Im using a timing light to dynamically set my timing. Here's the issue: The timing for 1-4 is advanced at idle (left of mark) which is around 1200 RPM, but at full advance the timing falls within the marks (just on the left tick mark). Idle timing for 2-3 falls on the mark and full advance is also correct.
I can no longer turn the plate clockwise to correct the advance for 1-4 at idle as there is no more space on the plate.
- Points are not new, but are in good shape
- Disassembled/cleaned/reassembled points and advance mechanism
- Gap set to 0.014
- No play in the plate when unscrewed so No need to shim
What am i missing here?
