Author Topic: Very Noobie  (Read 1429 times)
Offline Rocket
Very Noobie
« on: October 28, 2015, 03:45:48 AM »
Greetings to anybody willing to read this.  This is my very first post so sorry if i balls things up a tad, like wrong threads etc.
I am restoring a Honda 1973 CB350 Four and although can not afford to get it to concourse status I would like to get it somewhat original.
I have re-laced both wheels with stainless steel spokes (I did say "somewhat original) but have run into 2 problems.
First is "What is the actual "offest" for both wheels", I didn't know about that when I took the old spokes  off!
And secondly is it possible to put "original" Bridgestone tires back on both wheels.  The copy of the manual just says Bridgestone 3.00 x 18 and 3.50 x 18, without type, tread or model.
Hoping some one can help.  Cheers
Life is good if you have a beer in the fridge and can afford the electricity to keep them cold!
Offline dusterdude
Re: Very Noobie
« Reply #1 on: October 28, 2015, 07:12:53 AM »
Welcome
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline chewbacca5000
  • I polish covers!
Re: Very Noobie
« Reply #3 on: October 28, 2015, 09:04:34 AM »
There is no offset.
Offline Johnie
Re: Very Noobie
« Reply #4 on: October 28, 2015, 11:57:34 AM »
Welcome to the forum. Can not go wrong with the CB350. Did a 72 last year myself. Another good source for you: http://www.hondatwins.net/forums/forum.php
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline calj737
  • I refuse...
Re: Very Noobie
« Reply #5 on: October 28, 2015, 04:30:38 PM »
Except the bike in question is a 350/4. He's in the right place after all
Offline Johnie
Re: Very Noobie
« Reply #6 on: October 28, 2015, 06:39:02 PM »
Oops...missed the Four :)  If you need other 350 parts then try the Honda Twins site. Very helpful guys there with extra parts if you need anything. And welcome aboard.
Oshkosh, WI  USA
Offline Rocket
Re: Very Noobie
« Reply #7 on: October 29, 2015, 02:17:27 AM »
Thanks for the welcomes, looks like I have some help out there!  Cheers.
No off set!  Great, had me looking and worrying needlessly, on-wards from here.
OK,  the original Bridgestone tires are not made anymore so would the BT45 be ok?
I kind of like the Dunlop K81's that I remember but am sooo old I may have that balls up too.
Again Thanks and Cheers
Re: Very Noobie
« Reply #8 on: October 29, 2015, 07:07:59 AM »
BT45's are great tires, I have them on my K4. Not really a vintage looking tread though.
  • I polish covers!
Re: Very Noobie
« Reply #9 on: October 29, 2015, 07:42:21 AM »
I asked a guy who has done this for 5 years as a professional mechanic and that is what he told me.  I laced up 3 sets worked out great.
I am lucky as I have discount steel supply place and made my own truing stand out of 1/2" steel plate.  Steel alone cost $80.  Rigidity of the stand is the most important factor.  With my stand I can true to racing speck fairly easily.  AVoid the harbor freight setup go for a good one.  Should run around $100.  You may need to reinforce it to improve rigidy.
Re: Very Noobie
« Reply #10 on: October 29, 2015, 08:13:36 AM »
Some guy use old swing arms too.  Let me know if you want one
Offline faux fiddy
  • bike in a box
Re: Very Noobie
« Reply #11 on: October 29, 2015, 01:42:24 PM »
I think the tire sizes translate to 90/90  18   front and  100/90  18  rear.
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
Offline Rocket
Re: Very Noobie
« Reply #12 on: November 21, 2015, 02:17:22 AM »
So  I have re-laced the wheels with stainless spokes and nipples from Thailand, the spokes are very good BUT some of the nipples split and were drilled out of square!
Short version, $110 latter for 72 new nipples, $295 for labor  to "true" and balance both wheels all looked good!  Then I noticed that the front tire was put on backwards, ie: the arrows are wrong......DOES IT MATTER??  Thanks
Offline calj737
  • I refuse...
Re: Very Noobie
« Reply #13 on: November 21, 2015, 03:50:38 AM »
Orientation does matter with tires.
Re: Very Noobie
« Reply #14 on: November 21, 2015, 02:37:04 PM »
I think buying quality parts rather than cheap spokes would save some headaches. I shop here...
http://www.buchananspokes.com/products/spoke_kits_honda_cb.asp
Offline faux fiddy
  • bike in a box
Re: Very Noobie
« Reply #15 on: November 22, 2015, 03:01:34 AM »
Some  people prefer certain tire patterns mounted backwards, and race them that way. I try to get mine on right.  I guess the cords inside have more to do with it than the tread(?).
Offline Rocket
Re: Very Noobie
« Reply #16 on: November 22, 2015, 03:35:59 AM »
Thanks, and you may be right, cheap may not always work for the better.  I will take the wheel back and reverse it  when I am closer to finishing.  Again,  thanks all
