Offline BPellerine
« Reply #23 on: October 20, 2015, 02:23:06 pm »
thanks jerry,I see yours are higher compression,with a 3mm band around the piston to clear head,the other one is really low compression!!!hahabollp
another anfob
Offline turboguzzi
« Reply #24 on: October 20, 2015, 10:56:24 pm »
tnxs J. remember by any chance who high is the crown?
