Author Topic: Two Fuel lines One Outlet on Petcock  (Read 5904 times)
Offline gwallis
  • 1976 Honda CB550F 1973 Honda CB750
« on: November 03, 2015, 11:48:18 AM »
OK.... so once again I am going to show my ignorance.  When I bought the 1976 CB550 it came with two gas tanks...one leaked and the other was covered in rust but was spotless inside.  Neither of these tanks were on the bike.  So when I removed the carbs I really had no idea as to how the tank and fuel lines hooked up.
Now I am putting it all back together and I see two fuel lines coming from the carbs but only one spout on the petcock.  Am I missing a 'T-Connection' of some sort?  Is one of the lines a vacuum line?
Any help in this matter would be greatly appreciated,
Gary
Offline gwallis
Re: Two Fuel lines One Outlet on Petcock
« Reply #1 on: November 03, 2015, 01:52:03 PM »
I just bought a new petcock for a 1976 CB550F and it only has one spout.  And when I look at the diagram for the 1976 CB550F it shows two fuel lines coming from the carb holder.
Can someone confirm that the 1976 CB550F has just one spout on the petcock.
Thanks in advance!
« Reply #2 on: November 03, 2015, 02:02:04 PM »
My '76 550F has one line coming out of the petcock, goes to a tee, splits and two lines feed the carbs.
BTW - the fuel line size is 5.5mm, I use 3/16" and its a good tight fit [like she likes it!]
« Reply #3 on: November 03, 2015, 02:15:19 PM »
Just FYI: Somewhere around 74-75, the CB750 switched from 2 nipples to 1 nipple and a T. Something like that happened on the 500/550s as well?
Offline gwallis
« Reply #4 on: November 03, 2015, 06:53:01 PM »
Guys... 'Thanks'... I appreciate all the help from this forum... it makes everything so much easier when you get the benefit of everyone's knowledge and experience!
And Stev-O... I hear you big time!!!
'Thanks again',
Gary
P.S.
Now where can I buy that 'T - Connection'?
Offline BollarNPS
« Reply #5 on: November 03, 2015, 08:01:35 PM »
hate to piggy back but i have the same thing on my cb650. this has cleared up my guesses on this one! thanks for sharing your problem ;D. Is there a good place to purchase this "t" part what im seeing is like 10 dollars. and would you happen to know the hose size for the 79 650s? if not thanks anyways!!
« Reply #6 on: November 04, 2015, 06:40:00 AM »
The OEM fuel line is 5.5mm (7/32"). This presents the problem of procurement. Most common is 3/16 (too small) or 1/4" (too big). Both will often work, force the 3/16 on or clamp the 1/4 in on. Ts can be found at any auto parts store for cheap.
But if you want the OEM fit, you'll need to buy OEM sizes from a dealer or online dealer.
Offline Scott S
« Reply #7 on: November 04, 2015, 08:02:21 AM »
 Some 550's had a petcock and carbs with one line, some had duals. Looks like you've got a combination of the two.
 Honda never used a T fitting, but that's one way around it. Get a good brass one.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline MD
  • Living in the North Woods overlooking The Lake.
    • MN North Woods
« Reply #8 on: November 04, 2015, 06:39:33 PM »
After reading this thread I decided to do some math.
0.09375 x 0.09375 x 22/7 = 0.027611 x 2 = 0.055223
0.125 x 0.125 x 22/7 = 0.049087
The top line is the surface area of two 3/16" line.  The bottom is the area of one 1/4" line.  The two 3/16" can supply slightly more fuel.
-MD
1975 CB550F Super Sport;  Lake Superior Circle 1000, 45-90 Saddle 1000, All in Yooper 1000 and SS 2000 in 48 hrs:  1985 GL1200A, MN in State SS1K
« Reply #9 on: November 04, 2015, 07:01:36 PM »
Quote from: Scott S link=topic=
[/quote
0's had a petcock and carbs with one line, some had duals. Looks like you've got a combination of the twol
 Honda never used a T fitting, ut that's one way around.....
 If Honda never used a tee, how did the single outlet petcock get gas to all carbs?
« Last Edit: November 04, 2015, 07:04:32 PM by 754 »
Offline turboed13b
« Reply #10 on: November 04, 2015, 07:26:19 PM »
[/quote
They used tees my 77 550f has one.
Offline jonda500
« Reply #11 on: November 04, 2015, 07:37:30 PM »
I guess the later PD carbs had a single fuel inlet... I wonder why the single outlet petcocks are readily available, but screw on dual outlet petcocks are as rare as hens teeth?
A while back, just after I swapped my dual outlet petcock as it didn't fit my '78 550 tank, I scored an original early model 550 supersport tank. My current favourite plan for this tank is to cut off the threaded bit where the petcock screws on, and weld on the same (but smaller diameter) bit from an old honda twin tank that I have so I can use the common readily available dual outlet petcock that many old honda twins use (which also happen to fit the '78 tank).
John
A starter clutch thread:
Offline jonda500
« Reply #12 on: November 04, 2015, 07:39:39 PM »
"They used tees my 77 550f has one."
Does any one know where to get one of these oem honda tees - I have never heard of them until now??
Edit - Actually I believe Scott S, I don't think honda originally used a tee piece on any of the 70's CB550s at all!
« Last Edit: November 04, 2015, 07:48:00 PM by jonda500 »
« Reply #13 on: November 04, 2015, 07:54:42 PM »
Yes, it's on the '77 550F fiche:
    011   JOINT, FUEL
16235-657-000   001    Discontinued
No longer available from Honda. Here's a brass one....
http://www.ebay.com/itm/Adapter-Fitting-Brass-Barb-Tee-0-22-5-5mm-Hose-For-Air-Water-Fuel-/151871358592?hash=item235c3d0680:g:DqwAAOxyHE5RugOc&vxp=mtr
Offline jonda500
« Reply #14 on: November 04, 2015, 08:05:05 PM »
Hey Stev-o, good to learn that info and great to know that a 5.5mm diameter tee is available - have added that to my watch list! :) Thanks,
John
« Reply #15 on: November 04, 2015, 08:31:58 PM »
John
You're welcome, Jonda.  It's a little pricey, you may find a better deal, that's just the first one I ran across.
Offline Oz350Four
  • Keep yer stick on the ice...!!!
« Reply #16 on: November 05, 2015, 12:01:38 AM »
If I recall correctly for the 72 CB350F a single fuel line goes to a T that is part of the "fuel rail" for the four carbs..??!!
"Me speed officer...?? never..!!!"
1972 CB350F Four - Project Ol' Red (current)
2007 Harley Davidson Softail Deuce - Sold to start this project.
« Reply #17 on: November 05, 2015, 12:38:42 AM »
My CB750K6 -76 petcock have one outlet mounted on the right side (left)! :) The fuel line had a T-connection when the OEM carbs have 2 fuel inlets. Smoothbore carbs have 1 inlet, Mikuni TMR 2 again.
Now using older type of petcock with 2 lines when the Yamiya tanks have that design (69-74) with petcock on wrong side (right). Trickier when fuel suddenly starvs and need to switch to reserve and release throttle.
Offline Scott S
« Reply #18 on: November 05, 2015, 03:46:54 AM »
[/quote
 OK, then...technically, the "T" was part of the rack of carbs. I don't believe there was ever a "T" between the tank and the carbs.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #19 on: November 05, 2015, 03:50:49 AM »
    011   JOINT, FUEL
 Well, I'll be darned. I stand corrected. That's a new one on me. And that brass "T" is exactly what I've used in similar situations before.
'71 CB500 K0
'81 Yamaha XS650
