Author Topic: '77 CB750 K7 café - Here I go again  (Read 20053 times)
Offline Andy K
Re: '77 CB750 café - it's running! but what about the jets?
« Reply #50 on: March 19, 2016, 04:37:47 AM »
And of course little test ride.. small one  :)
my middle son was immediately coming ride with me. not yet.. later when weather is warmer, now it was -10 degrees.. and ice on roads
ex bikes:
Honda CBR 1100XX '98
Suzuki VL1500 Intruder LC '98
Suzuki GSX1300R Hayabusa '03
this is my version of Honda CB750 '77:
http://caferacer77.blogspot.fi/2015/10/tasta-lahdettiin.html?m=0
Re: '77 CB750 café - ready for the summer..
« Reply #51 on: March 19, 2016, 03:37:52 PM »
Yikes!
Sunny and warm today. 70 degrees F/21 C
Offline Andy K
« Reply #52 on: April 03, 2016, 12:27:35 PM »
okay... can ride but still something is wrong.
Emgo pods, 120 main jets, 35 pilot jets, air mix 2 turn out from seated, needles one clip lower from middle of five (richer).. still need choke that can ride normally.. need 125 jets or bigger? needle clips lowest (richest) set?
ex bikes:
Offline Andy K
Re: '77 CB750 café - carb adjusting..
« Reply #53 on: April 04, 2016, 12:48:10 AM »
need to check float level first. I think they are reason to this.. or not. maybe floats are too low that pilot jets can't get fuel enough. that is why have to pull choke, main jet helps pilot jet..
ex bikes:
Offline Andy K
« Reply #54 on: April 06, 2016, 02:42:23 AM »
great!! regulator is broke..  >:( >:( >:( Do regulator need all three wires black,white and green... what about reg/rec combo where is only black and white wires??
ex bikes:
Offline Andy K
Re: '77 CB750 café - regulator brokes..not working anymore
« Reply #55 on: April 06, 2016, 08:23:47 AM »
..or wires in front light cover are wrong places.. or new igniton swich is broke or.. or.. or.. testing and troubleshootin begins again.
ex bikes:
Offline Andy K
Re: '77 CB750 café - Working.. or not..
« Reply #56 on: April 11, 2016, 05:46:29 AM »
now it's not even try to start.. little bit pissed right now..
I don't understant what is happened.. light fuse burned couple time.. check the wires, was driveable but now it do nothing.
« Last Edit: April 11, 2016, 05:48:16 AM by Andy K »
ex bikes:
Offline Andy K
« Reply #57 on: April 13, 2016, 08:45:04 PM »
battery empty..offcourse. load... meanwhile loading battery I look wires again. so..wiring diagram on hand.
With full battery and change some wires places works better but still battery goes empty pretty fast. I pressed start button couple of times and it turns engine but suddenly only "bbzzzzz" sound from solenoid.. battery is new but is it dead allready? have to fired up the engine (float level adjust first!) and test how much it's load from engine..
ex bikes:
Offline Andy K
« Reply #58 on: April 15, 2016, 12:32:44 AM »
now it's getting weird..
float level adjusted and fired up the bike (with bigger help battery) terrible
missfires but the weird thing is that when I turn lights off bike runs better than ever!! whaaat?!?! lights takes all power.. what a he..
ex bikes:
Offline Andy K
Re: '77 CB750 café - Now what??
« Reply #59 on: April 17, 2016, 09:45:54 PM »
earlier I find out that when bike is running and lights on, front light get more bright when turn revs from engine. I think that power comes straight from stator to front light. I loaded battery (new battery, bought on September, put in bike this spring) and volts shows 10,6.. put ignition on (with lights) volts drop about 6 to 7, and press start witch, volts dropped under 4!!
every power supply is stock only tail light and speedometer is aftermarket parts
with help power started the bike and put RPM.. Volts stands under 8V! F*****k!!!
(new)battery is been in bike only couple months.. maybe batteries could die this fast?
I haven't fix the regulator, only thought that it could be broken.
Good thing is that engine runs great but without lights and starts amazing easy with kickstart
ex bikes:
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #60 on: April 17, 2016, 09:48:46 PM »
Charge the battery. You have to start out with a fully charged battery. The alternator will not work properly if you do not have 12v (or more) at the battery before starting.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Andy K
« Reply #61 on: April 18, 2016, 02:00:43 AM »
done that.. not work. With full battery it will empty very fast. Need to test today with other motorcycle battery from another bike which working normal. Then is possible to find is it battery dead or my charger just won't load like it should be and I have low battery voltage all time.
weird thing is no matter which rpm is, there is no changes in volts..
ex bikes:
Offline topperharley
« Reply #62 on: April 18, 2016, 03:55:42 AM »
You can try with aftermarket reg/rec.
