So i have palstigauges and two rods which have bad bearings and i have to measure other two good. And maximum measurement what you want is 0.08mm but how i know which bearings i have to order? because in manual bearings are A or C or B but there isnt any measurements like in crankshaft bearing section in manual. So how i can know which bearings i have to order? and what bearings i have to take if the clearance is bigger than 0.08? does this bearing selection think same like the crankshaft bearing selection, so std clearence is 0.00-0.8
bigger clearence bearing is 0.08-0.16?
