Author Topic: "Mile High" CB350 Four project  (Read 38839 times)
Offline Denver_Larry
Re: "Mile High" CB350 Four project
« Reply #100 on: April 17, 2017, 06:07:44 PM »
Also, a bit of an update on the frame mods...  I have things almost wrapped up with all this, I just need to weld in the threaded studs for the battery cage and drill the mounting holes in the cage itself.  I think I'll do some studs for the Motogadget brain and rectifier/regulator as well and then I can finally send it to powder coat!
2005 RC51
1973 CB350F...project
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
« Reply #101 on: April 21, 2017, 09:36:46 AM »
EXCELLENT
I have a motorcycle problem.
« Reply #102 on: April 21, 2017, 10:55:29 AM »
What's going on there with your RC?
« Reply #103 on: April 21, 2017, 11:12:49 AM »
You mean my other money pit?!
That's the daily.  Only 5k miles on it so far, picked it up last fall.  It's got quite a few silly mods (rear brake, titanium hardware etc) at the moment, some more meaningful suspension upgrades will happen later this year hopefully.
2005 RC51
« Reply #104 on: April 22, 2017, 06:35:42 PM »
Finished up getting the seat pan mounts built and welded in today.  All I have left now is to weld in some threaded studs for the battery mount, and I think I'm going to change up how the rear of the tank is secured.  The original mount is kinda chunky and ugly and will likely be visible still after the seat is upholstered.  I want something similar to how a modern sport bike tank is secured at the front, with a couple rubber isolated bolts.
THEN I can finally get it powdercoated!
2005 RC51
« Reply #105 on: April 22, 2017, 06:48:30 PM »
Can I make a small suggestion about the seat underpan? A drain hole, for those wet days? :)
Just a thought...I still remember the rusted-away frame tubes on the 750K1 where some of the holes did not get drilled in production.
« Reply #106 on: April 22, 2017, 07:08:51 PM »
Sure you can!  There is actually some gaps built in around the shock mounts, and the front end of the tray will be stay wide open.
2005 RC51
« Reply #107 on: April 23, 2017, 08:11:37 AM »
Looking great!
« Reply #108 on: May 08, 2017, 04:36:44 PM »
So I'm thinking ahead and considering getting my wheels/tires ordered up and I'm wondering if anyone has tried stuffing a 120/80 tire into the back of this thing.
I've crunched all the suspension numbers and after deciding I want to target a trail number close to 97mm, picking my front tire (110/80-18), finding a shock that gets me almost 1.5 degrees less rake on the fork, a 120/80 rear will get me the rest of the way..
2005 RC51
« Reply #109 on: May 13, 2017, 04:52:17 PM »
Battery came in, along with my motogadget brain.  Went with a different battery so I had to mod the battery bracket a bit but I'm happy with how it came out.  I WAS going to weld studs on to secure the motogadget but I think I'll just drill the seat pan and use button head allens from underneath.  If I get them in black they will hardly be seen..
Any input regarding a 120 series rear tire on this thing?  Will it fit in the stock swingarm?
2005 RC51
« Reply #110 on: May 13, 2017, 04:57:20 PM »
Speedcell -- wow, you didn't mess around.  One of the best lithium based batteries out there - some even have a built in volt meter.  Speed Merchant uses them on their race bikes.
« Reply #111 on: May 13, 2017, 07:06:30 PM »
You may find that you have to run an extra link the the drive chain to let you move the axle back 1/2" for its 'first' slot. to move it away from the bow. I've seen them one the 350F before, though: the one I am thinking of had a 120/90-17" rear wheel, though (pseudo-chopper look).
« Reply #112 on: May 13, 2017, 11:13:18 PM »
Not too worried about the height of the tire, it's the width.   Sounds like it will fit.
2005 RC51
« Reply #113 on: May 14, 2017, 04:00:14 AM »
Oh no black oxide!  Pro-bolt does a black finish for their stainless that will do just fine.
As for the wiring I'm reasonably confident that I can manage that with the MU centered up as I'll probably be using an M-button to bus all the input wires.
2005 RC51
« Reply #114 on: May 14, 2017, 02:02:56 PM »
That would be awesome Cal, PM incoming!
2005 RC51
« Reply #115 on: June 03, 2017, 01:57:53 PM »
More progress on the frame, I think I'm finally ready to powdercoat!  I have the major electrical components all placed and secured under the seat cowl.  Last thing on the pre-PC list was getting the tank secured and I've got that sorted this afternoon.
Before the cut:
After the cut and with the mounting plate welded in:
Mounting tab made and welded to the modified original mount:
Mounted with a more modern set of hardware:
2005 RC51
« Reply #116 on: June 03, 2017, 01:58:49 PM »
And BTW, a big shout out to Cal for contributing a motogadget goodie to the project!
2005 RC51
« Reply #117 on: June 14, 2017, 08:50:04 AM »
Progress!  The powdercoater sent some pics after the frame was dipped and stripped.  A trip through the media blaster is next, hope to have it back today or tomorrow!
2005 RC51
« Reply #118 on: June 14, 2017, 12:59:09 PM »
After media blasting and a pre-bake:
2005 RC51
« Reply #119 on: June 15, 2017, 03:35:48 PM »
Got it back!  Color is a little darker than I was shooting for but I think it will be just fine.
2005 RC51
Offline NobleHops
« Reply #120 on: June 15, 2017, 03:37:46 PM »
It looks amazing. Did you fill the pits and voids in the frame Larry? If so, how? It looks like liquid, so nice.
« Reply #121 on: June 15, 2017, 04:18:07 PM »
No I didn't get to crazy with that, but they did do a very nice job anyway getting it smoothed out..
Looking forward to your latest care package so I can get the motor in there!  I think it's already shown up at home but I won't be back there for a couple days.  Assembly starts on Saturday!  ;D
2005 RC51
« Reply #122 on: June 15, 2017, 04:21:25 PM »
That is a brilliant blue. It really pops.
« Reply #123 on: June 15, 2017, 07:05:35 PM »
Thank guys.
Next question: what's the best way to get the original cush drives out of the rear hub?  Going to be taking it in for powder next week and I need them out..
2005 RC51
Offline NobleHops
« Reply #124 on: June 15, 2017, 08:18:58 PM »
Thank guys.
Don't do it. Leave them be. Was an enormous pain in the ass, involving torches and pointy tools. Powder with them in, it's not like they can get much harder.
« Last Edit: June 15, 2017, 08:35:54 PM by NobleHops »
