Author Topic: Changing tires on the XR650L  (Read 1914 times)
« on: November 02, 2015, 04:51:36 AM »
This past Saturday I had set myself an ambitious project - changing the XR650L knobbies (death cornering!) for some more street friendly Avon Trailriders front and back. I had employed the services of Anders to keep me right in technique and in case I couldnt do it  8). This would be only my second time changing tires on a bike (last time was front tire on the CB750). Plus I was testing out my recently purchased trail stand that is necessary since the XR dosent have a center stand.
Trail stand works as advertised allowing for both front and back wheels to be removed
After many breaks, lots of sweating and muscling on my part and nearly 2 1/2 hrs later...
New tires warming in the sun to make it easier to get them on - it helped a lot!
The front
Trail stand lifting the rear and front
The front wheel required more inflates/deflates to get the tire to seat properly - part of issue was the tires were tubless so tighter sidewalls - eventually we went to the gas station and got it up to 102 psi  8)
The final result - corners sooooo much better!
Points to note:
1. KTM tire irons are superior to anything I had - which were two long motion pro tire irons and two short ones. The KTM ones have the right ends and it makes it much easier. 3 irons make it easier.
2. Getting the valve back in the rim defeated me this time - looking at getting a valve stem puller to help out here
3. Getting the new tire on was easier in the front. The final bit requires some strength and I discovered that I need more strength  8)
4. Right now I could probably patch a tube in the wilds but probably couldnt change a tire yet - need more practice!
The CB750K4 sunning itself waiting for a ride
cheers
Andy
Re: Changing tires on the XR650L
« Reply #1 on: November 06, 2015, 06:55:59 AM »
How much an hour are you paying the elderly gentleman? ;D I thank God for my tire changing machine. ;D ;D
Offline knowsnothing
« Reply #2 on: November 06, 2015, 07:03:35 AM »
Hahahaha
1978 CB750k Blue - for sale
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #3 on: November 06, 2015, 07:12:23 AM »
Ru-Glyde is worth its weight in gold:
http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Lubricant-Tire-Mounting-RuGlyde/_/R-BK_7651338_0361142441
http://www.amazon.com/AGS-RG18-Gal-Ruglyde-Lubricant/dp/B000CIJUGK
Motorcycle tires slide right on. I just recently spooned new tires on my Suburban with very little effort. Even the old tires slide off with very little drama.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #4 on: November 07, 2015, 03:15:54 PM »
I was paying him in coffee and ice cream  8) I was just thinking about you today Mike as I was driving up the Mass Pike to go Subaru car shopping. I have to come see you at some point its been too long! However off to China first for a couple of weeks  8)
