Author Topic: 550 cam timing mark  (Read 1735 times)
Offline BigBird
  • learning and doing
550 cam timing mark
« on: October 18, 2015, 02:42:19 PM »
I am timing my cam and supposedly the notch is missing, or is it one of the marks in the following pics.
Cam sprocket only has a 25 stamped, and some casting lines that are barely visible.
End of camshaft has a big mark which seems unprecise to make the timing with.
Any thought is greatly appreaciated, thanks!
Offline Bodi
Re: 550 cam timing mark
« Reply #1 on: October 18, 2015, 02:57:23 PM »
Well, your second image shows the notch rather clearly. If this is your cam (not an image of a different one) I don't see your problem. Engine at TDC 1-4, cam notch as described in the service manual (I think it's correct as pictured), work the chain over the sprocket until the bolt holes line up.
Offline mrfish2
  • I might be a
« Reply #2 on: October 18, 2015, 07:41:55 PM »
Take a picture straight on at the end of the camshaft, it almost looks like you could be off a tooth from the camera angle assuming you're at TDC.
But yeah, what Bodi said. Make sure engine is at TDC 1-4 and the notch is pointing straight foward parallel to the ground.
1976 CB550K            1979 XS1100
1980 CB650C - Sold
It's a little motor and likes having the tits revved off it.
Offline BigBird
« Reply #3 on: October 19, 2015, 02:00:43 AM »
Thank you for replying. Guess that was obvious, oh well, it was a tooth off and that is corrected now. Will post a pics for ref !
Tonight is the time of first startup after rebuild
Offline BigBird
550 cam timing mark
« Reply #4 on: October 20, 2015, 04:52:04 PM »
So finaly some good news -the epic first startup, though did i misplace the sparkplug wires so it starts to run on two, unfortunately.. Still, after building oil preassure, it fires on the first kick. You can hear an excited umph. Haha
And on all four a moment after, and with just the header - no muffler
Cheers
