Author Topic: Gentleman's Express 550 engine build  (Read 40756 times)
Re: Gentleman's Express 550 engine build
« Reply #75 on: December 13, 2015, 07:07:56 PM »
So question (for HM)... For my 550f I was experiencing clutch slip as well. I replaced the stock plates and disc's with Kevlar Disc's and Titanium plates (Barnett Clutch kit) also included stiffer springs and was not all that pricey. I cant get it to slip no matter how hard I try.. Would that be better than using CB750 dics and plates or do the CB750 offer better results and did I waste money on this clutch kit?
Thanks,
.: Scott :.
I'm glad to hear about new technologies that work: I tend to stay with those I know, especially when it's not my own bike. I don't want to drop something new (and untried by me) into someone's extensive rebuild, then discover he has troubles with it later. Once in a while someone asks me to use 'this or that' parts, and I'll do it on their request if it seems like it will be OK. Other times they may ask me to install a part that I already KNOW will be troubles, and I usually refuse: I'd hate for them to ride off and not make it to the sunset?
Offline Zaipai
    • My Home page
« Reply #76 on: December 13, 2015, 08:35:19 PM »
So its about going with what you know rather than something new I get that. Well all I can tell you is I ran with this set up all summer (about 1k miles) and in some heavy traffic and so far so good it still hooks up solid and has a very firm feel. I am glad I did it however time will tell if it was a smart move or not! :)
Thanks HM..
.: Scott :.
Its my Avatar..
75 CB550F  |
« Reply #77 on: December 14, 2015, 03:28:39 PM »
Thanks HM..
.: Scott :.
Thanks, Scott: maybe periodically keep us all posted? Lots of 'us' want a beefier 500/550 clutch.
« Reply #78 on: December 14, 2015, 03:55:30 PM »
Thanks HM..
.: Scott :.
Can either Scott or HM provide some details on this clutch?
« Reply #79 on: December 14, 2015, 06:59:58 PM »
Thanks,
.: Scott :.
Scott was talking about a fancier clutch that he made from Barnett parts: maybe ask him about the pieces? I know the Barnett parts, but not the fancy plates he mentions.
Offline Zaipai
    • My Home page
« Reply #80 on: December 14, 2015, 07:03:57 PM »
So what I picked up was the kit, it included the plates, discs and springs. It was the same cost as the stock one so I figured no harm to go with the kit. The kits are usually for sale on E-Bay, 4into1.com etc....
Here is their website.
http://www.barnettclutches.com/
.: Scott :.
Its my Avatar..
75 CB550F  |
« Reply #81 on: December 14, 2015, 10:10:32 PM »
Today's work was both good and bad: I finished augmenting the head chambers, added a wider quench band, semi-hemi'd them for more midrange torque, and started to cut the bottoms of the pistons to clear the crankweights. Then the trouble: I had not removed the pistons yet to this point (I have ENOUGH parts lying about the garage at the moment, didn't want to confuse me...), only to discover that the small end of 3 of the 4 rods are deeply scarred. It is reflected in their wristpins, which were real hard to remove. There are 120 degrees arcs cut in the small ends of the rods, with a corresponding groove in each wristpin, from rust particles where wetness had rested itself into the top oiling holes, rusted the pins, then the engine got turned over with the rust in the way. It appears to have happened long ago, as the grooves are rusty on both the pins and the rods.
Gotta find a set of rods for a 500, now...
« Reply #82 on: December 14, 2015, 10:13:36 PM »
The bottom of the 750 pistons interfere with a couple of the crank weights by just a touch. It looks like the sides of the pistons can be cut enough to open up a gap of just over 1mm. If this isn't enough, I'll have to have the crank turned a bit to trim off another 1mm from the flyweights.
Offline calj737
  • I refuse...
« Reply #83 on: December 14, 2015, 11:09:23 PM »
I've got a good set of 550 rods already paired with their caps, if you can use them. I'm reasonable on pricing too  ;)
Offline flatlander
« Reply #84 on: December 14, 2015, 11:12:41 PM »
.: Scott :.
you mentioned titanium plates, i can only find the steel ones on their site. can you point out the exact kit you bought?
also: how's the clutch operation in traffic when you often need to start from a stop, and do the stronger springs make your hand tired?
Offline Zaipai
    • My Home page
« Reply #85 on: December 15, 2015, 04:50:32 AM »
Its possible they don't make them any longer not sure. I will see if I can dig up where I got them from its been a while. I don't do traffic I live in farm area almost no traffic however on a few trips I did venture across the boarder and encountered traffic and it seemed to do well.
Yes, my clutch hand gets tired quicker with this setup but the solid connection I feel off the line and between gears are well worth it.
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline mrfish2
  • I might be a
« Reply #86 on: December 15, 2015, 08:35:31 AM »
.: Scott :.
Lossa has the complete kit, not a terrible price either for everything that comes with it (including a clutch cover gasket!).
http://www.lossaengineering.com/products/honda-cb550-barnett-complete-clutch-kit
1976 CB550K            1979 XS1100
1980 CB650C - Sold
It's a little motor and likes having the tits revved off it.
Offline Zaipai
    • My Home page
« Reply #87 on: December 15, 2015, 10:16:55 AM »
Correct..
Here are the Kevlar set on Barnett's website..
http://www.barnettclutches.com/310/honda/0/0/1975-honda-cb550f.html
The plates are steel but they did a little while back offer stronger ones but probably did not sell so ..
The springs are supposed to be about 20% stiffer than stock.. Not sure I have no way of testing that.
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #88 on: December 15, 2015, 10:28:30 AM »
I was going to get this kit last winter, but decided against it after hearing horror stories of cracked clutch baskets, due to stronger springs. Used my original springs with new plates. Still a scary feeling torqueing it down. I'm sure stronger springs are just fine as long as you make DAMN sure everything is lined up perfectly before torqueing and you go slowly and correctly.
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
Offline Zaipai
    • My Home page
« Reply #89 on: December 15, 2015, 10:52:48 AM »
Yes, exactly and 20% stiffer won't cause any issues with the basket that wouldn't happen even with stock springs. Its defiantly much more firm feeling clutch and there is no question its not slipping. :)
.: Scott :.
Its my Avatar..
75 CB550F  |
« Reply #90 on: December 15, 2015, 10:58:35 AM »
Thanks, Cal!
I found a set locally, will use those. I appreciate the offer:
Merry Christmas!
Offline Kickstart
« Reply #91 on: December 15, 2015, 11:03:06 AM »
Thanks, Cal!
Merry Christmas!
Could you also sleeve the small end's?  I was under the impression that it improves performance (although I'm not sure how much of an improvement it would be hp wise).
- Chris
75' CB750F Orange flake (rider)
75' CB750F Blue (Project)
75' CB750F Painted black (Project)
No Reserve Racing #171 AHRMA
Offline calj737
  • I refuse...
« Reply #92 on: December 15, 2015, 11:57:11 AM »
Hey Mark- Perhaps in an effort to re-track this thread away from clutch options, you could elaborate your preference for modifying a cast 750 piston versus purchasing a new forged unit? I know from other posts, you appear to be gun shy over forged units, but with all the guys running them, it seems these issues are no longer prevalent. So is there a performance reason, a reliability reason, or a romantic reason that drives your preference?
Offline Zaipai
    • My Home page
« Reply #93 on: December 15, 2015, 12:02:48 PM »
 ;D
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline edwardmorris
  • Youngish
« Reply #94 on: December 15, 2015, 12:18:36 PM »
I'd imagine it being hard to argue $0 for cost as there are plenty usable 750 pistons collecting dirt? Most rebuilds on the 750s usually end up with either an 836 or the next size up on the pistons.
« Reply #95 on: December 15, 2015, 12:41:30 PM »
As far as hp and torque goes...the chain alignment can really rob more power than you might think. Any extra movement robs power and can cause wear, whether it is at the front sprocket or rear. Good enough is probably going to be good for street bikes but having it dead-nuts straight fro front to rear and the output shaft of transmission and axle parallel with sprocket on output shaft perpendicular through its rotation will reduce wear and be most efficient.  The chain not have to accommodate a rear sprocket a mm or two off center from the front sprocket,  etc.  This is engineering of the system for highest efficiency. It is overkill for most bikes, as it is complicated to make it that way and stay that way...
Especially when adjusting the chain becomes more complex.
Sorry,  complex subjects cannot be said briefly and convey the necessary info...
David
« Reply #96 on: December 15, 2015, 02:07:41 PM »
Thanks, Cal!
Merry Christmas!
Well, in another thread where we were just discussing the free-turning, lubed wristpins of these engines vs. some forged units that don't have oil holes in the wristpin bosses...(whew), I suspect that bronze-bushed small ends would reduce friction, absolutely. Usually, in my experience, these are the kind of mods the endurance-race guys like, because the bronze outlasts the cast iron in such places. If my 750's rods ever wear out, I would like to look into doing it for mine, just to test it? Whenever the engines are held at high RPM for extended time (like 200 mile races, or maybe all-day touring like I used to do), this would be a good thing and would generate less friction, heat, and extend the oil's life, as there is less shear between the steel pins and bronze than between the steel pins and iron.
« Reply #97 on: December 15, 2015, 02:50:29 PM »
Yeah, I am kind of gun-shy from not having the best results (long-term) with forged pistons in these engines. At least a part of that is the type of engines these are: they are made for cast pistons, with the alloys of the cylinders being very close to the alloys of the pistons - for good reason: this matches their thermal characteristics closely. The rings, too, are designed with the steel liners in mind, which is one reason why the 1-piece oil rings outlast the 3-piece types: their thermal masses are similar. The 1-piece oil rings are very light and lose or gain heat more rapidly than the thicker liners, so during the startup cycle these rings wear a bit more than the 1-piece type: this is the primary point where increased wear occurs.
But, back to the pistons: the forged pistons grow and shrink at rates different from the cylinders. For reasons that are not clear to me, the manufacturers of these forged pistons require more than twice as much piston-to-bore clearance than the cast pistons. And, if not clearanced this much, they will stick if the pistons are hotter than the cylinders, seen mostly during the initial startup-to-run-temperature cycle. This seems to infer that the forged pistons do not cool as well as the cast pistons, or else the cast pistons heat up more slowly and do not grow in diameter as much. All this presumes, though, that at running temperatures both types of pistons are running at the same clearance, which is probably near 0.0002". So, this raises the appearance that the forged pistons must grow much more than the cast pistons, because advocates of the forged pistons say they seal up the bores "better than cast pistons", whatever that means?
In practice, this is what I have experienced that makes me shy away from forged pistons in these engines: I have NEVER seen forged pistons from 811/812cc, 825cc, or 836cc versions of these engines that were NOT deeply scarred on their skirts on the front and rear sides where they are largest diameter. On the other hand, I have seen cast pistons with as much as 80k miles come out of these engines with even the original dull luster of their finish still intact, and at worst a barely-perceptible mark on the same skirt surfaces. I have also not seen very long ring life on these forged pistons, which has often been the reason I was inside the engine: 25k miles and the rings were toast, burning oil and low compression. This was usually caused by the debris from the scratched-up skirts getting caught up in the rings, chipping away their edges so they no longer sealed. Twice (that I remember) I was asked to simply re-ring them (honing it first, making even MORE clearance as the result), and the bikes I did this on did not fare well: one did not stop burning oil until the owner simply sold it, the other one would overheat on hot summer days in heavy traffic and stop (with stuck piston(s)) until it cooled down. I don't know the rest of that bike's history, as I moved away from that area soon after.
So...I don't like making engines that don't last for a long time. To that end, I prefer to stick with those parts that will help me do this? If someone is making a race bike, that's sort of a whole different thing and I may (and have) participate if asked. But racing engines' lives are measured in minutes, so lots of things are acceptable in that game that simply aren't when you're 100 miles from Nowhere, in the dark, and hoping to make it to the next town to put it down for the night.  And, especially here in the American West, that's barely a trip to the next town.  ;)
Offline Justin
    • Cj's Garage
« Reply #98 on: December 15, 2015, 03:17:40 PM »
Mark,
What do you think about coating the piston skirts with a DFL or something of the nature? That surely would reduce friction/scuffing of the bores/skirts I would think... I don't know enough, I've never built an engine with forged pistons or coated pistons before.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #99 on: December 15, 2015, 04:08:25 PM »
Your forged piston experience is simular to mine and the reason I was so happy to find original Yoshimura cast pistons for the Interceptor.