I had loadin issues but that was a wiring problem about reg/rec Did you connect the wires right? I posted pm about this in finnish. Pistin yv:tä.
http://forums.sohc4.net/index.php?topic=156830.0
« Reply #63 on: April 18, 2016, 04:03:33 AM »
Check here for very detailed charging system troubleshooting (scroll down to the charging system section):
http://www.hondachopper.com/garage/troubleshooting_charging_system/troubleshooting_charging_system.pdf
and here:
http://forums.sohc4.net/index.php/topic,1012.msg8345.html#msg8345
TAMTF...
Wilbur
Projects:
Offline Andy K
« Reply #64 on: April 19, 2016, 10:20:23 AM »
holy sh...!  I can't be leave it it works again  8)
I test volts around the bike about an hour and take regulator off and wondering what a hec is wrong with this? I watch pictures on internet and suddenly I got it! There is sticker (black-white-green) on side of regulator and suprise suprise when I'm taken the regulatorcover off before, I've putt the cover back wrong side!! so the colours are opposite..Stupid and funny own mistake at same time.. now I got 14.5V in battery.
 Sorry and thank you
ex bikes:
Offline Andy K
Re: '77 CB750 café - Works again vol.2
« Reply #65 on: May 11, 2016, 03:43:12 AM »
couple pics.. bike feels good. I'm happy now. License plate frame had to move left side because rear tire hit on it. So tail light frame is pretty different but same place.
ex bikes:
Offline Andy K
Re: '77 CB750 café - Here I go again
« Reply #66 on: September 08, 2016, 11:19:47 AM »
Long time no seen!!
quess what??
I take engine apart.. why? oil leaking from cylinder head. Just I get bike works great and made some adjusting to carbs, oil made my legs wet..
So the enginw is peaces and goin to change cam chain and primary chain and tensioners offcourse.
ex bikes:
Offline Andy K
« Reply #67 on: September 08, 2016, 11:30:38 AM »
I put some pics later, where's the oil came from.. I got lot more things to do on winter so I take time for this and not taking stress. hopefully get back on road next fall.. hopefully
ex bikes:
« Reply #68 on: September 08, 2016, 12:42:04 PM »
Could be a good time to replace your studs too. And beware, there was a whole batch of junk non-stock cam chain tensioners that were being sold recently. The lesson learned by many members who used them was to spend the few dollars more and buy true, stock Honda tensioners.
Amen to that:
http://forums.sohc4.net/index.php/topic,155043.msg1774841.html#msg1774841
TAMTF...
Wilbur
Projects:
Offline Andy K
« Reply #69 on: September 08, 2016, 01:34:18 PM »
ouch.. I feel pain in my heart...
CMSNL and David Silver is places where I buy stuff for honda.
Other things to do is blast and clean engine all over with soda and paint it better.
When putting engine back in business thank god we have a Hackaweek on youtube. I've watched those clips several times and learn lot of tips, and need to watch couple more time.
« Last Edit: September 08, 2016, 01:37:24 PM by Andy K »
ex bikes:
Offline Andy K
« Reply #70 on: September 09, 2016, 11:29:50 AM »
okay.. here is the reason why I take engine to the table again and where oil leaks
There is previous owners Einstein idea in cylinder head. They had try to cover those holes with something black silicone or something else s***t. I put loctite in previous time when engine was open but I don't understand how this silicone haven't get off earlier when sodablasted the engine.. Anyways.. Because I need to take cylinder head off, it's better to do bigger service to engine.
So.. need to do this time:
-Cam chain + tensioner
-Primary chains + tensioner
-all seals and gaskets
-sodablast and paint
« Last Edit: January 02, 2017, 03:06:53 AM by Andy K »
ex bikes:
Offline Andy K
« Reply #71 on: September 09, 2016, 11:32:58 AM »
and pictures..
ex bikes:
Offline Andy K
Re: '77 CB750 K7 café - Here I go again
« Reply #72 on: February 12, 2017, 02:22:50 PM »
New brakes..
ex bikes:
Offline Andy K
« Reply #73 on: February 13, 2017, 08:09:09 AM »
Looks ok
ex bikes:
Offline Andy K
« Reply #74 on: April 23, 2017, 12:14:49 AM »
Sodablasted.. Again
« Last Edit: April 23, 2017, 12:24:18 AM by Andy K »
ex bikes:
