Author Topic: 76' CB550K Aftermarket Turn Signal Wiring Need HELP! Thanks!  (Read 749 times)
Offline rwhiskey
« on: October 20, 2015, 03:20:42 PM »
Hey Everyone I was hoping you could help me out with these aftermarket T/S and Left Switch wiring troubles.
So if you look at the attached diagrams I made it will show how I have the wires hooked up.
With the ignition key in the on position and moving the T/S Hand Switch:
T/S Switch Center - No T/S Running Lights
T/S Switch Right - All T/S Lights on Solid
T/S Switch Left - All T/S Lights OFF
The Left Hand Switch I'm working with from Dime City:
http://www.dimecitycycles.com/chrome-left-side-turn-signal-headlight-and-horn-handlebar-control-switch.html
"Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac?"
- George Carlin
1976 CB550K Basket Case
Offline Bodi
Re: 76' CB550K Aftermarket Turn Signal Wiring Need HELP! Thanks!
« Reply #1 on: October 20, 2015, 03:33:09 PM »
I don't see any running light function on the switch. Where do they connect to?
Assuming the switch connects "t/s main wire" to the signal wires, the wiring would be pretty simple if you ignore the running lights. Your list looks right so something is not connected as per the list, or the switch is not as shown.
The flashing power (from the flasher) should presumably go to "t/s main wire" as you show. Confirm that connecting a lamp from the flasher wire to ground powers and flashes the lamp. To get the normal flash speed you need a two standard lamp load.
If that works then check the switch connects to the signal wires.
You can connect the running lights to switched power if you want them on. The stock switch turns off the running light on the flashing side to make the front signal more visible, your switch doesn't have that function.
