Author Topic: Im screwed....right? Caution using an o-ring chain on a 550!  (Read 10331 times)
Offline FunJimmy
  • Who you calling
  • Vancouver
Re: Im screwed....right? Caution using an o-ring chain on a 550!
« Reply #25 on: February 25, 2007, 10:35:46 AM »
Seems we are all purchasing 530 O-ring chains and now learning that these are not recommended. Bummer!
How about making or purchasing narrow spacers to add clearance. I’m soon going to be lacing up new wheels with a 3” wide alloy rim on the rear and have been told that if the chain clearance to the tire is to tight, just shim the sprockets.
Does anyone have experience shimming sprockets and a supply for shims.
Cheers
FunJimmy
Offline eurban
« Reply #26 on: February 25, 2007, 06:10:07 PM »
Go to Cycle Exchange's website and look at their offset sprockets.
« Reply #27 on: February 25, 2007, 08:29:26 PM »
Oddly enough, Honda just released a critical service bulletin about using O-ring chains on CB series bikes. Honda recommends that, under no circumstances, should an O-ring style chain be used on CB series motorcycles. They even said that it will void your warranty.  :D
I suspect that my warranty may have expired after 37 years? :)
ChopperCharles
« Reply #28 on: November 17, 2007, 07:25:07 PM »
Where can I find  a 15 tooth front sprocket and a 37 tooth rear sprocket, 520 size, for a CB550K so I can run an o ring chain?
Thanks!
Charles.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #29 on: November 17, 2007, 10:31:16 PM »
Sprocket Specialties can provide all the sprocket combinations you can dream of.
ChopperCharles
« Reply #30 on: November 18, 2007, 06:57:27 AM »
They only list 530 sprockets for the 550...
Charles.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #31 on: November 18, 2007, 08:27:19 AM »
I stand corrected!
It really isn't difficult to machine the front sprocket and space it from the cases.
I'll post pictures later if it'll help.
FJ
« Reply #32 on: November 18, 2007, 08:55:56 AM »
I had a 530 front machined to the proper width. Then bought a 520 blank for the rear and of course had to machine for the hub center and mounting holes.
ChopperCharles
« Reply #33 on: November 18, 2007, 03:14:43 PM »
I don't have access to machining here unfortunately.
Charles.
Offline apex_seeking
  • Ron Swanson is a
« Reply #34 on: December 24, 2010, 04:46:15 PM »
I had an oil leak from that same left side cover. I thought it was the shift shaft seal as well so that was replaced. After a ride I realized that that was not the fix. I figured that it could wait until my winter tear down as the leak was just a drip here or there.
I wanted to get an o-ring chain because I was getting a lot of chain lube slinging onto my wheels. While doing a little research I found this thread and decided that I'd take a look at my chain a little closer. I have an o-ring chain thanks to the PO and it has eaten a nice groove into my seal as well.
Any of the temporary solutions here work? Just looking for a little follow up.
Offline Hush
« Reply #35 on: December 24, 2010, 06:54:27 PM »
This is from May 2005? man someone dug furiously. ;D
  • Ron Swanson is a
« Reply #36 on: December 24, 2010, 07:03:43 PM »
Hahaha! I believe in the search button! ;)
Offline solo 2
« Reply #37 on: December 24, 2010, 07:06:33 PM »
Here's some good info on chains if anyones interested. I've never had an O-ring last any longer than a non o-ring, and you still need to lube them.
http://www.quality-cycle.com/truth_about_motorcycle_chains.htm
You know you've achieved perfection in design, not when you have nothing more to add, but when you have nothing left to take away.
« Reply #38 on: December 24, 2010, 07:08:29 PM »
Not much to lose by cleaning it really well with alcohol and putting a JB weld patch over the leak.
Either that or pull the case halves apart to insert a new seal.
Then either ditch the oring chain or get an offset front sprocket to keep the chain away from the patch.
Offline q2418130103p
« Reply #39 on: December 24, 2010, 07:39:09 PM »
Who makes an offset front sprocket?  I know cycle x has one, but its offset rather far.
Check out my CB550 project thread:
http://forums.sohc4.net/index.php?topic=83097
  • Ron Swanson is a
« Reply #40 on: December 24, 2010, 07:47:37 PM »
And all I saw were sprockets for 750's.
« Reply #41 on: December 24, 2010, 08:28:48 PM »
A machinist can mill off one side of a standard sprocket and make a spacer for the side that is un-milled.
I just use standard chains on my CB550s.  They are lighter, and if you use Black PJ-1 chain lube properly (and regularly), fly off is minimal.  What does fly off is easily cleaned with mineral spirits.
Offline Goofaroo
  • general nuisance
« Reply #42 on: December 25, 2010, 05:11:15 AM »
Bingo!
The only thing to add is that if your chain is shot, so are your sprockets. They might still look okay but as pins and rollers in the chain wear and the chain increases in length, it wears the sprockets to match the length of the chain. Putting a new chain on old sprockets will cause a mismatched condition and render accelerated chain wear. Your dollar will be stretched further and your driveline will be much smoother if you replace the chain and sprockets as a set.
1972 CB500 four
1972 CT90
1974 CT90
1978 BMW R100S
1983 CX500
1986 GL1200 Aspencade
1986 CH150 Elite Deluxe
1984 NH125 Aero
2005 Genuine Stella 2T
2007 KLR650
2002 KLR250
1985 XR350R plated
1994 DR350SE
2004 Concours ZG1000
1987 KDX200 C
1992 KDX200 E
2010 BMW F800GS
Always room for one more.
  • Ron Swanson is a
« Reply #43 on: December 25, 2010, 05:23:27 AM »
Thanks for all the input. I think must of what I was seeing all over the rim was from the oil leak onto the chain. Not the lube I was applying. After messing with it for a bit last night, I agree with twotired, a standard chain has got to be lighter than that o-ring chain. That thing is a beast.
Anyway, lesson learned.
Offline Kong
« Reply #44 on: December 25, 2010, 08:45:27 AM »
I guess the only real question to be answered here is if anyone has had long-term success with a temporary repair (rub on goo of some sort or another) of the original problem.
There are a couple of other threads on this subject (as those of us who faithfully use the Search function first know) in which the proud owner, as opposed to the previous owner, smeared either MarineTex or JB-Weld around the area with at least temporary success, which begs the question again - did it hold?
I'm also a bit interested in the response about the 350 plug, is there a similar alignment stub on the 550's case and seal that might be removed to make this a repair that can be accomplished without splitting the cases?
Oh, on that Search thing, when I was doing a search on this subject I also ran across a bit of discussion about the purchase of a set of sprockets and chain in 520 (I think it was) that were special ordered for the bike; the when and where and maybe even the cost, were mentioned.  I didn't keep a link to it, I think it was Sprocket Specialists, but just to let everyone know, they are available.
2002 FXSTD/I  Softail Deuce
2001 Acura (Honda) CL Type-S
1986 Honda Rebel, 450
1978 Honda CB550K
1977 Honda CB550K
Offline crazypj
  • I'm brill, me
« Reply #45 on: December 25, 2010, 08:54:37 AM »
I've never used 'o' ring chain and probably never will.
 I don't see enough advantage and do see some disadvantage, particularly on lower power bikes. (which is why 'X' ring was invented)
 If your lazy enough to think 'O' ring is worthwhile to allow lack of maintainance, your wrong, they require almost the same maintainance as a non-O-ring.
 There is nothing to seal lubrication between rollers and bushings, only seals between bushing and pin.
Offline Tintop
« Reply #46 on: December 25, 2010, 10:50:38 AM »
I installed 520 sprockets and an 'X' ring chain on my 550 build.  Alloy rear from Sprocket Specialties, machined 530 front (like Bwaller), which uses the stock 550 bolts and clip to position.  It was not an inexpensive solution, but as I plan to show the bike as well as ride it, I wanted to reduce the mess of a standard chain.  I would agree with TT that using a standard 530, is probably the best and least expensive way to go.  My 750K3 with be getting new 530 sprockets, and a 530 X-ring chain, as I feel the 630's are much to heavy, and rob power.  Be sides I already have the chain. ;) :)
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline Deltarider
  • I'm back
« Reply #47 on: December 25, 2010, 10:56:34 AM »
Happen to disagree. The last 100.000 kms (CB 500) I've always used two chains on one set of sprockets and I'm not the only one. With a simple (non-O-ring) Tsubaki QR I've always managed over 15.000 kms per chain. No problems.
« Last Edit: December 25, 2010, 11:03:21 AM by Deltarider »
CB500K2-ED Excel black
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #48 on: December 25, 2010, 04:11:56 PM »
I know the 77-78 750's came with a 630 chain, but I do not believe they were "O-ring" chains. I have used o-ring chains, both 630 and 530 on my 78' 750K and have experienced some mild scoring on the case. I believe I wil be converting back to non o-ring 530 chain when the current chain wears out.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Goofaroo
  • general nuisance
« Reply #49 on: December 25, 2010, 06:18:07 PM »
I guess the question to pose would be what kind of mileage everyone gets out of their chains and at what point they deem them unusable. I would personally expect more than 15000 kilometers (9320 miles) from a new chain and sprockets. I would say that in my experience a new chain and steel sprocket set (alloy is another story) has always lasted at least 20,000 to 30,000 miles or until I sold the bike, whichever came first. On the ones that I replaced because they were beyond the service limit, the sprockets were worn as well and would have eaten a new chain for lunch.
1972 CB500 four
1972 CT90
1974 CT90
1978 BMW R100S
1983 CX500
1984 NH125 Aero
2007 KLR650
2002 KLR250
1985 XR350R plated
1994 DR350SE
1987 KDX200 C
1992 KDX200 E
2010 BMW F800GS
