SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Frozen Oil Filter Bolt
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Frozen Oil Filter Bolt (Read 1412 times)
gwallis
Enthusiast
1976 Honda CB550F 1973 Honda CB750
on:
October 21, 2015, 06:06:40 PM »
Well... I have another issue with the 1976 CB550F I recently bought. The bolt that holds the Oil Filter assembly together is frozen and impossible to remove. Especially since I rounded the bolt head trying to remove it.
I tried heating the bolt... I tried using a large ViseGrip pliers and I also tried using a cold chisel and a hammer to turn the nut... with no luck.
Any suggestions on how to deal with this? I did see a YouTube video of someone that welded another nut on top of the bolt and then used an impact wrench.
Gary
Logged
calj737
Really Old Timer ...
I refuse...
Re: Frozen Oil Filter Bolt
Reply #1 on:
October 21, 2015, 06:08:19 PM »
welding the nut works very well. you can dremel a slot into the bolt head and try a large screwdriver, but...
Logged
'74 550 Build
http://forums.sohc4.net/index.php?topic=126401.0
'73 500 Build
http://forums.sohc4.net/index.php?topic=132935.0
MCRider
Such is the life of a
Today's Lesson: One good turn deserves another.
Reply #2 on:
October 21, 2015, 07:27:19 PM »
Centerpunch the remaining nub and drill it out in ever increasing amounts until the head falls off. Then you can pull the cover off. Then you can turn the remaining bolt out. Usually it comes easily because the sticture often occurs between the bottom of the head of the bolt and the cover, not so much the threads themselves.
Logged
1988 NT650 HawkGT; 1978 CB400 Hawk; 1975 CB750F -Free Bird; 1968 CB77 Super Hawk -Ticker; Phaedrus 1972 CB750K2-
Build Thread
gwallis
Enthusiast
Reply #3 on:
October 22, 2015, 03:13:45 AM »
Guys:
'Thank You' for the sugguestions.
MCRider,
I just might try drilling the bolt until it allows the case to slip off. I was thinking along those lines but thought it might be too extreme! Looking at the OEM's part diagram confirms that it all should come apart once the bolt head is removed.
Thanks again,
Gary
Logged
70CB750
Labor omnia vincit improbus.
Northern Virginia
Reply #4 on:
October 22, 2015, 03:19:25 AM »
There was a picture, somebody took sawzall to it - sliced across the oil filter housing and the bolt - and used vicegrips to get the bolt out afterwards.
Makes some sense, the head of the bolt is usually stuck - as McRider mentioned - and there is plenty of decent oil filter housings available on ebay and other places.
Logged
BobbyR
Proud Owner of the Babe Thread & Dirty Old Man
Reply #5 on:
October 22, 2015, 10:13:43 AM »
You can take a cheap smaller sized socket. Pound it onto the rounded part.
Logged
Gene
Chat enuf you too can be a
Master
One bike is enuf, change my mind
Reply #6 on:
October 22, 2015, 04:56:34 PM »
Large Pipe wrench. Maybe - worth a shot.
Logged
*1973 CB750K3 (Bow)
gwallis
Enthusiast
Reply #7 on:
October 22, 2015, 05:04:44 PM »
Well .... I got it off.
I tried the heat, Hammer and Chisel one more time and it started to turn. A little more heat, more hammering and it came off.
I ordered a new Oil Bolt assembly... $54.00...Yikes!!
'Thanks' for all the input,
Gary
Logged
BobbyR
Reply #8 on:
October 22, 2015, 05:52:20 PM »
Congratulations!
Logged
gtmdriver
Enthusiast
Reply #9 on:
October 23, 2015, 12:35:06 AM »
Unless you need the originality an after market bolt with a 17mm head is a good swap.
Logged
gwallis
Enthusiast
Reply #10 on:
October 23, 2015, 03:41:20 AM »
Yeah... I was too quick to buy the OEM part from a Honda Dealer ($54). I found the same part on the '4 into 1' parts website for $13.00.
The 4 into 1 website (
www.4into1.com
) has some very nice prices on CB550 parts... I will keep this in mind as I go through the build.
Take care guys!
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
