Author Topic: Tip for troubleshooting carbs w/o removing from bike  (Read 1098 times)
Offline fastbroshi
  • Puppet
« on: November 04, 2015, 08:47:08 AM »
  I was doing a lot of fuel system troubleshooting yesterday and as you all know our bikes can be pretty troublesome considering most of us have four carbs on each bike.   Lot's of times it seem you need to pull the whole rack just to get access to everything and be able to remove and install components.   You have to remove the battery, its tray, airbox, unplug the electrical panel and remove it, etc.
  If you haven't already figured it out, a small, ratcheting screwdriver can be purchased that allows you to get the bowls off while the carbs are then installed.
  The leaf spring and the main jet, as well as the idle jet, can be gotten at fairly easily then.  But what about the fuel shutoff valve?  This I had a hard time with.  Once you take off the float, it just falls out.  Given how small it is, and especially for those of us with large hands, it can be a bear to hold in while simultaneously holding the float in place and replacing the brass pivot shaft.
  I found out a solution to doing this.  Get length of painter's tape, about 3 or 4", and a razor blade.   Slice a small X in near one end and place the needle valves pintle through the X on the sticky side.  Leave about 4mm or so from the edge.   You can now hold the piece of tape and manage to hold and manipulate it enough to stick up in it's brass holder.  Once there, press the tape against the body of the carb with the slack of the tape going towards the front of the bike.  This excess will stick out for a reason.
  Now get your float and reinstall.  It should now be directly under the needle valve.  Gently tug on the slack going towards the front of the carb and it should rip fairly easily and drop the valve on the float tang.  This is why you want just enough slack from the edge of that X you sliced, so it will rip easily.  I had to do this 3 or 4 times last night and it works like a charm.  Saved me from having to R&I the carbs quite a few times!  Not to mention removing all the other stuff to get to the carbs.
« Last Edit: November 04, 2015, 05:47:31 PM by fastbroshi »
Just call me Timmaaaaay!!!
Offline mrfish2
  • I might be a
Re: Tip for troubleshooting carbs w/o removing from bike
« Reply #1 on: November 04, 2015, 09:06:03 AM »
Wait....you have to remove the battery, its tray, airbox, and unplug the electrical panel to get the carbs off?? I'm assuming from your other post you have a 550 like me, and there is no reason to have to take all that off to get the carbs off. All you gotta do is unscrew the top two bolts holding the airbox to the frame, slide the whole contraption back as much as you can (only about an inch or so) and wiggle the carbs off.
But anyway, your idea with the tape sounds like a good one for those with bigger hands. Nice!
1976 CB550K            1979 XS1100
1980 CB650C - Sold
It's a little motor and likes having the tits revved off it.
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=7a70bgef8ofnmrofuqqj1ihcl1&/topic,60973.0.html
« Reply #2 on: November 04, 2015, 09:15:59 AM »
on my 550 i just push the rubber konnektors inside the filter housing...then i can loosen the studs..and pull back the vhole rack( i do not loosen the filter housing)..10 minuts to pull it all..push pull kabels are the hÃ¥rdest  i have a 1978 k3 550..and all rubber parts are soft and nice..gives it some hot air to soften it ekstra
« Last Edit: November 04, 2015, 09:24:03 AM by strynboen »
i hate all this v-w.... vords
Offline fastbroshi
  • Puppet
« Reply #3 on: November 04, 2015, 09:20:39 AM »
Well that way is news to me.  At least I don't have to take off #$%* now!!
Offline jonda500
« Reply #4 on: November 04, 2015, 04:24:15 PM »
"just push the rubber konnektors inside"
-I wouldn't use that method unless you have nice new soft air chamber boots - original 40 year old ones would most likely rip tear crack or break if you tried to do that to them!
I can't wait to try it though, and I will next time as I have purchased new boots to use next time. :)
Thanks for the awesome tape tip fastbroshi - that will definately make it far less frustrating getting the needles to stay in while putting the floats back in, it was a right PITA when I did it!
John
A starter clutch thread:
