Author Topic: 1974 cb750 fun "Spruce Goose" (STEP 2: frame/suspension)  (Read 28452 times)
Offline mashfu
Re: 1974 cb750 fun (STEP 1b: Head)
« Reply #100 on: December 26, 2015, 06:53:39 PM »
try to keep the camtowers and rockers together with the cam you will use,they have worn in together,billp
As i suspected, wasn't sure if the towers/rockers stayed or not. Thanks bill
Offline mashfu
« Reply #101 on: December 27, 2015, 12:31:51 PM »
Got a second pair of keihin 657a carbs, missing just about everything. I kept all of the parts from the 657b and plan to transplant those. From a post i saw, Hondaman said that the 657a and b are pretty much interchangeable they just got some minor exterior changes. Found a reasonable set for the right price because one of the float pillars on the 657b broke and tig cost just about the same as what i paid for this set. I will definitely be sending the broken body to jim french, but not quite yet!
Offline mashfu
« Reply #102 on: December 30, 2015, 12:45:53 PM »
Got up close and personal with the chamber and see some pitting on the seats, will be ordering some tools from neway to cut the 3 faces once new guiides get in. Glad i have an extra head!
Offline BPellerine
« Reply #103 on: December 30, 2015, 04:52:09 PM »
not cheaper at a machine shop?cutters are exp.bill
1978 CB 750K ard and webers
another anfob
Offline mashfu
« Reply #104 on: December 30, 2015, 07:58:44 PM »
It most likely would be cheaper but i will be having some extra time so figured what the heck.
Offline mashfu
« Reply #105 on: January 24, 2016, 02:05:28 PM »
Thought i would be having some extra time to work on the project but that ended up not happening... Got even busier with work... While ordering parts i overlooked the chains so when i sat down to start assembling the engine back together i had to stop. Went through the fiche one last time before reordering all the necessary parts so hopefully sometime in next few weeks the engine will be back together!
I decided i might as well refurbish the points and advancer. New condensers and a slight cleaning/greasing now allows the advancer to rotate freely!
Offline mashfu
Re: 1974 cb750 fun "Spruce Goose" (STEP 2: frame/suspension)
« Reply #106 on: January 24, 2016, 03:42:10 PM »
Since i cant stand sitting around i guess its time to move on towards the part ive been dreading. Taking all the easy parts off and the front and rear suspension is soon to follow!
Offline mashfu
« Reply #107 on: January 24, 2016, 04:37:52 PM »
Front all out and looks like ill be needing some new parts  ;D PO seems to have tried to remove it so there are missing washers and nuts as well!
« Reply #108 on: January 24, 2016, 08:09:33 PM »
Looks like 77/78 triple trees , with a 74 tank they may be hitting forks to tank..
Offline mashfu
« Reply #109 on: January 25, 2016, 11:14:05 AM »
The way they were prior to removal, forks had decent clearance but it was definitely closer than i liked; might not even use them at all. Really leaning towards the gsxr conversion, hopefully they don't hit the tank. Can always mod the tank if they do. Ill read into it some more. Ive had to stop myself about 10 times already from ordering fronts because im not even sure how i want to proceed...
Offline mashfu
« Reply #110 on: January 27, 2016, 06:19:44 PM »
Got some well used hand controls, sun damaged pretty bad but the internals seem alright so gonna see what i can do with them!
Offline edwardmorris
  • Youngish
« Reply #111 on: January 27, 2016, 09:26:02 PM »
Get a hold of Bill Benton, he should have a good kill switch knob and other internals as well. These will clean up ok, but see if you can find non-rusted ones from him. Red vinyl dye or vinyl paint fixes that thing up nicely. For the housings, there is no match for what Marc/Powderman does with them IMO.
Offline calj737
  • I refuse...
« Reply #112 on: January 28, 2016, 02:51:04 AM »
...Or split the housings and strip them, then have them hard coat anodized.
Offline mashfu
« Reply #113 on: January 29, 2016, 06:55:11 PM »
Definitely in desprite need of some new knobs and possibly internals. Will get ahold of Bill Benton asap. Hard coat looks amazing! Ill see if i can find somewhere in the LA area.
The last of the parts are arriving for me to assemble the engine, and a pile of misc bolts which i bought because i saw an alternator bolt slewn in the mess! Time to see how much can get done this weekend! Glad to know i have a few spare nuts and bolts just in case...
« Last Edit: January 29, 2016, 07:09:52 PM by mashfu »
Offline mashfu
« Reply #114 on: January 29, 2016, 09:11:17 PM »
New parts/peices ready! Decided to just get oem/ntn ball bearings because im a lazy sob  ;D
Offline calj737
  • I refuse...
« Reply #115 on: January 30, 2016, 04:07:04 AM »
New parts/peices ready! Decided to just get oem/ntn ball bearings because I'm a masochist  ;D
FTFY
Offline mashfu
« Reply #116 on: January 30, 2016, 08:22:05 AM »
Hahaha  ::) its a new day and age! Next build will definitely get some skf's and then I'll trully understand how much of a masochist i trully am  :P
Offline mashfu
« Reply #117 on: January 30, 2016, 11:35:33 PM »
Transmission is reassembled and shifting/rotating smoothly. Thought I'd get more done haha but a few trips later to the auto parts store had the whole day gone! Tomorrow should go much smoother
Offline mashfu
« Reply #118 on: January 31, 2016, 10:15:36 PM »
Got mostly everything in today, still cleaning rods so when i put them on ill add the cam chain. Not too sure if the primary chains are supposed to go on in a certain direction or if that only applies to used ones, either way i put the new ones with green dots facing each other; in case i forget shouldn't be able to mess that up...
  • Youngish
« Reply #119 on: February 01, 2016, 07:16:09 AM »
Are you using any assembly lube or is this just a mock up?
Offline mashfu
« Reply #120 on: February 01, 2016, 10:49:16 AM »
Everything is lubed up, except the chain probably put a little on when closing the cases
Offline mashfu
« Reply #121 on: February 01, 2016, 07:20:20 PM »
Got the shift assembly on and tested to see if anything is catching etc... Seems to be shifting through all five gears just fine, but every once in a while the drum won't want to move. This could be from not rotating the crank enough because if i apply some more force to the spindle, while rotating constantly, it will find the gear just fine.
Offline mashfu
« Reply #122 on: February 02, 2016, 06:06:23 PM »
Getting closer and closer!
Offline mashfu
« Reply #123 on: February 03, 2016, 11:14:35 AM »
Gsxr suspension came in, from what ive been reading cognito sells a stem conversion that should pretty much plug and play. Pretty excited to see it all put together... Eventually. Does anyone know if the steering damper is able to be used? *edit (found the answer)*
« Last Edit: February 03, 2016, 11:22:25 AM by mashfu »
Offline mashfu
« Reply #124 on: February 03, 2016, 12:02:56 PM »
About to seal up the crankcases and since i do not have an engine stand im making the best of what i have hahahahaha
